Digital BW, The Print
Y position options for UT7 for 2200
2006-01-20 by Michael Vendrell
Paul Roark, et al: For the optional inks in the Y
position do I need to fill my own or re-chip the
carts, or can these be purchased pre-made from MIS.
(e.g For printing on un-coated Arches) Perhaps this
has been answered before,but I can't find it on the
Paul Roark or the MIS sites - so I apologize in
advance if I've overlooked something. Thanks...
Michael Vendrell
Do You Yahoo!?
http://mail.yahoo.com
RE: [Digital BW] Y position options for UT7 for 2200
2006-01-20 by Paul Roark
Michael,
> ... For the optional inks in the Y
I'd re-fill your own.  I don't think MIS sells the LC in the Y cart.
You'll have best results with the diver and slider approach -- i.e., don't
use the RGB curves approach.  The reason for this is that the LK really
seems to help the image on un-coated Arches Hot Press.  So, you'll want the
driver to "think" a grayscale image with no color is being printed.  Sliders
should also be at default 0 position for this.  Today, with Roy Harrington's
Create ICC program, that may be the easiest way to linearize the system.  A
monotone curve in PS could also do it, if needed.
Good luck.
Paul
www.PaulRoark.com
Thanks Paul.  Very Helpful! The following is a quote
from your site:
 "A simple grayscale curve, however, can improve the
contrast.  \ufffdUT22-ArchesHP-GS\ufffd is one that works well
with media type at EEM and Color Controls checked.
The \ufffdColor Density\ufffd slider in the \ufffdInk Config\ufffd area is
set to + 20%.  Resolution should be at 2880 with High
Speed not checked."
Could you tell me where to get and where and how to
use the "UT22-ArchesHP-GS" curve you mentioned?  Would
that be part of the work flow you describe below - or
are these two different recommendations?
Thanks again, Michael Vendrell
--- Paul Roark <paul.roark@...> wrote:
> Michael,
> MIS.
> LC in the Y cart.
> that the LK really
> Good luck.
> Paul
> www.PaulRoark.com
Do You Yahoo!?
