Re: [Digital BW] Re: A bit off topic - RE: Epson 2400 - Ink Usage
2006-01-24 by sburger104@aol.com
The MIS inks for the 2400 are wonderful. I use the refillable spongeless cartridges. The black and white prints are exceptional as well as the color. I feel this is the best solution today, as the inks can easily be swapped out. It took me a couple of refills before I could refill the cartridge without getting any ink on my hands. I started with a continuous ink system on a 2200. The system worked well for about two years. I print a lot, so this was many prints. Eventually, the cartridges developed a clog that I couldn't fix. I still think the CIS system was cost effective, based on the number of prints that were made. The problem with continuous ink systems is swapping to different inks is pretty much out of the question. That's the advantage of the refillable cartridges. With this set-up, one has the ability to make great glossy, matte, or black and white prints all with one printer and one set of inks. Steve Burger [Non-text portions of this message have been removed]
