UT7 Fading
2005-01-15 by Clayton Jones
Hello All, Last June I began experimenting with UT7 inks in a 2200. Using the slider controls I printed three of Paul's enhanced step wedges on Photo Rag paper as follows: #1 - with all controls at 0 (which I think is just the carbon inks K and Lt-K) giving a moderate warm color #2 - with cool toner settings for a neutral color #3 - with warm toner settings for a sepia color I taped a strip of matt board down the length of each ramp and put them on my windowsill along with other things being tested (on June 19th). I've been real busy over the past months and have only given them quick looks now and then. But tonight, after 7 months, I took a careful look and was surprised to find some fading, as follows: #1 - No toners - No sign of fading #2 - Cool toners - Slight fading, visible from 20% - 70% #3 - Warm toners - Extreme fading, visible from 5% - 100% Some questions come to mind: a) Paul (I hope you are reading this), you said recently something about the magenta in these ink sets being upgraded. Assuming these inks purchased last June had the older magenta, do you think the newer version will eliminate this fading? What about the cool toner ink in print #2? b) I recently (November 30th) purchased a UT7 set in 4 oz. bottles with the new ezfill carts. Will that have the newer magenta, and would you recommend I make a new set of prints for a new test? c) What does this test represent? The prints are on a south windowsill which is covered by an awning. They get a small amount of early morning and late afternoon direct sunlight as it peeks under the ends of the awning, and a full day of bright reflected daylight. Yes, it's a torture test, but the fact remains that they did fade and right beside them is an Eboni BO print that's been there 14 months and an Epson UC (grayscale mode) print for 16 months, both with no signs of fading. So the toner inks do fade in response to light. Whether this amount of light can be translated to 40 years in room light behind glass, or something like that, I don't know. Everyone will have to draw their own conclusions. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
