Digital BW, The Print
Problems with PrintFixPro
2007-12-09 by Andre Vallejo
I bougth the PrintFixPro in order to generate profiles to my MIS FSN
inks and 1160 combo. I downloaded the upgrade to the Spyder3print
software,I print and read the HQ chart,it saves the xml file,but when it
tries to build the profile, it hangs about 2/3 of the jobs...If I use
one of the sample xml included in the S3P,it builds the profile all
right. Has it happened to anyone? C.D. ?
Andr\ufffd
Re: [Digital BW] Problems with PrintFixPro
2007-12-09 by CDTobie@aol.com
it
It takes much longer to generate a B&W profile than a color one. Don't
quit when it "hangs", just go get a cup of coffee, and give it time to
process. It should be able to finish the job if the inks are reasonable
for RGB driver usage. Never tested the FSN inks, so I can't comment on
that...
C. David Tobie
Product Technology Manager
Digital Imaging & Home Theater
Datacolor
CDTobie@...
www.datacolor.com/spyder3
________________________________________________________________________
More new features than ever.  Check out the new AOL Mail ! -
http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003
Re: Problems with PrintFixPro
2007-12-10 by Andre Vallejo da Silva
Thanks,C.D.,it worked. Took 25 minutes to build,but did. As it took
about 5 seconds to build the color one,I could never figure it out,
but then...got me a good profile,and the magenta cast is also gone.
Good.Very good...
Andre
> it
> that...
> C. David Tobie
> Datacolor
> CDTobie@...
Re: [Digital BW] Re: Problems with PrintFixPro
2007-12-10 by CDTobie@aol.com
Good.Very good...
You must have a fairly slow computer for it to take 25 minutes, but the
result is what matters. Glad it worked for you.
C. David Tobie
Datacolor
CDTobie@...
That's the funny part.It's not slow.Not the fastest(it's An Athlon 64
bits with 2GB RAM and a fast video card) but I use for Photoshop and
Premier video editing with no hassles...but then software is a strange
animal...but as you said the result is what matters,and the profile is
very good. Go figure...
André
> Good.Very good...
> C. David Tobie
> Datacolor
> CDTobie@...
