Digital BW, The Print
MIS UT-FSN Inks...Magenta cast!
2007-12-09 by Andre Vallejo da Silva
I print with this inkset on a 1160. Shouldn't it be neutral? All
prints on all papers come with a magenta cast when printed from PS or
QImage. Strange enough,when I print from QTR,with a curve I linearized
from one of this magenta prints(using printfixpro),it prints
neutral,but then the blacks are blocked and the image dark...
Any thoughts?
André
RE: [Digital BW] MIS UT-FSN Inks...Magenta cast!
2007-12-09 by Paul Roark
Hi André,
There have been occasional problems with the blended inks (carbon blended
with cyan and magenta or blue) like the UT-FSN from settling if the printer
has not been used for a while or if a CFS is used and not agitated, from ink
color batch differences, and from simply the differences among papers.
Getting an inkset to print “neutral” is always, of course, a compromise
because each coating will print somewhat differently.
With the UT-FSN, the dark gray inks are more green/less magenta than the
light gray inks.  So, at least with a QTR, you have some control of the Lab
A axis (green-red/magenta) by how you write the curves.  For example, to
reduce a magenta cast, you can use more of the dark grays and less of the
light ones, being limited mostly by when the dots become visible.  With an
1160, you should have a fair amount of latitude here.  Linearization should
not result in blocked shadows and a dark print, however.  Be sure system was
linearized at the same resolution that it’s being printed.
My first guess as to cause is that you’re seeing some settling or ink batch
differences.  Pigment inks need agitation.
Paul
www.PaulRoark.com <http://www.paulroark.com/>
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Andre
Vallejo da Silva
Sent: Sunday, December 09, 2007 8:23 AM
Subject: [Digital BW] MIS UT-FSN Inks...Magenta cast!
Any thoughts?
André
Re: MIS UT-FSN Inks...Magenta cast!
2007-12-10 by Andre Vallejo
Thanks Paul, I took you advice and was able to solve the problem in QTR.
In the meantime CD solved my PFP problem,so I can say that after the
Police show yesterday (they're old,but sturdy),it's a good end of weekend...
Best,Andr\ufffd
Non-image marks
2007-12-10 by Peter De Smidt
A number of my R2400 8x10ish prints on 8.5x11" paper have an
approximately 1/2" square area of ink marks just outside the image
area.  The area is about 1 " from the last end printed and approximately
3/4 inch in from the edge of the paper on the "button" side of the
printer.  It consists of smallish darkish specks.  This isn't the ink
blobs that I've had a few times.  At first glance it looks like a
smudge.  Anyone have an idea as to what this could be and what might be
done about it?
RE: [Digital BW] Non-image marks
2007-12-10 by David Whistance
Although it is difficult to tell from a description it sounds like a roller
mark.  Try cleaning the rollers and see if the marks disappear.
David Whistance
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Peter De
Smidt
  Sent: 10 December 2007 04:03
  Subject: [Digital BW] Non-image marks
  done about it?
Re: [Digital BW] Non-image marks
> roller
> David Whistance
Thanks David.  What's the best way to clean the rollers?  A paper towel
with Windex?
Try a paper towel with water first, then move on to windex if that doesn't
work.
David
Smidt
  Sent: 10 December 2007 12:46
  Subject: Re: [Digital BW] Non-image marks
  > roller
  > David Whistance
  with Windex?
2007-12-10 by Eric Neilsen
You can spray it right onto a plain piece of paper too. Just make sure that
you don't get it so damp that it falls apart on transport.
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
http://ericneilsenphotography.com
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of David
Whistance
Sent: Monday, December 10, 2007 7:02 AM
Subject: RE: [Digital BW] Non-image marks
work.
David
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>
Smidt
> roller
> David Whistance
with Windex?
