Digital BW, The Print
Are inkjet pigments opaque or translucent?
2006-11-22 by elauq
I printed a yellow patch and then ran the paper through a second time
and overprinted with a cyan patch.  The reverse was also done, first
cyan then yellow.  A third paper had one patch with 100% yellow and
100% cyan printed in one pass.  All three looked different.
It seems to get the correct blend of two colors, or grays for that
matter, each dot must be printed adjacent to another but not on top of
one another.
Re: [Digital BW] Are inkjet pigments opaque or translucent?
2006-11-22 by Steve Clark
CMYK printing employs subtractive color theory whereas RGB is
additive color theory. This requires that the inks be transparent
since the light passes through the inks, which act like a filter,
hits the paper and reflects back up to your eye.  Theoretically, cyan
is white light minus the red, yellow is white light minus the blue,
and magenta is white light minus the green.  That said the
transparency of inks is not always 100% pure. I think the yellow is
the worst offender. I'm not surprised that your test green looked
different. My guess would be that the one with the cyan on top would
be a bluer green whereas the one with yellow on top would be less
blue-green.
Clark
> one another.
