Digital BW, The Print
R220 cartridge woes
R220 cartridge woes
2006-01-25 by vmixer42
Any tips for getting the R220 to recognize 3rd party carts?  I'm using the MIS UTR2 inkset and
when I last ran out of cyan, it refused to accept either of two brand new MIS carts. in this
position.  I tried the things MIS tech. support suggested (shimming, pulling the power cord
during cart replacement, bending the tabs, overstuffing the chip cavity), but nothing seems
to work.  In desperation, I threw in the OEM Epson cyan cart which it took just fine (so at least
I can print BO for my next photo class assignment).  Anything else I should try?  Thanks in
advance for any help...
RE: [Digital BW] R220 cartridge woes
2006-01-25 by Paul Roark
> Any tips for getting the R220 to recognize 3rd party carts?  ...
The suppliers of chips to the third-party re-sellers have been sending some
incorrectly labeled products.  Use the OEM chip until MIS replaces the bad
chip with a correct one.  To use the OEM chip, you'll need a chip re-setter,
which is a cheap item.  Use a sharp knife to shave off the plastic pins that
hold the chip onto the OEM cart.  It should fit the MIS cart easily.  I use
a 1/8" wide strip of tape across the top of the chip and sides of the cart
to hold the chip on.
Paul
www.PaulRoark.com
Re: [Digital BW] R220 cartridge woes
Thanks Paul... I gather I shouldn't try to move the OEM chip onto one of the MIS carts without
resetting it first?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...>
> Paul
> www.PaulRoark.com
> the MIS carts without resetting it first?
You can move it over any time.  It'll just show the same level as before.
Paul
www.PaulRoark.com
