Re: a-155
2010-08-02 by Guy
Hi Rene, I have no idea if these are the proper switches indeed, but I can tell you the Miyama switches (and most likely the other one too) are not exactly prime examples of decent quality. Good switches are expensive. Try C&K, NKK, or Mountain. _g --- In Doepfer_a100@yahoogroups.com, Rene Verdult <reneverdult@...> wrote:
> > hello group, > > I have just filled my first 9U rack (and very very happy with it!!) but my > latest addition is giving me some problems. When i received the A-155 together > with my A-154 expander I noticed the toggle switch that selects the range (1v / > 2v / 4v) was a little 'wonky' like it had sustained a little damage. Now when I > switch to 4v from any of the other ranges it doesn't switch to 4v, but toggeling > back and forth sometimes helps, sometimes not. Also sometimes just slightly > touching the toggle switch will make the pitch 'wander'. > > As i am ordering parts for a DIY project soon, I thought about getting a > different toggle switch for it, but i am not sure if that is wise. Should I just > send it back to Schneiders (it's only a few weeks old)? Can someone confirm > either one of these would work if I did it myself? > > http://www.banzaimusic.com/Miyama-SPDT-on-off-on-Toggle.html > http://www.conrad.de/ce/de/product/701153/KIPPSCHALTER-TA103F1 > > thanks very much > Rene > > > > > > [Non-text portions of this message have been removed] >
