Permajet MonochromePro and UT2
2006-09-06 by keith_r_smith_99
Paul said in another thread some time ago that the Permajet Monochrome Pro ink set are very similar to UT2. I have been trying the Permajet and find that the U&2 curves really don't work well. So the question is How similar are these two? Should the UT2 curves work? Keith
2006-09-06 by Paul Roark
What printer? The version for the 2100 is like the UT7. This may be what's happening. Paul www.PaulRoark.com <http://www.paulroark.com/> _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of keith_r_smith_99 Sent: Wednesday, September 06, 2006 9:04 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Permajet MonochromePro and UT2 Paul said in another thread some time ago that the Permajet Monochrome Pro ink set are very similar to UT2. I have been trying the Permajet and find that the U&2 curves really don't work well. So the question is How similar are these two? Should the UT2 curves work? Keith [Non-text portions of this message have been removed]
2006-09-07 by keith_r_smith_99
Sorry I should ave said. It;s a 1290. i managed to get a working one from 2 free broken ones, so I am trying it out. At the moment I am very unimpressed with the results from Monochromepro. The prints using PS curves are poor, The UT2 curves don't seem right and the curves from northlight-images don't seem right either. In fact none of them are as good as the print I get from my 2100 (using Lyson Fotonic dye (yes I know..) inks and a curve I managed to liniarize using a scanner. I need to decide whether to keep with the 1290 - maybe using real UT2 inks, or sell it and get a 2400 for colour and switch the 2100 to UT7 or something. or maybe even just use the 2400 with QTR fro B&W. Will the 1290 ever be better than the 2400/OTR combo? Thanks Keith --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > What printer? The version for the 2100 is like the UT7. This may be what's > happening. > > > > Paul > > www.PaulRoark.com <http://www.paulroark.com/> > > > > > > _____ > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of > keith_r_smith_99 > Sent: Wednesday, September 06, 2006 9:04 AM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] Permajet MonochromePro and UT2 > > > > Paul said in another thread some time ago that the Permajet Monochrome > Pro ink set are very similar to UT2. I have been trying the Permajet
> and find that the U&2 curves really don't work well. > > So the question is How similar are these two? Should the UT2 curves > work? > > Keith > > > > > > [Non-text portions of this message have been removed] >
2006-09-07 by Roy Harrington
Keith, You have a lot of unknowns so it's pretty hard to tell what's wrong. I'm not familiar with the Permajet inks but QTR does have profiles for UT2 inks on the 1280/1290. First, I'd make sure your printer is printing all the inks -- nozzle checks. Then try out QTR with some of the profiles. If it's still not to your liking you need to be more explicit about the problem. Roy --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "keith_r_smith_99" <keith@...> wrote:
> > Sorry I should ave said. It;s a 1290. i managed to get a working > one from 2 free broken ones, so I am trying it out. At the moment I > am very unimpressed with the results from Monochromepro. > The prints using PS curves are poor, The UT2 curves don't seem right > and the curves from northlight-images don't seem right either. > > In fact none of them are as good as the print I get from my 2100 > (using Lyson Fotonic dye (yes I know..) inks and a curve I managed to > liniarize using a scanner. > > I need to decide whether to keep with the 1290 - maybe using real UT2 > inks, or sell it and get a 2400 for colour and switch the 2100 to UT7 > or something. or maybe even just use the 2400 with QTR fro B&W. > > Will the 1290 ever be better than the 2400/OTR combo? > > Thanks > > Keith > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" > <paul.roark@> wrote: > > > > What printer? The version for the 2100 is like the UT7. This may > be what's > > happening. > > > > > > > > Paul > > > > www.PaulRoark.com <http://www.paulroark.com/> > > > > > > > > > > > > _____ > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of > > keith_r_smith_99 > > Sent: Wednesday, September 06, 2006 9:04 AM > > To: DigitalBlackandWhiteThePrint@yahoogroups.com > > Subject: [Digital BW] Permajet MonochromePro and UT2 > > > > > > > > Paul said in another thread some time ago that the Permajet > Monochrome > > Pro ink set are very similar to UT2. I have been trying the > Permajet > > and find that the U&2 curves really don't work well. > > > > So the question is How similar are these two? Should the UT2 curves > > work? > > > > Keith > > > > > > > > > > > > [Non-text portions of this message have been removed] > > >
2006-09-08 by Paul Roark
>... It's a 1290. OK, then it's similar to UT2. ... > Will the 1290 ever be better than the 2400/OTR combo? The main reason to use a 1290 over a 2400 is cost. The 2400 is an outstanding printer. I think it puts too much color in the "Advanced B&W" mode printing. That's why I have one set up with MIS LK, LLK and even LLK in the Y spot. (MIS LK and LLK are warmer than Epson K3 and give this setup a better range.) Then it uses the minimum amount of color and makes prints that are about as good as it gets. A 1290 that is working correctly can visually match the 2400, but it would be slower. Re-check all the settings by looking at my UT2 write-up at http://home1.gte.net/res09aij/UT2-Readme.htm Also, print see the test files I have at http://home1.gte.net/res09aij/Test-files.htm These will tell you whether the inks are loaded correctly. Good luck. Paul www.PaulRoark.com
2006-09-14 by keith smith
Thanks Paul and Roy for you input. I have given up on the 1290 - I could not get it to print consistently using either the curves or QTR - nozzel clogs etc. I will probably get a 2400 soon and use that for B&W until I convert the 2100 to UT7. keith [Non-text portions of this message have been removed]
