Digital BW, The Print
ICC-Profile controlled MIS UT3D printing
2006-11-22 by CDTobie@aol.com
In a message dated 11/22/06 4:40:56 AM, j.h.j.h@... writes:
>  I'm currently setting up a set of QTR curves
> for the UT3D inkset, including some split tone curves, and I'd love
> to experiment in this direction.
Thats an interesting area. While I find the most direct way to work with
tonality in B&W to be standard inksets, and PrintFIX PRO 2 profiles; it is also
possible to profile the MIS UT3D inksets with PrintFIX PRO 2 right through the
OEM driver, no RIP required. This works a bit differently than with full gamut
inksets, but it offers full control of the UT3D gamut, with live preview of
the adjustments in Photoshop, so that you can create any tint or cross-tint
within the inkset's gamut visually, on screen, then print this same result with
the UT3D inks and paper that the profile was created for. Lovely sepias, carbon
tints, and cross-tints.
I should note that the UT3D neutral results, simply profiling them with PFP2,
and printing a neutral or grayscale image to them, is a beautifully smooth
tone just a hair to the carbon side of neutral, and, being a toned grayscale
inkset, it has smoother microscopic results than with OEM inksets. Tyler will be
interested to see the gray ink smoothness of these prints from printers
starting below a hundred dollars; the R220 I'm testing on was $99 at Staples.
So any PrintFIX PRO owners who were wishing they could test the new B&W
capabilities, but who lack a "two-gray" printer to test with: dig out that old
R200, 220, 260, 300, 320, 340, 380, or RX500, 580, 600, 620, or 700; or any other
printer the UT3Ds will run on (or buy a new one for under a hundred dollars)
get a set of UT3Ds to match, and give it a try. I'll be interested to hear your
results.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
RE: [Digital BW] ICC-Profile controlled MIS UT3D printing
2006-11-24 by Paul Roark
CDTobie wrote:
> ... it is also possible to profile the MIS UT3D inksets with
> PrintFIX PRO 2 right through the OEM driver ...
> or cross-tint within the inkset's gamut visually, on screen,
> then print this same result with the UT3D inks and paper
> that the profile was created for...
I downloaded the 2.0b5 beta and gave this a try on the 220.  It does,
indeed, seem to work.  I used the 225 target without the special B&W target.
It produced a good "neutral" print with tones that went from the paper white
to the black tone. The soft proofing seemed to work also.
I haven't experimented with this very much, but it looks like, for example,
on Premier Art's rather cool Matte BW paper it's easy to get a cool tone
with a Lab b of -5, or a medium warm print with Lab b a bit over 3 in the
midtones just by adjusting the color balance of the RGB file.  Split tones
ought to be very easy.
Limiting factors appear to be the small gamut of the inkset and distortion
of the ramp if the color balance sliders are pushed too far.  The soft proof
give visual feedback as to when the ramp is getting distorted.
If one wants a neutral print, it appears a grayscale file can also be
printed with the profile.
While this approach does not seem to be able to reach the limits of the
inkset the way manual profiling can, it looks like anyone with the program
will be able to profile papers and achieve very useful tones and split tones
with ease.
Congratulations David.
Paul
www.PaulRoark.com
Re: ICC-Profile controlled MIS UT3D printing
2006-11-24 by Joost Horsten
Hi David,
Sounds very interesting. I'd be interested to give it try, but I just
invested in an Eye-One. I assume the PFP software doesn't work with
that. Right?
Joost
Re: [Digital BW] ICC-Profile controlled MIS UT3D printing
2006-11-26 by robert49brake
does,
B&W target.
paper white
> to the black tone.
I'm very happy to see this thread.  I have a recently purchased PFP
that I've been using very happily to profile my R220 for MISPRO and
my color papers and will have some time in a few weeks to do my B&W
R220 for UT-3D, but I have a few questions concerning the UT-3D
inkset that I have.
I bought a goodly amount of the UT-3D a number of months ago when I
believe there were still some issues with the QC of the inkset.
Essentially I only pulled a couple of prints with the set and then
had to set it aside until now.  The first was a generic test print
with a very high tonal range pulled on Epson Enhanced Matte and then
on Crane Silver rag using Paul's profiles and I was really taken with
the range and the depth of the blacks.  The second print I pulled was
a mostly midtone image using the pre-made profiles and I ran into the
problem of a much cooler than nuetral print.
To make a long story short, do you think profiling with PFP, using
the method mentioned above with 2.0 (which is still in Beta?) or the
manual method will get me back to nuetral (and for a project where I
need very warm prints) with the inkset I have or will I need to
change some of the inks.  From following this forum I believe I have
the inkset that went out right at the change of QC methods but proved
to be problematic with the ready made profiles.  (I have 4oz bottles
of the 5 inks other than Eboni and PK and I'd like to be able to use
some or all of them if possible.) I'm perfectly willing to get new
inks where necessary but I have some logistical problems and
currently for me, weeks are the norm for orders rather than days and
that situation will get even worse after December.
Thanks, Robert
2006-11-26 by CDTobie@aol.com
In a message dated 11/25/06 11:00:26 PM, robert49brake@... writes:
> does,
> B&W target.
> paper white
> > to the black tone.
Yes. Thats all that should be necessary with the UT3D inks, the extended
grays target is for color sets, not for graysets, which are automatically
"extended"...
> inkset that I have.
There is a good chance that the PFP2 profiling process will cover any
variation issues with the inks.
> Thats exactly the type of thing PrintFIX PRO is good at controlling... if the
variation was in some other factor it could be problematic. But what is
challenging in manufacturing such insets is the tonality, and what PFP is best at
controling is that same factor, so there there is a good relationship between
the two; it allows the ink company to produce inks with less difficultes, and
allows the end users to get the precision and control they desire.
> the method mentioned above with 2.0 (which is still ,in Beta?) or the
Should be able to tint the images warm in Photoshop, and print through that
same neutral PFP2 profile to get what you want for tints. Use the PFP profile
in Custom Proof Setup so that you can tint visually, and see what tints are in
the gamut of this inkset, and what tints are not. General tints in Photoshop,
done without the softproof function on, don't work for such inksets.
You may have to reprofile once you use these inks up and purchase new
supplies, if there is significant variation. But thats only a ten minute process.
C. David Tobie
ColorVision Business Division
DataColor Inc.
CDTobie@...
www.colorvision.com
In a message dated 11/24/06 1:43:16 AM, paul.roark@... writes:
> to the black tone.
Yes, thats an appropriate target choice for this use; and it should result in
a good paper white to ink black ramp as the base profile...
Yes, I've seen problems with softproofing gray inksets before, since the
softproofing tools expectations are very different from the inksets results, but
here is seems to be close enough to printed results to show you the tints you
are defining, and to show you where gamut limits are reached; if you try to
tweak towards colors that the inkset does not contain, the softproof stops
changing, or stops changing in the section of the ramp where you've run out of
gamut, which is just as it shoud be...
Yes, as long as the ink/paper gamut contains all the tones in the ramp, you
can cross to your heart's content, and see just about what you'll get right in
the Photoshop softproof.
Precisely; the color sliders in PFP that can be used to define tints in color
inksets are not the right way to do this with gray inksets, they would have
to be pused too far before the effect was achieved, and pushing them too far
can cause undesired effects, so my recommended way to tint UT3D prints is via
Photoshop adjustments with the PS softproof on. You can save your adjustments in
Photoshop and apply to other images.
>   The soft proof
Yes, the softproof pretty well indicates when you are reaching "out of
bounds" conditions for the inks gamut.
Identical results from a grayscale file or a neutral RGB file.
> with ease.
It might well be able to nudge out into the corners of the UT3D inkset's
rather unusual gamut if you use just the right Photoshop tools to get there, but
frankly I don't have much use for distinctly blue, or distinctly red prints
anyways. I'm most interested in flexible ramping in the carbon to cool range, and
thats exactly where these inks are most comfortable: good neutrals, a range
of carbon to sepia tones, plus slight cools.
> Thanks, Paul. We both know this capability has been a long time in the works;
its too bad it has to finally appear quite so late in the PrintFIX PRO 2.0
development cycle. But B&W printing fans will be very pleased to see that the
range of options for previewable, ICC-based B&W printing options is growing as
we go along. I would expect to see them become even more flexible and
broadbased as we move forward.
C. David Tobie
DataColor Inc.
CDTobie@...
www.colorvision.com
