Doepfer
Question about the Dopefer Diy Kit
2010-08-22 by Diego
I'm interested in the DIY kit , can i wire the kit in manner that every block being a single module ?
thanks in advance
Re: Question about the Dopefer Diy Kit
2010-08-22 by Guy
If you mean "without normalisation" (no internal connections, as suggested in the manual), then: yes, sure. Simply skip what's suggested in the manual, and connect to sockets where appropriate.
Or use [socket]switches, and combine both... (à la ARP 2600).
I've done it that way ~ each module is separate, so patching at least *something* is always a necessity. Partly because that's my philosophy, and partly because I use banana sockets. Ha.
_g
> thanks in advance
