Digital BW, The Print
Suggested Monochrome Inkset for Epson 2200?
2006-11-13 by John Hollenberg
I have an Epson 2400 and an Epson 2200, and have decided I would like
to try a monochrome inkset in the 2200.  Previous experience:
currently own both QTR and IJC.  About a year ago I used my Eye-One
Pro to make a profile for Epson Velvet Fine Art for QTR on the Epson
2200 (UC inks).  Also made one profile for IJC as an experiment, can't
remember which paper.  Used QTR ICC-create to build a profile for the
ABW mode on Epson 2400.  Fairly happy with the results, but would like
to see how much better (if any) monochrome inkset prints would look to me.
In spite of all my reading on this list, I haven't figured out what
inkset would be best for me to try.  Don't plan to print sepia, would
use subtle toning if not printing a straight neutral print.
Possible choices: Cone K7, MIS K4+, or ?
Any suggestions appreciated.
--John
Re: Suggested Monochrome Inkset for Epson 2200?
2006-11-13 by remkopieter
I have to make the same kind of decission using the 2200 i have for
B/W and buying a CFS with it. Or bying a new 2400 with or without CFS
with what ink?
I am also using a 1290 for mainly color images.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John
like
can't
like
to me.
would
> --John
2006-11-13 by Clayton Jones
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "remkopieter"
<r.p.de.graaff@...> wrote:
>Or bying a new 2400 with or without CFS with what ink?
If you won't be using the ABW driver and the K3 ink then is there any
reason to pay the extra money for a 2400?  Can't the 1800 be driven
with a RIP and whatever ink you want to put in it?
Clayton
Clayton,
I am missing your remark on the 1800.
At this moment I use the QTR RIP with standard Epson UC ink. This
works fine except I mis the possibility to print on glossy papers
although the No-black profile is after spraying more or less OK.
My thoughts were to buy the 2400 and use this with standard ink for
BW as well as color and dedicate the 2200 for BW with the MIS UT7
inks and QTR.
However when the results with the 2400 are better for BW i would
dedicate the 2400 for BW,look for the methode to use for printing BW,
sell the 2200 and use the 1290/1270 for color.
regards,
remko
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones"
any
> Regards,
> Clayton
RE: [Digital BW] Re: Suggested Monochrome Inkset for Epson 2200?
2006-11-13 by Paul Roark
This is the approach I'm using on my 2200:
http://home1.gte.net/res09aij/4K+.pdf
So far, I think the need for the rip is worth the inconvenience.  In fact,
as a few recent posts suggest, rips might even make for better prints.  For
me, it's mostly the ease of profiling and the inkset options they allow that
make the rips attractive.
The ease of profiling comes, in part, from the toners being very light (no
carbon in them).  I totally ignore density when changing tones.  The
linearization takes care of any impact.  There are also no cross-overs.  So,
all I deal with are 2 curves - LM and LLC (50% dilution of LC).  The profile
I use for my brightened PremierArt Matte BW paper involved only moving end
points and 2 internal points on 2 curves.  The profiling and experiments
took only 4 iterations from the neutral curve starting point.  That is way
faster than previous blended inkset approaches would have allowed.  The ease
of experimenting is part of what encouraged me to try the brightened paper
(the mainstream media), and the results appear superior - higher dynamic
range.  See my notes on this at
http://home1.gte.net/res09aij/PM_Split_Tone.pdf .
Having non-blended toners does reduce smoothness a bit, but because the LLK
is lighter than the UT7 light inks, the smoothness is not compromised.  The
limiting factor is the LC - which the 2400 uses.  So, with a 50% dilution of
LC used in this approach, we're smoother than the 2400.  In fact, with the
LLLK in the 2200, it has the lightest ink I've ever used in highlights -
very questionable whether it adds anything that one will see in a photo.
The other options such as glop or yellow ink might be more useful in the
yellow spot.  Note that with brightened paper, I'm not using any colors in
the lightest highlights.  That smoothes them out even more than the older
variable-tone inksets.  Frankly, in the 2200, dots are just not a problem
with this approach.
It's nice to not have to worry about mixing errors.  The only blend in the
basic approach is a 1:1 blend of LC and base.  As you may have noticed in
earlier posts, we've found that Image Specialists glop is essential if not
exactly the same as MIS base (and glop).  So, all inputs are available
commodities, although MIS's prices are good enough that there is little
reason not to use their services and more convenient sizes.   I think this
approach avoids the sources of the mixing errors.  Moreover, I've worked
with MIS to get them doing QC on the LK that they buy wholesale.  As such,
the MIS LK should be more consistent than other third party inks.   One can,
of course, mix the LLC just by purchasing 2 bottles of standard MIS inks -
Lc and glop - and pouring them together.
Note I'm using Epson UC LM now.   I'll be doing comparison fade testing to
determine which LM is the best.  One attraction to this approach is that it
opens up each position to competition.  I'll use the best ink form any
vendor.  Past tests suggest Epson UC LM is the best.  We'll see.
I think this basic approach will work on all Epson printers.  So,
transitioning from one printer to another will be easier and cheaper.  Even
the curves are not that different.  With a rip, comparing the full-on ink
limit initial test pages of different printers allows one to alter the ink
limits appropriately.  Once that is done, I found the basic curves transfer
over from printer to printer with little alteration needed.
The 3800 is a "large format" design, and I think it shows the future.  All
blended inks I've been involved with are unstable and experience tone
changes if the carts and lines are not regularly used or agitated.  This
approach avoids that problem.  I expect the 3800 to be the first real mass
market large format printer.  Dealing with the blended ink tone shifts on
that scale is something I will not do.
If we all end up going with the k3 approach, most of the inks we have on
hand will be useable even in that approach.  What I've basically done is
take the k3 approach and port it to other Epson printers - and improved it
by cutting the LC density in half.
In short, this is a variable-tone approach for virtually all Epson printers
that is largely compatible with where I see the mainstream going.
Paul
www.PaulRoark.com <http://www.paulroark.com/>
2006-11-13 by Mark Stracke
A set of Cone K7 inks costs $119.00. Not free, but not terribly expensive. Try it out and
see what you think.
 The profiles for the 2200 that come with QTR are *very good* - made by Cone & Co. You
might find that your files need adjusting if you were used to printing heavy since Jon likes
to make use of a subtle ramp from white to black. Viewing your files through the grey
matte profile that is installed with QTR will give you a pretty good idea of how your files
will print, if your monitor is profiled that is.
If you don't like the K7's it's easy to move on to something else. Put the Epson inks back in
and print a bit till the grey goes away and you're back at square one. I have found the K7's
to be very nice and haven't swapped them out since I first tried them.
Mark Stracke
2006-11-13 by john dean
This is the inkset I would suggest also for that printer. A group of
us met in NY and had a number of prints pinned up from the same file.
Those of us who had used the K6/K7 set had remarkably similar output
in regard to the greyscale ramp and resolution qualities, regardless
of what rip or what printers we were using. I really couldn't tell
what printers people were using. The little printers with K7 did as
well as the 9600s with Studio Print in my opinion, so did the 7000s.
The K7 inks would also be a really good choice for cfs set ups because
of their clog free nature. They are finely ground and well suspended
in the base.
And, as he said the other great advantage with a small printer is that
you can pull them out and put Ultrachrome in right behind them for
another job, then go right back to K7 without even having to flush
your printer. That is certainly unique and they were really smart to
offer this adaptability. All you would have to do is print out a purge
grey scale and you've got a totally different inkset to work with.
This would also allow you to put in the k7 sepia set or a split tone
set if you should desire for a particular job.
I agree with Walker. There is always going to be need for a dedicated
mono inkset for some of us. Lets hope we will alway have it. This
inkset was set up for QTR so controlling output with the create icc
capabiliy is also a big plus. I love these inks.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark Stracke"
> see what you think.
2006-11-14 by horstenj
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
Paul,
I must confess I'm a bit puzzled by your suggestion of this inkset
for the 2200. I just (2 weeks) started to work with the UT-3D set on
my 2100. I have not made all required profiles yet, but the early
results are very satisfying.
I think I do understand your suggestion to use this 4K+ set, with
its LLLK, for printers with non-variable dots. But why for the
2100/2200? As you indicated yourself, the LLLK might add less value
for this variable dot printer. Now you use non-blended toners that
seem to violate you earlier statements preferring blended toners (no
color dots, less color shift problems on glossy paper, perhaps also
longer lifetime). Why this apparent change in direction?
Joost
2006-11-14 by Paul Roark
Joost,
>Paul,
> this inkset for the 2200. I just (2 weeks) started to
> work with the UT-3D set on my 2100. I have not made
> results are very satisfying. ...
Short answer:  The 3D inkset is fine, and I use it.  But my large format
tone instability, the advantages of standard inks, QC issues, and what I see
as the future of B&W printing have combined to alter the approach I'll be
using going forward.
The long answer gets too long to put everything in one post, but here are a
few factors that have influenced this change in direction.
First, note that in many ways the UT-3D approach will still have advantages
over the 4K+ or 5K+cm approach I'm moving to.  For example, the Epson driver
is more convenient than a rip, and some purists may still prefer the blended
inks over the separate inks for desktop printers (but the 2200 with LM and
LLC is amazingly smooth, and standard inks allow me to use the best ink at
each position regardless of base compatibility, thus probably offsetting any
longevity advantages of blending).  I might also add that the 3D inkset is
the one that I'll will be using for most of the museum project I'm on.  It's
a good inkset, and I'm using it.
That said, I had some specific problems I needed to solve, and the future
looks a lot different to me after the introduction of the Epson k3 approach.
The 3D inkset may seem new to most, but I've been trying to solve it's
production and other problems for quite some time -- too long, in fact.
The immediate problem I had to solve involved the tone instability in my
7500.  My tests showed a huge advantage to non-blended inks.  I tried some
experiments with altering the ink base to solve the problem, but I
ultimately gave up on that approach.  While I found how to alter the
direction of the shifts, and while I think with enough time I could control
2 different pigment types in an ink, when the number of pigments goes to 3,
I doubt a base can be made that will be as stable as one that can be
tailored to a single pigment type.  I certainly don't have the time to work
on that solution at this point.  Additionally, the other issues here argued
against a unique base as a solution.
The bottom line is that a non-blended approach is all I'll be using for my
large format printers.  My printing with the 7500 is too intermittent to
assure that I'll have tone stability from printing session to the next.
(Note that those who use their printers regularly will be un-affected by
this problem.) When one considers that the 3800 is a large format design, I
doubt I'll be looking at blended inkset solutions for it either.
There are numerous advantages to standardized inks.  Quality control,
competing vendors, and using the same inks in all printers, among them. One
should recall that the only reason we got into the dedicated inkset approach
and non-standard ink densities is that the mainstream color market did not
produce a system or inks that were adequate.  That has changed.  As with the
printers themselves, I think this small niche market needs to take
advantages of the high volume products that already exist if they serve our
purposes.  I used to mix my own POTA developer for Technical Pan film --
until Kodak and others came out with products that were as good or better.
Then I used the simpler, pre-mixed solutions.
Additionally, I think people need to be able to profile whatever inkset they
are using.  There are all different levels of involvement here.  The EZ and
R2 approaches have broad appeal because they do not require any hardware or
software other than the driver.  I think these approaches will continue to
have appeal.  On the other hand, the older variable tone inksets are
difficult for people to write new curves for unless they have a spectro and
the patience to fool around with profiling.  Most do not.
Here the 2400 ABW mode really changes things.  The ColorVision PFP's ability
to profile the 2400 Y=Carbon arrangement also takes semi-automatic profiling
to an inkset that is about as lightfast as is possible with today's
technology.  The UT-3D inkset does work on the 2400, but, frankly, I'm not
sure there is much of a market at that level for an inkset that does not
take advantage of the technical improvements in profiling that are in place.
The Create ICC approach does extend the life of existing profiles somewhat,
but as totally new papers come onto the market, and as the ink tones drift,
keeping the print tones and ramps where they were intended becomes
increasingly difficult for most users, who simply rely on existing curves
and profiles.
Looking forward -- and that is the only direction I look -- for those who
want to do something that the OEM solutions can't do, I see rips and
standardized, competitive inks as the variable-tone approach that will
survive in this very changed environment.
Paul
www.PaulRoark.com
[Digital BW] Re: Suggested Monochrome Inkset for Epson 2200? (for Paul R.)
2006-11-14 by sagaface
Paul....I can't read your .pdf...it dowloads fine (I'm on a mac), but reads as gobbledygook.
anyplace else I could read this?
thank you,
Sarah
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...>
wrote:
> Joost,
> >Paul,
> and profiles.
> Paul
> www.PaulRoark.com
2006-11-15 by john dean
If you want an inkset that doesn't clog, has awesome smoothness of
tone,  especially in the high values,good dmax, and perfectly neutral
color everytime, try Cone NK7. If you like warm but not too warm, try
the CSK7. You can also put the Ultrachrome right in there behind them
without having to purge the lines or heads. QTR is the rip, it is $50.00.
john
RE: [Digital BW] Re: Suggested Monochrome Inkset for Epson 2200? (for Paul R.)
2006-11-15 by Paul Roark
Sarah,
Try it now.  The last time this happened there was some font incompatibility
that was the source of the problem.  So, I tried to make sure it's all
Arial, which has worked in the past.
Paul
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of sagaface
Sent: Tuesday, November 14, 2006 3:36 PM
Subject: [Digital BW] Re: Suggested Monochrome Inkset for Epson 2200? (for
Paul R.)
as gobbledygook.
thank you,
Sarah
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>
wrote:
> Joost,
> >> http://home1. <http://home1.gte.net/res09aij/4K+.pdf>
> >Paul,
see
a
advantages
driver
blended
any
It's
approach.
control
3,
I
One
approach
our
they
or
and
ability
profiling
place.
somewhat,
drift,
> and profiles.
> Paul
> www.PaulRoark.com
2006-11-15 by John Hollenberg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john dean"
$50.00.
I ordered the Cone neutral K7 for my Epson 2200.  I have some Red River
Dourian Art (I think, the one that is a dead ringer for HPR per Clayton
Jones) at home, as well as Epson Vevlet Fine art.
Any favorite papers for this inkset?
--John
2006-11-15 by sagaface
Strange...I still can't read it. There are a few letters and symbols that show up but mostly
nothing. I wonder what the deal on my 'puter is. Oh well.
wrote:
> Sarah,
> Paul
>   _____
> From: DigitalBlackandWhiteThePrint@yahoogroups.com
> Paul R.)
> as gobbledygook.
> thank you,
> Sarah
> eThePrint@yahoogroups.com, "Paul Roark" <paul.roark@>
> wrote:
> > Joost,
> > >Paul,
> see
> a
> advantages
> driver
> blended
> any
> It's
> approach.
> control
> 3,
> I
> One
> approach
> our
> they
> or
> and
> ability
> profiling
> place.
> somewhat,
> drift,
> > and profiles.
> > Paul
> > www.PaulRoark.com
Well I have three papers that I use with it primarily, but most
everything works well. My favourite for my own work is Hahnemuhle
Museum Etching (100 rag with no obas), Hah. Photo Rag 308, and
Hahnemuhle William Turner. I've also used Innova Cold Press with good
results. Strangely enough the fairly warm Epson Ultrasmooth that I
like for color looks quite cool with this inkset. Kind of nice but
really cool.
John
> --John
Re: [Digital BW] Re: Suggested Monochrome Inkset for Epson 2200
2006-11-15 by john eckenrode
I have playing with the K7 split tones lately and I
second John's choices on paper, especially Museum
Etching-great stuff, but expensive.
I made a couple curves for the Premier Fine Art 270g
that aren't bad, but it prints cooler than the Hahn
papers. Paul Roark has always suspected that Premier
Hot Press and Epson Ultrasmooth are the same paper and
John and my findings that both print coolish might
confirm that.
Ultimately the split tones and Museum Etching may be
my favorite combo after years of screwing around with
a bunch of inks and papers.
John E
> primarily, but most
> is Hahnemuhle
> Rag 308, and
> Ultrasmooth that I
> Kind of nice but
> really cool.
> John
> > --John
2006-11-15 by Mark Stracke
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Hollenberg" <weasel@...>
I'd recommend starting with Photo Rag. It's the standard on which the ink color (or lack of
color) was based. It's a fine paper too.
 My other suggestion is to work with the curves that come with Quad Tone Rip at the start.
The two papers you mention are not among the ones for which curves are supplied.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, john eckenrode
How does Museum Etching differ from German Etching?  Is the paper tone
the same?  I haven't seen either, but have a sheet of Mediastreet Royal
Plush which I understand is the same as German Etching.
--John
2006-11-15 by remkopieter
Paul,
After following and participating this post I just ordered the UT7
MC2200UTK-PLUS inkset . So I decided to start using my 2200 dedicated
for  B&W.
After installing etc. I will report on the results.
Thanks for now
Remko
In fact,
prints.  For
allow that
light (no
overs.  So,
The profile
moving end
experiments
is way
The ease
brightened paper
dynamic
the LLK
compromised.  The
dilution of
with the
highlights -
photo.
in the
colors in
older
problem
> with this approach.
in the
noticed in
if not
available
little
think this
worked
As such,
One can,
inks -
testing to
that it
any
cheaper.  Even
on ink
the ink
transfer
future.  All
tone
This
real mass
shifts on
have on
done is
improved it
printers
> Paul
The H. Museum Etching is 100% rag, and the German Etching is Alpha
Cellulose (high grade wood pulp). The Museum E. has no oba's but is
slightly brighter than the GEtch but not much. The textures are very
similar but not identical since they are made from different
substances. I have found the M Etch (also called White Etching) to be
tougher on the surface. I used to have more problems with the G.
Etching scuffing in big black areas, similarly to W. Turner, since the
"tooth" sticks out more. A lot of this has to do with how well you
brush the paper before printing however. For some reason the M. Etch.
just seems to be a great fit with the  NK7 inkset that I'm using, but
then so is PhotoRag.
John
> --John
2006-11-15 by Howard Shaw
> John
I've not tried either but am under the impression that the White &
Museum Etching are different papers. The White Etching is significantly
cheaper and contains OBA's.
Museum Etching:
http://www.hahnemuehle.com/index.php?mid=401&lng=en&pkat=1233
White Etching:
http://www.hahnemuehle.com/index.php?mid=401&lng=en&pkat=315
Howard
Museum Etching
You would think that wouldn't you? The roll version of Museum Etching
has "White Etching 350 gsm 100% rag" on the box, which is the Museum
Etching paper. You'll have to ask the Germans why they don't just call
it Museum Etching on the roll paper boxes like the sheet form. So far
I've used about 10 rolls of this stuff so it isn't a misplaced label.
The sheet form of " White Etching" is 25% rag and 247 gsm, a lesser
quality paper.
John
> Museum Etching:
> White Etching:
> Howard
RE: [Digital BW] Museum Etching
2006-11-15 by Jim Doyle
Guys.. As far as I Know They must Have missed labeled The rolls that Came to
the states..
They tell me that its all labeled in Germany..That its correct.
Jim Doyle
Shades Of Paper
600 Deer Rd Unit 4
Cherry Hill NJ 08034
856-795-7780
www.shadesofpaper.com
   _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of john dean
Sent: Wednesday, November 15, 2006 5:42 PM
Subject: [Digital BW] Museum Etching
quality paper.
John
> Museum Etching:
> HYPERLINK
"http://www.hahnemuehle.com/index.php?mid=401&lng=en&pkat=1233"http://www.ha
hnemue-hle.com/index.-php?mid=401&-lng=en&pkat=-1233
> White Etching:
> HYPERLINK
"http://www.hahnemuehle.com/index.php?mid=401&lng=en&pkat=315"http://www.hah
nemue-hle.com/index.-php?mid=401&-lng=en&pkat=-315
> Howard
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.14.5/534 - Release Date: 11/14/2006
