B&W with Epson 7600 ?
2006-03-04 by roschko_leolevin
hi, i am using the Epson 4800 and 7600. Now I am wondering, if I should set up the 7600 for BW printing only. But I have no Idea what BW-ink-System would be the best for the 7600 ? And what RIP should I use for that ? Maybe there is anybody who has experiences with the 7600 and BW- printing. Thanks Florian
2006-03-04 by Shilesh Jani
Florian, Since you already have a very good b/w system in your 4800, I would explore the option of both matte and glossy (RC) printing on the same printer. To do that, you can put the 4800 PK, LK, LLK, LC, LM, and use the standard 7600 MK (same as 4800 anyway). That leaves one slot open in your 7 slot 7600 printer. If you want the option of sepia prints then give the last slot to 4800 Y ink. This is the most hassle-free way to go. All you have to do is swap the inner bladders from the respective carts of the 4800 into the 7600 carts, and reset the chips. This system will give you the option of warm to cold prints and many interations in between, including "selenium" type toning. The RIP that would drive the system would be QTR, a $50 program. You will need some way of reading density measurements to linearize the system. If you don't care for glossy printing, then by all means explore the other options of 3rd party inksets, particularly the MIS FS (quad), or even the InkjetMall's various inksets. Hope this helps. Shilesh --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "roschko_leolevin" <g.flo@...> wrote: > > hi, > i am using the Epson 4800 and 7600. Now I am wondering, if I should set > up the 7600 for BW printing only. But I have no Idea what BW-ink- System
> would be the best for the 7600 ? And what RIP should I use for that ? > Maybe there is anybody who has experiences with the 7600 and BW- > printing. > > Thanks > > Florian >
2006-03-04 by Leon Strembitsky
I'm printing both colour and b&w on a 7600 using QTR RIP for the b&w. Only works with matte papers though... Leon --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "roschko_leolevin" <g.flo@...> wrote: > > hi, > i am using the Epson 4800 and 7600. Now I am wondering, if I should set > up the 7600 for BW printing only. But I have no Idea what BW-ink- System
2006-03-04 by Paul Roark
> ... I have no Idea what BW-ink-System > would be the best for the 7600? Several of the inksets I've been involved with will run on the 7600. The MIS UT-7 is a variable-tone inkset that I used on a 7600, both with the Epson driver and the Bowhaus IJC rip. See my notes at http://home1.gte.net/res09aij/UT7-7600-Readme.htm The UT-3D that I'm setting up now I have running on the 2200, and it is intended to cover the 7600. It will give easy Lab a* and b* control across most of the range and most popular papers. It utilizes the UT7 C & LC, but the UT7 toner is split, and there will be a new LK. The UT inksets like UT7 and UT-3D print on matte or glossy papers without changing the inks. The dmax is generated with the dark midtones. With the 3D on a 2200, this is hitting 2.3 on the Epson Ultra Premium I'm printing at the moment. It does not suffer from gloss differential at the dark end, in part, because there is no sudden change of ink at there. The UT inks have very low bronzing. The UT inks have been the most lightfast I've tested, in part because they use the minimum amount of color pigments, and the blended inks back the colors up with carbon, minimizing the visual density loss as the color pigs fade. I'm going to color management to match the monitor and print. I think it is the easiest way to go. With the UT-3D I'm using Roy's Create ICC, and there may be other automatic profiling down the road. Paul www.PaulRoark.com
