Digital BW, The Print
Densitometer question . .
2006-01-22 by lulalake_1999
Hi folks,
OK it's time for me to get a bit more involved in curve making, etc.
in B&W printing. I've been eyeballing it for some time and am pretty
happy with the results I am looking for more control over the prints
through making my own curves.
I'm requesting a bit of mentoring in densitometers.
I'm mostly a film shooter, I scan the negs in to print. I'm using a
2200 and QTR, I am using an MIS Ebony cart in place of the standard
Epson black and it's great (Thanks Paul R.) however I need to refine
it a bit.
I've never messed with them but I see many densitometers on eBay from
60 bucks on up. What's a "good" densitometer? What brands are
acceptable (I know, lots of opinions there)?
Thanks for any thoughts that you are generous enough to share.
Jules
Re: Densitometer question . .
2006-01-22 by helen_bach2003
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lulalake_1999"
Jules,
I'm only familiar with a few Macbeth instruments, and my experience
with densitometers is mostly in cinematography and photography rather
than printing, so this is a bit biased. I'll only mention those that
can do visual reflection measurements, because I guess that is what
you are most interested in.
The TR924 is a good all-round photo densitometer. It has both
transmission and reflection heads. It has visual (Wratten 106 filter,
amber, to mimic the spectral response of the eye), Status A and Status
M RGB channels for transmission; and visual and Status A RGB for
reflection. Status A filters are glass spectral interference
(dichroic) filters for use with prints and transparencies intended for
viewing. Status M filters are used for negative and interpositive
materials. The TR524 and TR1224 are similar. The RD919 is the
reflection-only equivalent.
The RD918 is similar to the 919, but it has Status I narrowband RGB
filters instead of Status A, in addition to the visual. I'm afraid
that I have no knowledge of Status I densitometry, other than that it
is intended for use with inks.
Best,
Helen
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "helen_bach2003"
from
> Jules,
rather
filter,
Status
for
it
> Best,
> Helen
Thanks so much Helen,
I assume that the reflection head would be the one for checking
prints so I'll investigate those.
Also thank you for your posts on the Museo Silver Rag paper. I'm
looking forward to trying it.
Jules
