Digital BW, The Print
All of a Sudden Photoshop Baffled
2006-03-19 by btvarner
I apologize for this question in advance but I am apparently drawing
a blank.
I work all the time in Photoshop to prepare by images for printing.
One of the process I go through is to make adjustment layers for
different corrections &/or effects and then add a layer mask to
feather back the portions of each different layer I wish to have show
through the final image.  All normal enough workflow.  All of a
sudden I am having an issue that has never happened to me before and
I have now spent all day trying to resolve.
I can no longer observe any changes on the screen that I make to an
image when painting to expose or unexpose portions of a layer onto
the image below using layer mask.  This is driving me nuts.  Opacity
& flow are both set to 100% but I cannot change the image to either
show or hide what is below.  This carries over to every image I open
in Photoshop.
I am sure I have just inadvertently changed a setting but cannot
figure out what.  Any help would be appreciated.
Bruce Varner
Re: All of a Sudden Photoshop Baffled
2006-03-19 by bwinkjet
Hi Bruce,
I have done that several times.  In my case I inadvertantly had
unchecked Preview in the Adjustment layer.  I'm sure other problems
could explain it as well.
HTH
Paul
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "btvarner"
drawing
> a blank.
printing.
show
and
Opacity
open
> in Photoshop.
> Thanks,
> Bruce Varner
Re: [Digital BW] All of a Sudden Photoshop Baffled
2006-03-19 by Andrew S. Webb
On 3/19/06 at 8:27 PM GMT btvarner arranged some pixels so they looked
like this:
>in Photoshop.
Can you see the paint building up on your mask? Option/Alt-click on the
mask in the layer stack to show the mask by itself.
If not, you probably have your painting tool set to a mode that does not
change black and white, ie, screen on white or multiply on black. Check
to make sure you don't have a painting mode turned on.
Also try other brushes. It's possible to set brush options so that
nothing happens under certain circumstances.
Does anything happen when you set foreground to black and paint on a new
white background?
If none of these solve the problem, reset Photoshop's preferences.
Good luck,
_andrew
WebbWorks Words & Pictures
mailto:andrew@...
http://www.webbwork.com
