Digital BW, The Print
QTR 2.1e/QTRGui 2.12 Printing horizontal line at bottom of image
2005-01-16 by Kip Cole
After a "cleanout" and install of the 2.1e version (was previously using a
version several release older with batch files) my images are all now
printing with a horizontal grey line of about 3 pixels wide along the bottom
of the image (looks like along the bottom of the photoshop canvas).  It's
definitely not in the image file (well, I've looked hard).  The line shows
up in both the QTRGui preview window, and on the printed page.  This does
sure suggest it's an image file problem I know, but I just can't see it in
the files, and files which used to print fine now also have the line.
Anyway seen this, or got any clever ideas? (could find anything similar in
an archive search)
Regards, --Kip
Kip Cole
e:  <mailto:kipcole9@...> kipcole9@...
RE: [Digital BW] QTR 2.1e/QTRGui 2.12 Printing horizontal line at bottom of image
2005-01-16 by Stephen Billard
It might be a TIFF file format problem. If the file is not saved as a
straight TIFF, no compression, no alpha, IBM format, try saving it that way.
If that works, we will probably need a copy of the image to see what is
wrong.
-Stephen
http:\\www.sbillard.org\Stephen
Sent: Saturday, January 15, 2005 5:44 PM
Subject: [Digital BW] QTR 2.1e/QTRGui 2.12 Printing horizontal line at
bottom of image
an archive search)
Regards, --Kip
Re: [Digital BW] QTR 2.1e/QTRGui 2.12 Printing horizontal line at bottom of image
2005-01-16 by jimpegoda
I've experienced this when I print in Landscape orientation. I've
found that when I print in Portrait orientation QTR doesn't print
the line.
-Jim
the bottom
canvas).
similar in
> an archive search)
> Regards, --Kip
Re: QTR 2.1e/QTRGui 2.12 Printing horizontal line at bottom of image
2005-01-16 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Kip Cole" <kipcole9@h...>
> an archive search)
> Regards, --Kip
Hi Kip,
I've found this problem and have fixed it.  There's a couple other things
that I have done which I am testing out.   A new version should be available
very soon.
Roy
RE: [Digital BW] Re: QTR Windows -- Printing horizontal line at bottom of image -- Fixed
2005-01-19 by José Miguel Ferreira
Roy,
Is it necessary to un-install version 2.1d before installing this release?
Also, do you recommend doing the greyscale and 8 bit conversion in PS or
will QTR do that job just as well?
Jos�
Sent: mercredi, 19. janvier 2005 01:01
Subject: [Digital BW] Re: QTR Windows -- Printing horizontal line at bottom
of image -- Fixed
This has been fixed.  There is a new download -- version 2.1f.
Simply download and install.
Roy
Please visit the Group Homepage to check the Files, and other resources as
they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep
them short.
- Good manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice.
- Keep your posts and threads related to the group topic of digital B&W
printing. Users who persistently make off-topic posts may be removed from
the membership.
- By posting on this forum you agree to abide by the group rules and
guidelines, and to abide by the actions and decisions of the group Owner and
Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND
�MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND
�MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
2005-01-19 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, José Miguel Ferreira
<jmf@j...> wrote:
> Roy,
I don't think its actually needed but it does guarantee a completely fresh
set of files which isn't a bad idea.
I have added a better 8 bit conversion to QTR so it should be indistinguishable.
(At least I can't show a discernable difference).    The file is half the size
though so that'll save on disk I/O time.
Roy
> Thanks,
> José
> -----Original Message-----
> From: Roy Harrington [mailto:roy@h...]
> of image -- Fixed
> Roy
> page.
> them short.
> the membership.
> Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE
TO YOU
EXEMPLARY
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF
THE
OR
OF ANY
OK, thanks!
José
Sent: mercredi, 19. janvier 2005 02:52
of image -- Fixed
<jmf@j...> wrote:
> Roy,
indistinguishable.
size
Roy
> Thanks,
> José
bottom
> of image -- Fixed
> Roy
> page.
> them short.
> the membership.
and
AND
TO YOU
EXEMPLARY
THE
OR
OF ANY
page.
them short.
the membership.
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
