Doepfer
A-185-2 problem
A-185-2 problem
2008-09-21 by noiseoutsourced
I'm baffled at the solution to this problem.
ok, here goes.
I have a total of four A-185-2 Precision CV adders in my Monster case for use primarily as
range switches for a pair of PlanB Model-15's and Livewire AFG's.
The AFGs reside on the lower left bus board while the Plan B's reside on the bus board
directly on top.
When i plug the A-185-2's into the bottom busboard their negative positions only work
with one switch (and of the 4, but only producing 1 octave down, not 2,3 or 4) the positive
positions push the range up as is should with no problems. The A-185-2's on the bus
board above that work just fine. When i swap the top units with the bottom units the same
problem persists. so its not the two new A-185-2 units. Both +12 and -12 LEDs are
brightly lit on both bus boards. i even took out the AFG modules to see if it was a MA
overloading issue and the problem was the same.
I made sure all of the connections from the power supply to the bus board were not loose.
ummm, any help? :(
-bobby
Re: A-185-2 problem
Never mind.
In my infinite wisdom I remembered to RTFM.
Seems I wasn't as daft the first time around and took off the jumpers on my first pair of
A-185-2 units. Not so smart this time.
Jumpers removed. Units working properly now.
Sorry for the waste of bandwidth!
-bobby
--- In Doepfer_a100@yahoogroups.com, "noiseoutsourced" <mailinglist@...> wrote:
> ok, here goes.
as
> directly on top.
positive
same
loose.
> ummm, any help? :(
> -bobby
