Digital BW, The Print
PermaJet MonoChromePro inks review
2005-07-31 by kcooper666
Hi
I've just finished a review of the new MonoChromePro pigment based ink set from
PermaJet in the UK.
It's at:
http://www.northlight-images.co.uk/article_pages/monochromepro_review.html
The printer used was an Epson 1290.
As supplied they suggest using the Epson driver with adjustments or additional Photoshop
curves. I also tried using QuadToneRIP and building curves for the Delta Matt Fibre and
Museum Classic papers from PermaJet. I've included info about some of my QTR curve
building experiences and comparisons with prints done on my Epson 9600 using the
ImagePrint RIP that I use for most of my B/W landscape prints that I sell.
Hope it's of interest :-)
bye for now
Keith Cooper
PS
I have no commercial connection with PermaJet
RE: [Norton AntiSpam] [Digital BW] PermaJet MonoChromePro inks review
2005-07-31 by Jim Farrell
Keith,
            Great article, out of interest, have you experienced any nozzle
clogging using the pigment inks on a 1290, I use the MIS inks and get the
Black ink clogging up; nice to see that someone else uses QTR.
Regards
Jim Farrell
Re: PermaJet MonoChromePro inks review
2005-07-31 by John Vitollo
> PermaJet in the UK.
Keith...nice article but QTR isn't free...costs $50.00.
Re: [Norton AntiSpam] [Digital BW] PermaJet MonoChromePro inks review
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jim Farrell" <jim@a...> wrote:
> Keith,
Thanks!
I've not had any problems with clogging but then again I've only put a few of the new
cartidges through the 1290... and I do have that 9600 sitting in the room next door :-)
I think it was quite important to run the cleaning cartridges before the changeover since
Ink pH mismatches are great for causing sediment build up and clogs. The PJ inks are also
available for the 2100 where I suspect that as it was designed for pigments from the start,
there would be less likelihood of clogs. Maybe running the cleaning carts every so many
cartridge changes might keep the system 'fresh'?
There are no curves published by PJ for the 2100, but if the performance is like the
examples I tried for the 2100 it might be best going for QTR from the start.
The QTR tests were certainly interesting and produced very good results. I should imagine
that only a minority of people using the software would have an Eye One sitting around, so
curve generation and linearisation would probably not be an easy option for most ;-(
bye for now
Keith
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo" <jvlist@c...> wrote:
> > PermaJet in the UK.
The printing part is free. The curve generation part is shareware and asks for the $50 if you
use it regularly
see
http://harrington.com/QuadToneRIP.html
Is this not the case for the PC version? Just I've not got a PC and never tried it on one
Keith
Interesting...I just read Roy's shareware paragraph...sure is confusing! You might be right..
you
> use it regularly
> see
> Keith
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@t...> wrote:
> Aren't these MIS inks?
> Tyler
Are they?
I don't have any info on where the inks actually come from. PermaJet are a UK company based
not too far from where I live (in the UK midlands) and after seeing some of my B/W work,
asked if I'd be interested in looking at some of their new products...
Do you think they are any particular product from MIS?
Keith
2005-07-31 by dfaprinting
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kcooper666"
> > Tyler
> Are they?
products...
> Keith
More likely is that they buy the ink from the same manufacturer, if
they are indeed the same inks. But then again, who knows.
I was just looking at the MIS site and couldn't see a direct match. If they are the same then
you could have a US version of the review where you substitute product names ;-)
In some ways what I really found was that to get the best out of the inks you had to use a
driver like QTR, when they were excellent. The Photoshop curves technique is a good way to
get the best out of the Epson driver, but when it comes down to it the Epson driver is meant
for their own colour inks...
Keith
2005-07-31 by Steven Karafyllakis
Keith;
I think Roy needs to update his policy; that statement dates back to
the earliest releases, and doesn't take into account a lot of work
done since then, such as the installer, the several dozen curves
that Roy and others have added that make QTR useable 'out of the
box', on-goin work to support new printers, and Steve Billiard's GUI
which now comes integrated, and without which most of us wouldn't be
using QTR at all.
It may be a fact that under the hood there is some publicly-licensed
code being used, (Microsoft uses some too, when was the last time
you heard them say any part of their programs are free?) but how do
you actually use QTR without using some or all of the above? Try
downloading Gimp-Print and making it do what QTR does-it ain't gonna
happen, so let's be fair: at $50.00 it's the cheapest RIP on the
market, and worth much more.
In fairness to Roy, Steve, and all; the other fine folks who have
contributed, please consider changing your article.
Steve Karafyllakis
> you
> > use it regularly
> > see
> > Keith
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...>
wrote:
> Keith;
> using QTR at all.
> Steve Karafyllakis
Sorry but no...
if the terms on the web site say what is what, then it is not for me to interpret or second
guess them. If you wish to donate $50 (or more) for the printing part, then that is purely
for you to decide.
As to the QTR GUI - it's a windows thing and I've not got a PC so I've never used it. I
believe it is included in the PC download. If you go to the site referenced you will find this
statement:
"QTRgui is a front end to Roy Harrington's Quad Tone RIP for Windows. It is also
FreeWare."
If Roy changes the terms on the site then I would happily change the wording. The terms
happen to be quite clearly stated on his site to anyone who downloads the software.
I am not saying it isn't worth the money and isn't a great piece of software, but that's really
not the point.
Keith
Re: [Digital BW] Re: PermaJet MonoChromePro inks review
2005-07-31 by Tom Baker
Keith  -
You might be right.  But, I don't think that your's is a very honorable approach.
Tom Baker
wrote:
> Keith;
> using QTR at all.
> Steve Karafyllakis
Sorry but no...
for you to decide.
statement:
FreeWare."
not the point.
Keith
Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep them short.
- Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
- Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
2005-07-31 by Tyler Boley
> > Tyler
> Are they?
I really have no problem with whether they are or aren't. Either way
is fine with me. I just want to keep good up to date knowledge of
exactly what inks are out there and what they do.
A new monochromatic set on the market would definitely be "news".
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Baker <tbaker1328@s...>
wrote:
> Keith  -
> Tom Baker
Eh? Just how is that?
Am I now supposed to give my estimation of worth when I mention a program?
"Here is the new version of PhotoShop, it's so good I think you should ignore the price tag
and send Adobe $1000"  I don't think so :-)
The QTR stuff is excellent...
Keith
2005-08-01 by Steven Karafyllakis
OK, Keith, you don't use the GUI.... point is, how do you separate
out the 'printing part'? Either you use the provided curves, which
where after all generated using the 'curve creation' part, or you
use the curve creation yourself to make your own custom curves.
Either way you are making use of Roy's hard work and ingenuity, and
taking advantage of his good will (and poor business accumen-sorry
Roy)to peddle someone else's product. Sorry if that sounds harsh,
but that's the way I see it.
Steven Karafyllakis
> wrote:
> > Keith;
back to
work
GUI
wouldn't be
> > using QTR at all.
licensed
time
do
gonna
have
> > Steve Karafyllakis
> Sorry but no...
> for you to decide.
> statement:
Windows. It is also
> FreeWare."
> not the point.
> Keith
2005-08-01 by kcooper666
> Steven Karafyllakis
Well that's your view, and needless to say I do not agree with it :-)
I'll go along with what Roy says on his site and respect that. It's up to him to decide what he
wants to do with it...
Keith
2005-08-01 by bwinkjet
Hello,
Why are several of you "shooting the messanger?"  Keith is merely
quoting Roy's website.  When and if he updates it Keith should and
probably will update his publication.  I just don't see jumping on
Keith for his actions.  He has explained, and I for one understand.
It has nothing to do with the quality or worth of Roy's efforts.
Paul
separate
which
and
sorry
> > Steven Karafyllakis
> Keith
2005-08-01 by dfaprinting
It's increasingly more common to offer some form of software for free
while you work out a bunch of the bugs. Then when it is great, you
offer it for a substantial chunk of money. Others simply make enough
to keep going from the people that do not take advantage of the
software author's generosity and actually send some money to help
out. In Roy's case, if it ever amounted to enough to be able to buy
the newest printer, it might help to make the newest changes, and
make them better and quicker. It also might be that Roy doen't want
to have to keep up with the software pirates, and/or develop a bunch
of security features. You may spend more time trying to (temporarily)
defeat the pirates than you spend writing code, or making prints.
I do seem to remember that Roy wrote this because he was unhappy with
the performance in the Epson driver, and didn't want to spend the
rather large amount for a RIP like Studioprint or Imageprint just to
get the kind of prints he was looking for. Hopefully Roy will stop by
and correct me if I'm wrong on that last part.
2005-08-01 by John Vitollo
> Paul
I agree, give the guy break.
The way I read the latest Shareware agreement, just like Keith, is the driver is free but if the
profile makng part is used and meet your needs than pay the $50.00.
Or it could be that Roy's "QuadToneRIP Shareware License" is written in the head-scratching-
perplexing genre as Roy's first QTR 1 profiling instructions. I'm still recovering after a few
years of read it...I have to blame my hair loss on someone. ;-{
2005-08-01 by Tony Bonanno
Hi Keith and others,
As already stated, this is not about "shooting the messenger", but
rather there appears to be some legitimate confusion regarding the
shareware fee.
I guess it is up to Roy to clarify and resolve the fee question.
However, on the PC page, I don't see anything confusing at all.  Roy
clearly states that the "PRODUCT" has "TWO PARTS" : the gimp engine
and the QTR profiles, etc.  He then states that if you wish to
continue using the "PRODUCT", then there is a $50 fee.  There is no
"one part" PRODUCT option.  To read into the text that if you don't
use the profiles you don't have to pay the fee is a real stretch in my
opinon.
You might want to consider emailing Roy.  There have been a number of
articles on QTR and every one I've read is pretty clear that the
shareware fee is $50.
I found your article Keith to be quite informative and interesting
about the MonoChrome inks and the use of QTR. Thanks for the link.
Tony
2005-08-01 by Phil Rose
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tony Bonanno"
> shareware fee.
> opinon.
> Tony
I agree with every aspect of Tony's post.  In Keith's excellent
review, the interpretation he gives to Roy's shareware fee structure
is rather a "stretch" (one worthy of a high-priced tax lawyer). IMO,
he's  reading into Roy's wording a meaning that isn't intended and
can't be supported by the one-piece structure of the software
download. I don't believe Keith did this carelessly or maliciously
but in any event his interpretation of the shareware payment happens
to be at odds with the almost the entire community of QTR users.
Yes, it would be good if Roy changed the wording to make his intent
utterly, absolutely and irrevocably unmistakable. But in the meantime
Keith ought to just 'fess up to the fact that he's likely
misinterpreted Roy's intent, and change his article appropriately
without waiting for action on Roy's part. For that matter, I'd expect
that Keith, by now, would be making some effort to contact Roy
_directly_ for clarification.
Phil
> Phil
Hi
I'm afraid I stick by how I describe the QTR structure. It is clear for anyone to read when
they download and/or install the s/w ... it is not for me to interpret intent. And let me say
_again_ it is well worth $50!
However for all those people intent on seeing me as trying to bilk some poor developer
out of his well earned dues, I'd say that I sent a mail to Roy when I first published the
review inviting comment on the QTR aspect of the review. I am always happy to correct
mistakes but only when I hear from the horses mouth so to speak.
So to all of you having a slight dig at my integrity I stick my tongue out at you! :-) :-)
To those thanking me for the article or mailing me to agree with how I covered QTR
thanks!
High price lawyer indeed -- I'll choose to take that as a complement since we don't have
such a plague of them here in the UK :-) ... I'm a photographer now and the business suits
have sat in my wardrobe for several years.
bye for now
Keith :-)
2005-08-03 by Scott McLoughlin
Yes, I'm still in futzing mode with QTR unfortunately, but I've paid up
in the
last few weeks, and feel better for doing so.
Scott
Tom Baker wrote:
> Keith  -
> honorable approach.
> Tom Baker
