Digital BW, The Print
Comparing prints for that "3 dimensional quality"?
2006-11-24 by CDTobie@aol.com
In a message dated 11/23/06 10:32:20 PM, tyler@... writes:
> Amadou's comments about resolution are very important for dimension in
> photography on
> paper, and I find too much USM can kill all depth very quickly.
I was reading the various comments on this thread, and pulled out a sample
print I made the other day, as it had struck me has having that illusion of 3d
previously. It was an environmental portrait printed on an   R220 with Paul
Roark's UT-3D inks, through the RGB driver, via a PrintFIX PRO 2.0 profile. The
Italian chef in the image was in the tightest focus, and had also been optimize
for tonal range, etc, in the image editing stage. Next to him and a bit
further back, without the direct light, and not in the zone of tightest focus, was
a his rack of knives; a telling detail for a chef, but not the main focus of
the portrait. The chef had that illusion of 3d that can make an image jump off
the page; the background, and the knives, did not. I considered this an
effective combination, and had never really ponderd it before. Tonal range and focus
both contribute to the effect.
But I next had to check off another item on the list: inks. I dug around
until I found a copy of the same image printed on an Epson k3 printer, with OEM
inks, and (again) a PrintFIX PRO2.0   profile. So the main difference here was
instead of a number of tinted gray inks interacting to form the tones here, it
was predominantly one light gray for highlights and one dark gray for shadows,
with supporting roles for the color inks as toners. I rather expected that
the relatively fragile illusion of 3d would be clearly present in the monochrome
inks image, and missing in the OEM inks image; but, to my suprise both images
held the illusion in the same areas (subject, and backlit stemware to one
side) and did not hold it in the same areas (back wall and knife rack). So, at
least in this case, the "thinness" of OEM neutral printing did not effect the 3d
illusion, or show (to my eye, at 24 inch examination distance) any real
difference in detail, smoothness, or color noise. Gosh, you guys almost had me
convinced. <G>
Regarding Tyler's comments about detail and USM: the image in question was a
full frame Canon DSLR capture with an L series lens (stepping down in either
of those areas could well have cost   the image that effect), and was sharpened
only the amount that I sharpen all my images coming through CameraRAW, no
output specific sharpening. If it had been even a bit out of focus, and I had
tried to compensate with sharpening, I'm sure that 3d illusion would have been
absent, as it was in areas of the image in slightly softer focus.
C. David Tobie
Product Technology Manager
ColorVision Business Division
DataColor Inc.
CDTobie@...
www.colorvision.com
