> Nancy, if you are looking for neutral, archival b/w prints that
> don't use ANY color inks, the
> 1800 is your printer....that is, using Paul Roark's workflow.
> http://www.paulroark.com/BW-Info/R1800.htm
> check it out before you decide to relegate the 1800 to the back
> burner for color glossies
> only.
Hi All -
I don't post too often, and this, in no way, is meant to criticize or
otherwise
be critical of the work and other interesting methods so many of you
are using UT-3D, Ebony-7,
or any other inks & combinations. It's always inspiring to read and
appreciate how much energy
is being devoted to the black and white print. And, I might add, in
my opinion, the digital
carbon pigment inks have finally surpassed the quality of silver
prints -- at least on matte papers.
That said, it doesn't appear that a lot of people on this group are
using Jon Cone's piezography inks,
and I'm not connected in any way with him or his company, other than
having used them first
in an Epson 3000 (beautiful carbon prints when the printer was
working correctly and
the inks were not clogging), then on an 1160 with a CIS, through the
next iteration or
two of his inks (also with a lot of time used in clearing clogged
heads), and finally in my 2200,
which I originally beta tested for Epson.
When the 2400 arrived even better color, I started using Cone"s
latest K7 inks in the 2200. They are stunning
and I've not had a single clog, even after non-use for a full month
this summer. Apparently, the
carrier solution is a close chemical relative to anti-freeze, which
has a
very slow rate of evaporation, and therefore doesn't dry up and clog.
It's not a solvent, since carbon pigments are in
suspension, not dissolved, and is pretty much the same as in the
Epson Ultrachrome K3 inks. This, at least, has been my
experience with both the 2200 and the color in the 2400.
The issue of warmer and cooler prints, for me, has been resolved by
purchasing some Sepia
carts which can be inserted in place of any of the black set
positions. By inserting sepia in the No. 4
or 5 position, I've been able to print a warmer black. One could put
Selenium into the mix and
cool it down or do combinations of color tone. All are
interchangeable without flushing, and in fact
are exactly compatible with one another when using the QTR rip.
Of course the newest issue we all face is the Epson law suite and the
ruling by the FTC over use of
3rd party cartridges. Jon has been selling his desktop printer stock
at deep discount before the cutoff date
(sometime in December). Fortunately I have several sets of inks.
Although not advertised, the Cone cartridges
have a small Silicon stopper on the top (after you snap apart the
cart), and can be easily refilled.
So I purchased 4 ounce bottles of the inks, and should be able to do
my own refills for quite a while.
This, in preference to obtaining another CIS, which would be good,
other than my printing needs
these days, are not much in quantity.
Finally, a word about the 2200, which nobody has mentioned. Aside
from the standard paper feed, which skips
occasionally, and mostly can be corrected by rubbing the rubber
rollers with a damp rag -(you can see them if
you look straight down into the top paper feed.); the 2200 has two
other paper feeds - one for paper rolls, and the
other, which is terrific, feeds straight through the printer - back
to front, and will handle printing on very thick paper -
even cardboard. Someone mentioned that it would even print on
Masonite, although I wouldn't try that. A lever
with several positions raises the heads to compensate for the
different thicknesses. It works very well, and I guess
was too good to be true, because as far as I know none of the desktop
printer since then has such a paper feed.
anyone know if that's actually the case?
Clay Price
Clayton Price Photographer
www.cpricephoto.com
clay@...
212 929-7721
