Darktime suggestion
2009-12-07 by Florian Anwander
one short suggestion for the Darktime: The reset/stopswitch per step too narrowed down in its function. I suggest that this switch should feed to trigger/gate busses which is available at a 3.5mm socket at the rear (similar to the A155). These busses can be used for accent control or other triggers (drum sounds,...). There should be a single switch in the lowest row, which selects one of these busses for the corresponding stop/reset function. Florian
