Digital BW, The Print
Re: [Digital BW] Re: UT3D ink + QTR instructions
2007-01-01 by CorrPro96@aol.com
In a message dated 1/1/2007 5:44:35 PM Eastern Standard Time, goch@...
writes:
Oops! I started out thinking about doing this with QTR, but in writing the
message I decided
it might be simpler to stick to the Epson driver.
I use QTR too, so help with that and UT3D would be more than welcome!
Indeed, one of my problems is probably that there are too many variables for
me to get my
feet on the ground.
Reminds me of someone trying to start out in the chemical darkroom printing
on 5 different papers, using 3 different developer formulas and hasn't yet
learned what a fine print looks like.
Richard (Brooklyn)
2007-01-02 by Joost Horsten
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, CorrPro96@...
printing
hasn't yet
> Richard (Brooklyn)
Hi Myron,
Richard sounds a bit sarcastic here, but he has a point. QTR and
(from hearsay) PrintFixPro are both excellent tools. Both have there
pros and cons, but for when starting with B&W printing those are not
so relevant. Important is that they require quite a different
workflow. From own recent experience I know it takes some effort to
get that workflow right. So, like Richard implicitly seem to suggest,
select one or the other and get yourself acquinted with it. From what
I read in this forum, probably PFP could be the better starting point
for you, given the fact that you already own it and use UT3D inks.
But if you decide differently, I'm happy to help you out where I can.
Joost
2007-01-02 by CDTobie@aol.com
In a message dated 1/1/07 2:12:59 PM, j.h.j.h@... writes:
> Your subject says "QTR", with which I might be of help (just having
> gone through this process), but your post talks about Printfix Pro (no
> experience with that). I assume you mean the latter.
I assume he means both, since you can use PrintFIX PRO to export measurement
data to   linearize QTR, and to build CreateICC 'profiles'.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
In a message dated 1/1/07 5:44:26 PM, goch@... writes:
> message I decided
Then my first set of instructions (simple as they are) would be the ones to
begin with. That and the PFP2 help should be all that you need.
