[Fwd: Re: [Digital BW] Are inkjet pigments opaque or translucent?]
2006-11-22 by Ernst Dinkla
elauq wrote: > I printed a yellow patch and then ran the paper through a second time > and overprinted with a cyan patch. The reverse was also done, first > cyan then yellow. A third paper had one patch with 100% yellow and > 100% cyan printed in one pass. All three looked different. > > It seems to get the correct blend of two colors, or grays for that > matter, each dot must be printed adjacent to another but not on top of > one another. Dye inkjet inks and pigment inkjet inks are somewhere between transparent and opaque. Like all other inks in fact. Even thick solid silkscreen inklayers have some transparency, possible exception the metal inks and ironoxyde based (opaque) black. In CMYK color printing, subtractive mixing is the base for color rendering. The highlights where no color overlap happens is in fact the problematic part of CMYK mixing. One of the reasons why CcMmYK inksets are working better and even increasing the gamut, the larger cm dots with more overlap increase subtractive mixing compared to smaller CM dots with lots of white paper in between. Even with the more transparent dye inks you will see differences between color mixing samples when Y and C are used in reversed orders. Partly because the ink penetration in the coating differs between the two samples, partly because the primaries are not selective in their spectral filtering. So subtractive mixing (overlapping dots) isn't the problem but the less than ideal hue and transparency characteristics of CMYK inks are the problem. Anyway it is still better than additive mixing with RGB inks on paper, dots next to one another, the light you can get through the RGB dots and back isn't sufficient, the dot registration has to be perfect too. That kind of mixing is good for CTRs and LCDs. Met vriendelijke groeten,Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
