> I'm following this thread with great interest. I, too, have 'feed
> issues' with my 2400. It does appear to be very finicky with thicker
> papers.
> I recently tried H. Photo Rag 308. It was really hard to get this
> paper to feed correctly. I ultimately had to use the single sheet
> front feeder. And, even that, was not consistently effective.
> It is discouraging to have paid so much for a printer that has feed
> issues with thicker papers.
> Howard
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ginnylady33"
> <ginnylady33@> wrote:
> > Thanks Lou.
> > I don't believe there is a setting in the 2400 driver for a custom
> > paper width.
> > Anyone?
> > The only choice I'm aware for width is to choose the 'thick paper'
> > setting. Hehe...then one get's a warning with every print that one has
> > chosen 'thick psper', do you want to continue?
> > Duh......
> > Best
> > Ginny
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina"
> > <lbdina@> wrote:
> > > Ginny,
> > > I have a 4000 (not a 2400) and find Museo II feeds fine from the back
> > > slot. I use a custom paper width setting of 0.7mm in the Epson
> > > driver. Also, Museo II doesn't perform very well using the EEM
> > > setting on my 4000. The Textured Fina Art setting lays down less ink
> > > than the EEM setting and gives me much better Dmax and color gamut.
> > > Hopefully, this is relevant to your 2400.
> > > Lou
> > > > I just tried Museo II, 250 gsm. for the first time in my relatively
> > > > new 2400. For the most part, the paper will not feed from the rear
> > > feeder.
> > > > (About 1 out of 6 times the paper will feed into the printer)
> > > > I'm wondering what settings those of you who have tried Museo II in
> > > a
> > > > 2400 use?
> > > > What paper do you set the media type for in the driver?
> > > > Should I be using the 'thick' setting for 250 GSM. paper?
> > > > Should I be using the front single-sheet feeder?
> > > > Basically, I'm not sure if there is a problem with my printer, the
> > > > settings or the paper itself. By the way, for media type I was
> > > trying
> > > > Enhanced Matte and then Heavyweight Matte. (BTW, Enhanced Matte
> > > paper
> > > > itself feeds just perfectly.)
> > > > Thanks
> > > > Ginny
