Digital BW, The Print
Epson R220 BO driver problem?
2006-04-18 by foralltrash
Hi to everybody.
I just received my R220 but I'm not able to find the "black only"
option in the driver dialog!
I have only a "grayscale" option that seems to use the color inks to
produce grayscale prints.
Does anyone can help me? Can you tell me the correct driver version? I
use the 5.5 that was in the box.
Thanks for your help and best regards.
Ivan Ferrario
Re: Epson R220 BO driver problem?
2006-04-18 by Chris Ellis
Hi Ivan
I had this exact problem - you can fix it by downloading the latest
drivers from the Epson website.  I don't know whether your location
makes a difference to the drivers which ship with your printer.  I'm
in the UK.
I'm not at home right now so don't have access to the version numbers.
 (I posted about this previously so if you persevere with the search
tool you might be able to find some more details.)
Good luck
Chris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "foralltrash"
<foralltrash@...> wrote:
> Hi to everybody.
> Ivan Ferrario
Ivan
The details of the driver which works for me are in this post.
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/74854
Chris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Ellis"
<christian.ellis@...> wrote:
> Hi Ivan
> in the UK.
> Good luck
> Chris
> <foralltrash@> wrote:
> > Hi to everybody.
> > Ivan Ferrario
2006-04-18 by lscaglio2002
Chris
I use MIS neutral set for r220 and I noticed that when I use BO
printing I get brownish print; using all inks (without ICC) I get a
neutral print.
Is it your experience too?
Luca
2006-04-18 by brianechapman
I had the same experience with BO but I'm not sure it's a problem.
I think it's because the Eboni ink is warm to begin (notice the
product id's are the same for Eboni in both the warm and neutral ink
sets) with and the other neutral inks (when printing continuous
tone) are used to balance that out when using the neutral ink set.
Perhaps someone who knows might be more help though ;)
Brian
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lscaglio2002"
<lscaglio2002@...> wrote:
> Chris
> neutral print.
> Thanks
> Luca
2006-04-19 by Clayton Jones
Hello Brian,
That's exactly right.  Eboni is a pure carbon ink and so is a bit on
the warm side by itself (although it's a bit cooler than the Epson
black).  The R2 warm set is 3 shades of pure carbon inks.  The Neutral
set has those three plus two more that have some cool pigment added as
toners.
Clayton
2006-04-19 by Chris Ellis
Hi Luca
I just picked this up - I think Clayton's response says it all much
better than I could, and more quickly!
Chris
> Chris
> neutral print.
> Thanks
> Luca
2006-04-19 by lscaglio2002
Thanks everyone for the prompt reply
Luca
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones"
<cj@...> wrote:
> Hello Brian,
problem.
ink
set.
Neutral
as
> toners.
> Regards,
> Clayton
>toners.
Re BO printing, I'd like to add that while Eboni is slightly warm, one
of it's great qualities is that it changes it's tone from warm to cold
black depending on the paper.  So it's actual color really depends on
what paper it's on.  On Kayenta for example, it produces a neutral
cold black.  Since Kayenta is a bright white paper, this combination
makes the most pure and truly black and white carbon ink print I've
seen.  At the other end, on Wm Turner it produces about as warm as you
can get without being sepia colored.  So it has a wide range of tones.
 Other blacks respond to the paper too, but none with such pretty
tones as Eboni.  This is why it's the most popular ink for BO printing.
Clayton
2006-04-19 by Brian Chapman
Hey Clayton - thanks for the info!
Where on the cool/warm scale is the EEM paper?  (embarassingly,
that's all I've tried so far)  In comparison to the neutral
continuous tone print the BO option is significantly warmer but it
would be interesting to know where it falls in comparison to BO
prints on the two papers you mentioned below (Kayenta and WM.
Turner).
I showed a couple prints to one of my friends (one BO and the other
continuous tone) - and without giving any hints or anything, the
first thing he commented on was the intensity of the blacks in the
BO print!  Anyway, I thought that was interesting.
Brian
http://www.brianchapmanphotography.com
one
cold
on
combination
you
tones.
printing.
> Regards,
> Clayton
Hello Brian,
Fresh EEM has a paper color of W2.5 (in the grading scale used in the
"Paper Chase" article).  The ink color is B3.5, and dmax is D4.5
Yep.  It's a very common response.  Too bad we can't get that kind of
intensity and luminance with full ink prints.  The 2400/K3 prints are
the closest to it that I've seen from any full ink system.  I'm
printing a portfolio of California and Florida landscapes right now
that's all K3 and they look great.
Clayton
>>one of it's great qualities is that it changes it's tone from warm
>>to cold black depending on the paper.  So it's actual color really
>>depends on what paper it's on.  On Kayenta for example, it produces
>>a neutral cold black.  Since Kayenta is a bright white paper, this
>>combination makes the most pure and truly black and white carbon
>>ink print I've seen.  At the other end, on Wm Turner it produces
>>about as warm as you can get without being sepia colored.  So it
>>has a wide range of tones.  Other blacks respond to the paper too,
>>but none with such pretty tones as Eboni.  This is why it's the
