Hidden Power in Adobe's LightRoom
2006-01-12 by kingdex1
I'm new to posting here. Hope this is the right place to open this thread. I've been using Adobe's Light Room beta since it became available. Also, quite naturally making comparisons with Aperture. Both quite promising apps for the professional, digital photographer the merits of which are probably best explored somewhere other than this forum. HOWEVER... significant to this black & white forum is an under-emphasized conversion tool available in LightRoom called the Grayscale Mixer. In my opinion as a black & white photographer, the Grayscale Mixer alone is justification for buying this software. When I began "playing" with it I approached it with more than modest scepticism. How surprised I was to eventually tap into its incredible power. I've explored and tried nearly every approach to converting digital color to black & white. My personal choices to date are the channel mixer in Photoshop, the calibrate tab in Bridge and a plug-in called Convert toBW Pro. I am so impressed with the Grayscale Mixer that I may begin to use it exclusively for all my conversions. It seems to give me the best of all my previous choices. It allows for finite control of scale and saturation of color channels; provides instant previews and is most intuitive. Needless to say it is used on RAW files. And, after spending nearly 40 years in a darkroom, using this tool seems to recall the "old" rush of watching your tests come up in the tray. Aditionally, there is an "auto" toggle in the Grayscale Mixer which, like many other "auto" options, I was inclined to ignore. DON'T IGNORE IT! Use it as a starting place and then tweak from there. Here's why: And I quote Michael Reichmann: "There is an important control at the upper left of the dialog box titled Auto. Here is what its purpose is, as described to me by the engineers at Adobe. A conventional Grayscale conversion such as you would get in Photoshop using the Mode menu, or even via some more complex techniques involving Lab and multichannel mode, or such as you would get by simply turning down the Saturation control in Lightroom's Develop or in ACR, just takes the colorimetric definition of how luminous a pixel is and uses that as the gray level. The results are independent of the actual colors in the image. So, if the colorimetry does not provide much differentiation, then the grayscale conversion will lack detail. The Auto grayscale option in Lightroom looks for optimal settings for the grayscale mixer so that the line from black to white, instead of just following colorimetric definitions, follows a path that creates the greatest diversity of grayscale values, based on the distribution of colors in the image. Translation: Auto does the best possible job of causing the maximum differentiation between tonalities." Sorry about the lenghty post. It is simply the result of my excitement after using Grayscale Mixer and my desire to pass that along to those in this magnificent black & white forum. Best, King Dexter
