Doepfer
Modules for increasing VOCODER functions
2010-08-22 by ggtonet
Hello
I need your help for increasing in interesting ways the functionality and possibilities of my doepfer vocoder.
I'm not very deep in knowledge of doepfer modules because my interest is focalized in to the analog vocoders.
In my Eurorack I just have:
A-129\1
A-129\2
A-129\3
A-129\3
A-129\3
A-129\4
A-129\5
A-119
Some holes are in the rack and them want to be filled!
The carrier signals will came ever from external sources, so I'm not interested in VCO modules and complementar.
Can you help me to find interesting combinations for increasing the vocoder function?
For example:
other two A-129\4 could be required for completing the slew limiter controlling, but it seems to me not a big upgrade, another A-119 sometimes had to be usefull for having one for carrier and one for formant, but I usually use an external mic amp....
Also the matrix module (3 of them will be required! if I'm not wrong) was a possibility for an easier controll of the band filters but it will not gain or ampliate the "sounds" possibilities of the vocoder.
What's about a divider? Will be it usefull in the vocoder?
Or what's about the A-128 filterbank? Or a filter?
Please give me your suggestion, for gain the flexibility of the vocoder and implement its functions, also in experimental and original way.
What do you suggest?
Many thanks to all in advance for your reply!
Best regards.
Re: [Doepfer_a100] Modules for increasing VOCODER functions
2010-08-22 by york luethje
Hi!
The great thing about the Doepfer vocoder is that the individual analysis bands
are so easily accessible. So why not add some VCA's and LFO's and modulate some
of the analysis bands? Or go wild, get 16 VCA's and LFO's and do it to them all!
Get a multiple and split one of the analysis bands into several synthesis
inputs; conversely combine several bands into one with a mixer. Inverters are
nice, so is a joystick to control some aspects.
Grab a ringmodulator or some wavefolder and do unspeakable things to one of the
helpless analysis bands.
You said that you have no need for an oscillator but the voiced / unvoiced
detector needs some noise inputs as well (can be external too, of course).
As for filters, a vocoder is basically a filterbank on steroids so I'm not sure
how much mileage you'd get out of a dedicated unit. Otherwise, filters are
great, can't have enough of them.
Have fun!
York
To: Doepfer_a100@yahoogroups.com
Sent: Sunday, August 22, 2010 2:16:15
Subject: [Doepfer_a100] Modules for increasing VOCODER functions
Hello
A-129\1
A-129\2
A-129\3
A-129\3
A-129\3
A-129\4
A-129\5
A-119
function?
For example:
mic amp....
Best regards.
2010-08-22 by Bakis Sirros
York is right.
as the analysis module (A129/1) sends cv's to the cv inputs of the synthesis module(A129/2), you can basically use whatever dc-coupled module you can think of, to mangle the cv's coming from the analysis module.
for example, you can even use a Doepfer A187-1 vc-DSP (which is dc-coupled), to manipulate the cv's coming from the A129/1 !
Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. vu-us. com
--- On Sun, 8/22/10, york luethje <ybl@yahoo.com> wrote:
Subject: Re: [Doepfer_a100] Modules for increasing VOCODER functions
Date: Sunday, August 22, 2010, 10:28 AM
      Hi!
Have fun!
York
Hello
A-129\1
A-129\2
A-129\3
A-129\3
A-129\3
A-129\4
A-129\5
A-119
function?
For example:
mic amp....
Best regards.
Re: Modules for increasing VOCODER functions
2010-08-22 by selfoscillate
some vocoders have a nice feature called "pause stuffing".
it can easily be replicated by patching three additional
modules like this:
http://www.selfoscillate.de/forumfiles/pausestuffing.jpg
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "ggtonet" <cromocaone@...> wrote:
> Hello
> A-129\1
> A-129\2
> A-129\3
> A-129\3
> A-129\3
> A-129\4
> A-129\5
> A-119
> For example:
> Best regards.
Re: [Doepfer_a100] Re: Modules for increasing VOCODER functions
nice idea! thanks Ingo!
www. DiN. org. uk
www. vu-us. com
--- On Sun, 8/22/10, selfoscillate <synaptic_music@yahoo.com> wrote:
Subject: [Doepfer_a100] Re: Modules for increasing VOCODER functions
Date: Sunday, August 22, 2010, 4:17 PM
modules like this:
best wishes
ingo
> Hello
> A-129\1
> A-129\2
> A-129\3
> A-129\3
> A-129\3
> A-129\4
> A-129\5
> A-119
> For example:
> Best regards.
2010-08-23 by Florian Anwander
Hi Ingo
If I understand it right, it provides some amount of the carrier signal
to the modulator chain. This carrier2modulator signal is compressed by
the incoming modulator signal (e.g. voice in the standard usage).
What I do not understand: this "pause signal" will be assumingly a very
wobbly sound, because the changes of overtone will be exponentiated bye
the self vocoding. Does it really sound good?
And @ggtonet:
Additionally to the other recommendations I'd like to add:
You should have compressors for the Vocoder. At least one. You can use
an external compressor or a combination of A175 Inverter and A130 linear
VCA as used in Ingos example.
Then I suggest a second A119 Ext-In, to reassure, that your carrier
signal is at a correct level. Typical studio line signals have lower
level than the internal signals of the A100. If you don't adopt the
signal level, you will have a bad signal to noise ratio.
Also I recommend a high pass filter. There are at least two usages for it:
1.) Mix a little bit of the high frequencies of the original modulator
signal to the output. This increases the understandability of vocoded
speech extremely (I have made the well know example for the A129
http://www.youtube.com/watch?v=pLRgjzEjFkM with this trick).
2.) taking away a littlebit of the bottom end of the modulator input
signal before the (recommended) compressor increases the overall "power"
of the final signal.
Florian
2010-08-23 by Bakis Sirros
hi Florian,
for the Florian Schneider electronic poem, you have used the A129 vocoder, right?
you have indeed achieved very clear results.
best regards,
Bakis.
www. DiN. org. uk
www. vu-us. com
--- On Mon, 8/23/10, Florian Anwander <fanwander@mnet-online.de> wrote:
Subject: Re: [Doepfer_a100] Re: Modules for increasing VOCODER functions
Date: Monday, August 23, 2010, 5:54 PM
      Hi Ingo
And @ggtonet:
Florian
2010-08-23 by selfoscillate
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> Hi Ingo
hello florian,
it can sound really good, but not with all signals.
i like to use the pause stuffing with pad sounds as
carrier and another synth sound as modulator.
the pad sound is sustained even without the presence
of the modulator, and changes dynamically when the
modulator starts playing. not the standard use, but fun :)
as always with vocoders, the result is heavily dependent
on the used signals. of course the self vocoding will
change the overtones of the modulator at the output,
but from my understanding that is intentional.
this way the vocoder will provide a vocoded sounding
signal even when the modulator is silent.
some time ago i used an electro-harmonix vocoder which
offered pause stuffing. i don't know if ems uses a
different term or method, but on the electro-harmonix
it worked that way. i think it also had a compressor
built-in to tame the wobbliness. of course my patch is
only the "simple" version. i didn't want to make things too
complicated, so i kept it as simple as possible, only
to show the working principle. it can be improved with an
additional compressor patch, but i found that this is not
always necessary, as long as you use synth sounds only.
with a human voice this is of course a different story.
a human voice really needs compression to give good results.
best wishes
ingo
> I don't really understand what's the auto pause stuffing, theorically I have
> an idea but I don't have one about how it should be sound.....
if your goal is voice processing only then the
pause stuffing patch is probably not very useful.
as florian posted, the most important thing for
voice processing is the proper condition of the
voice signal.
best wishes
ingo
Hi Bakis
Yes, it is the A129/1 and 2. The carrier source was my Roland JX-3P. I
spoke in a Sure SM58 through my Yamaha console; and recorded it to an
Fostex 280 cassette tape (or maybe I already had an ADAT). The playback
signal was split then into a direct signal and a side chain signal. The
direct path went in one channel of a Yamaha CL2020 compressor, then in
the EQ of my mixer, where the higher frequencies were increased, and low
frequencies dropped. Then from direct out of the desk again in the other
channel of the compressor. The output of the compressor was fed into an
ashley noise gate. The side chain signal I mentioned before was fed into
the sidechain of the noise gate. The output of this signal then was fed
into the A119.
Then again the signal was split:
One path direct into the modulator input of the A129.
The other path into the A122 Highpass.
The output of the Vocoder and the output of the A122 went into a A138
Mixer and from there they were recorded to DAT.
The A122 is set at avery high frequency, so that it sounds like a whisper.
A you can see, if I do vocoder sound, then a lot of effort goes into the
quality of the microphone signal.
Florian
2010-08-23 by Mort Cinder
Thank you all for your suggestion
really nice hint here!
I'm convinced about a second A-119, one for carrier and one for formant.
Also the high pass filter is a nice idea but if I had not bad understood the
voice through the filter will be directly to the output and not in the
A-129\2 mixed with the usual formant.... and about compressors I'm using
just one external compressor for the voice. Do a second compressor will be
usefull for the carrier in your experience?
Increasing the understandability of vocoded speech is one of my global
purpose.
Here you can listen some of my vocoders (but it was not made with doepfer, I
had not it at that time):
http://www.youtube.com/watch?v=NyAzVod64YY
indeed.
many thanks for the detailed info!
www. DiN. org. uk
www. vu-us. com
Date: Monday, August 23, 2010, 10:49 PM
      Hi Bakis
into the A119.
Florian
second A119 for an external (not from A100 vco's) carrier would be, of course, needed.
also, yes, the high-pass filtered signal (from the modulator/voice) would go directly to the final output, mixed with the vocoder output.
compression would be useful for your modulator voice input mostly.
not very useful for the carrier signal, unless your carrier signal is quite wobbly and with many peaks...
www. DiN. org. uk
www. vu-us. com
Date: Monday, August 23, 2010, 11:15 PM
purpose.
2010-08-24 by Florian Anwander
Hi Mort
 > will be usefull for the carrier in your experience?
A compressor for the carrier is recommended in the case, that the
carrier is not a signal with continous level. Examples: a strings or
organ sound is continous, it does not need compression. A sequence of
strummed guitar chords has many different levels and compression is
recommended.
 > purpose.
I recommend NOT to use very modulated or chorus'ed sounds as carrier. To
My experience a single VCO sound with a Pulswave of 75% Pulswidth but no
PWM is perfect. If you want to have chorus like effects, then put the
chorus effect only on the voiced part of the signal, but not on the
unvoiced part. The easiest way to achieve this will be again the
highpasss filter, that should be mixed with the vocoder sound after the
chorus.
Florian
2010-08-24 by Mort Cinder
Thanks Florian for sharing your knowledge.
I thought that maybe buyng the HP filter only for the use you mentioned in
the vocoder is a little wasted....(?). If I just have one in the doepfer
synth architecture I can use it also for the vocoder in the way you
explained: do you think it will worth the purchase only for this use?
I can also use the high pass output inside the A-129\1 for this purpose or a
sampled HPfiltered version of the formant..... in the first case I lost the
modulation of the filter but I think it is in a little range, in the second
case I just have to sinchronizing two recorded audio....
But I don't know if the result is the same you have in mind. I tried one
time the HP output of the A-129\1 but I was experimenting really a lot at
that time for have a right perception of the result! I'll try soon
again.....
My best regards.
2010/8/24 Florian Anwander <fanwander@mnet-online.de>
> Hi Mort
> recommended.
> > purpose.
> chorus.
> Florian
