Digital BW, The Print
RE: softproofing QTR on PC/Windows
2005-03-04 by Diane Fields
I hope I'm not being too obtuse, but I've read through the directions on the
QTR site for softproofing (double clicking on the 'install softproof'
command does not appear to be valid in Win--I had never heard of it before,
but I tried it anyhow) and read Carl Schofield's directions for
softproofing.  AFAIK, in the Windows version of PS, I have always
softproofed by choosing an ICC profile from proof setup and of course, the
'proof' files in Carl's folder are not ICC profiles that can be used in
Windows (I stand to be corrected, but I've never seen files like this).
I was hoping that I could also use Carl's blending action but this wouldn't
be possible unless I have actual ICC profiles.
I have installed the ICC profiles from the QTR site and can convert to
gray-lab and then to gray matte or gray photo for output, but---is there any
way to softproof for QTR in Windows?
Thanks once again,
Diane
Re: softproofing QTR on PC/Windows
2005-03-04 by Johnny Eades
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Diane Fields"
<picnic@c...> wrote:
Hello Dianne,
When you convert Gray-lab to Gray-matte you are then working in the
proof space. Save the file as Gray-matte for printing from QTR. What
you do on the screen is the proofing environment.
Your friend in Photography,
Johnny
to
there any
> Thanks once again,
> Diane
Re: softproofing in Windows/Can I take this back????
directions on the
softproof'
before,
I just found the 'proof' folder and am going to copy the 'proof'
files to that and see--live and learn LOL.  Yes, that works after
closing and reopening PSCS.  However, because I don't have actual ICC
profiles, I'm unable to use Carl's blending action it appears.
Diane
Re: [Digital BW] RE: softproofing QTR on PC/Windows
2005-03-04 by Steve Kale
Do your soft proof in the normal way (a la colour in PS) but select either
QTR Gray Photo or QTR Gray Matte paper depending on what you are using.  A
while ago there was a long debate about how tonal compression was handled by
QTR (and other RIPs such as IJC/OPM).  In essence it was done poorly and on
a straight line basis causing a whole perceptual tone shift in the image.
Roy found a way to design ICC profiles to meet the tonal range we print to -
a general one for each of matte paper and photo paper.  By using the
Perceptual colour engine to convert the image to the print space we get a
much better fitting of the image into the compressed print space.  Since ICC
profiles are used to do the conversion we can do a soft proof in the
conventional manner with these.  They do NOT soft proof for hue (warm or
cold etc) but provide an accurate soft proof of luminance.  In essence, if
you are not worried about checking hue then these offer a much simpler way
of soft proofing. I HIGHLY recommend using the new workflow.  If you want to
soft proof for hue then you will need to create your own soft proof ICC
profiles and create soft proofs in PS in the normal fashion.
Re: [Digital BW] Re: softproofing QTR on PC/Windows
Yes or if you want to see a soft proof before committing by conversion to
the print space then just set up a PS soft proof with the selected print
space and perceptual intent.
> From: Johnny Eades <jeades1@...>
> Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
> Date: Fri, 04 Mar 2005 13:50:16 -0000
> Subject: [Digital BW] Re: softproofing QTR on PC/Windows
> Hello Dianne,
> Johnny
> to
> there any
>> Thanks once again,
>> Diane
Re: [Digital BW] Re: softproofing in Windows/Can I take this back????
Carl's blending action was designed as a means of soft proofing hue under
the old workflow (pre use of perceptual intent to map from workspace to
print space).  If you want to soft proof hue you will need to make your own
soft proof ICC files from output generated with the new workflow.  Unless I
am mistaken, Carl has not updated these hue proofs for the new workflow.
(The proofs were intended primarily to preview the workspace to print space
mapping rather than hue.  Now that mapping process has been significantly
improved and can be soft proofed from the actual ICC profiles used (QTR Gray
Photo/Matte Paper) in the perceptual conversion process.)
> From: Diane Fields <picnic@...>
> Date: Fri, 04 Mar 2005 13:54:59 -0000
> Subject: [Digital BW] Re: softproofing in Windows/Can I take this back????
> directions on the
> softproof'
> before,
> Diane
Thanks Steve.  I just learned that through printing from one where I used the 'proof' with color--and then using the converted gray-lab to gray-matte tiff to print to the same hue in QTR.  I agree--this is not the way to go.
I appreciate your help.  I'm really happy overall with QTR--just have to work out my own workflow.
Diane
  Sent: Friday, March 04, 2005 9:31 AM
  Subject: Re: [Digital BW] RE: softproofing QTR on PC/Windows
  snip
Yes, I understood that from the very good information from Lou I found on a search yesterday.  Thanks for reiterating it.  I found (see a post just made) where I found the 'proof' files not good for my uses for QTR.
Diane
 Original Message -----
  Sent: Friday, March 04, 2005 8:50 AM
  Hello Dianne,
  Johnny
  to
  there any
  > Thanks once again,
  > Diane
  Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
  If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
  Please follow these basic guidelines:
  - As threads develop, trim off excess portions of earlier messages to keep them short.
  - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
  - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
  http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
    a.. To visit your group on the web, go to:
    b.. To unsubscribe from this group, send an email to:
    DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
    c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
RE: [Digital BW] Re: softproofing in Windows/Can I take this back????
2005-03-04 by Stephen Billard
Look in the "icc" folder of the QTR installation. The ICC files are all
there.
-Stephen
 www.sbillard.org/Stephen
> -----Original Message-----
> From: Diane Fields [mailto:picnic@...]
> Sent: Friday, March 04, 2005 5:55 AM
> this back????
> directions on the
> softproof'
> before,
> Diane
> In low income neighborhoods, 84% do not own computers.
> At Network for Good, help bridge the Digital Divide!
> http://us.click.yahoo.com/S.QlOD/3MnJAA/Zx0JAA/ucIolB/TM
RE: [Digital BW] RE: softproofing QTR on PC/Windows
If anyone would care to document the soft proofing process for QTR for
Windows and send it to me off list, I will add it to the QTR help.
-Stephen
> Sent: Friday, March 04, 2005 7:08 AM
> Diane
>   ----- Original Message -----
>   From: Steve Kale
> but select either
> you are using.
>   snip
> Has someone you know been affected by illness or disease?
> Network for Good is THE place to support health awareness
> efforts! http://us.click.yahoo.com/rkgkPB/UOnJAA/Zx0JAA/ucIolB/TM
