Digital BW, The Print
Epson 2400 and Photoshop Clipping Problem
2006-07-30 by Rob Greer
Please forgive me if this is a silly question, but I'm having a
printing problem when printing from Photoshop CS2 and print on my Epson
2400.
When I use CS2 and create a file that is 13" x 19" and use 13" x 19"
paper, when I print I get a message that states "The image is larger
than the paper's printable area; some clipping will occur." This
message appears even if there is no image information at the edges. Can
anyone tell me what I'm doing wrong and how to correct this problem?
Rob Greer
Re: Epson 2400 and Photoshop Clipping Problem
2006-07-30 by Tyler Boley
It doesn't know if there's information out there or not. All it knows is there's file out there,
pure white pixels are still pixels. There are minimum margins necessary, the info should
be in the printer manual, or printable area might be seen in the print with preview box or
indicated by negative numbers there, margin info also used to be in some page setup
dialogue boxes...
Is there a borderless setting for 13x19 in page setup?
Another thing, if there's no info out there you can just print anyway and let that white clip.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Rob Greer"
> 2400.
> Thanks,
> Rob Greer
It gives me the message even when I have "Borderless" selected.
That would be fine but there is no visual indicator where it is going
to clip and I would need to know that for my purposes. My point is that
it shouldn't be giving me that message.
Thanks for your suggestions though! Anyone else have any ideas?
Rob Greer
