Digital BW, The Print
Split tone profile
Split tone profile
2006-11-09 by Paul Roark
I've recently made a mild split-tone profile that, I think, deals
effectively with the problems of a brightened paper used with a creamy mat
board.  In the past I've used non-OBA paper to deal with the issue.
However, with the selection of such papers limited, I decided to see what I
could do with a profile to match the paper and mat.  The approach seems to
work well.
I've made a short write-up of the efforts at
http://home1.gte.net/res09aij/PM_Split_Tone.pdf .
Paul
www.PaulRoark.com <http://www.paulroark.com/>
Re: Split tone profile
2006-11-10 by njfranknj
If your B&W toning process allows, you should be able to achieve split
toning effects using Photoshop's Duotone process.
Now that I have a decent profile (thanks Cathy!) I can print neutral,
metamerism-  and "greenie-"free B&W in RGB or Grayscale modes with my
2200 and MIS Pro color inkset and find that using a Duotone (tri- or
quad-, too) I can define the tone of highlights and control the
application with the curves and ink definitions. The method is very
versatile, maybe too versatile for me, since I never developed any
darkroom preferences, I can get bogged-down with all the possibilities.
Frank
creamy mat
what I
seems to
> work well.
> Paul
RE: [Digital BW] Re: Split tone profile
2006-11-10 by Paul Roark
> achieve split toning effects using Photoshop's Duotone process.
There are probably lots of ways to do this.  The new inkset approach I'm
using now on the 7500 and 2200 requires a rip.  So, I use that profiling
method.  I've never use the PS duotone process, but I’m sure the Epson
driver with the newest machines can do a very nice job.  On the other hand,
I would like control of the carbon channel as well.
IJC allows multiple alpha channels that I've used for split toning.  I find
that workflow easier than the PS-Epson driver workflow I used in the past.
In fact, with multiple alpha channels, I may be able to get control of the
carbon channel independently of the color, and yet have a full (if
light/more restricted shadow gamut) RGB.  It's one of the fun little
projects on the drawing board.  I'm not particularly interested in real
color, but as a adjunct to the B&W, it could be fun.
Paul
www.PaulRoark.com
creamy mat
what I
seems to
> work well.
> Paul
