Digital BW, The Print
Posterization in red channel
2005-01-10 by Steve Kale
Hi. I am just working up an image from my new digital camera and have come across
something that is puzzling me.  The colour image looks great - no posterization and no
apparent clipping in any channel.  From the RAW file I used Capture One Pro with high
contrast setting and simply slid the RGB black point slider up to the left of the red
histogram and then processed (no other adjustments).  In PS, I then used the split
channels technique to work up a B&W version.  The image is of a sand dune against a dark
(blue) sky.  My problem is that the red channel appears (on screen - I have not printed it
yet) to be posterized in the sky.  I want to use the red channel because it is giving me the
dark sky.  Any ideas as to why this would be?  I can go back to the original RAW file if need
be.
Steve
(I have ordered the 3 channels as follows:  base Green at 100%, red on top at 90%, then
blue with pinlight for extra contrast on top at 40%.  Although the posterization is evident
just looking at the red channel.)
Re: Posterization in red channel
2005-01-10 by Nick H. Nugent
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale"
<stevekale@b...> wrote:
>... From the RAW file I used Capture One Pro with high
> up to the left of the red histogram and then processed
> is of a sand dune against a dark (blue) sky.  My problem
> printed it yet) to be posterized in the sky....
Have you tried NOT adjusting the red histogram? Then what file format
did you pass from Capture One to PS? What bit depth? I'm sure you may
have already looked at these variables but if all are ok then may be
it's just your monitor display properties. Just some thoughts.
--nick
RE: [Digital BW] Posterization in red channel
2005-01-10 by Paul D. DeRocco
> From: Steve Kale [mailto:stevekale@...]
> have come across
> the left of the red
> then used the split
> be.
If you have a very quiet camera, like a Canon 20D, and you make the mistake
of converting to an 8-bit image, and then apply a curve, you may be able to
see posterization. Noisier cameras provide enough dithering to break up the
bands. Make sure you use 16-bit mode, at least until you're finished with
any significant exposure or curve correction.
Ciao,               Paul D. DeRocco
Paul                mailto:pderocco@...
2005-01-10 by Richard Wolfson
hi Steve -
I don't work with Capture One so I can't help on that specifically. But
here is a trick that may prove helpful, probably in combination with
other corrective measures you may already have found.
Before you convert to b&w, use Select Color Range to select the blue
sky. Save this selection as an alpha-channel mask.
Then when you're editing your b&w image, use Load Selection to reload
that mask. This will re-select the sky. While the sky is selected, add a
curves adjustment layer (the selection will become the layer mask). By
manipulating the sky curve, you'll be able to adjust the tone of the sky
quite precisely -- without changing the sand dunes.
You'll want to do this in 16 bit mode. And if you do see any dithering
in the sky, a little Gaussian blur (while the sky is selected, of
course) will take care of it. Also, note that reloading the sky mask
will not work if you've cropped or resized the image since you saved it.
Hope this helps,
Richard Wolfson
Fine Art Photographer & Digital Imaging Consultant
> -----Original Message-----
> Sent: Monday, January 10, 2005 1:33 PM
> To: DigitalBlackandWhiteThePrint@yahoogroups.com
> Subject: [Digital BW] Posterization in red channel
> and have come across something that is puzzling me.  The
> colour image looks great - no posterization and no apparent
> One Pro with high contrast setting and simply slid the RGB
> black point slider up to the left of the red histogram and
> the split channels technique to work up a B&W version.  The
> channel because it is giving me the dark sky.  Any ideas as
> if need be.
> Steve
> 100%, red on top at 90%, then blue with pinlight for extra
> evident just looking at the red channel.)
Re: [Digital BW] Re: Posterization in red channel
Tiff at 16 bit.  I went back and redid it with the shadow warning on.  Seems
that the warning kicks in (when set to 0) well before the RGB (not red)
black point reaches any of the left most points of individual channel
histograms (is this understandable?  I mean I am adjusting the levels in RGB
but watching the 4 histograms overlaid on each other - RGB, R, G, and B).
The image is much better but the notion of visually dragging the RGB black
(and white) points to the edge of the histograms seems to be flawed.
> From: "Nick H. Nugent" <nghin@...>
> Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
> Date: Mon, 10 Jan 2005 21:08:10 -0000
> Subject: [Digital BW] Re: Posterization in red channel
> --nick
Re: [Digital BW] Posterization in red channel
1Ds MK II all work in 16 bit.
> From: "Paul D. DeRocco" <pderocco@...>
> Date: Mon, 10 Jan 2005 13:58:17 -0800
> Subject: RE: [Digital BW] Posterization in red channel
>> have come across
>> the left of the red
>> then used the split
>> be.
Thanks.  Will give this a go.
> From: Richard Wolfson <rw@...>
> Date: Mon, 10 Jan 2005 17:32:00 -0500
> Cc: <stevekale@...>
> hi Steve -
> Hope this helps,
> Richard Wolfson
2005-01-11 by Paul D. DeRocco
Well, it's hard to imagine a quieter camera than that, and it's with
low-noise images that posterization is more likely to be a problem. I wonder
if there was some operation in your workflow that's really performed on
8-bit data, even though it claims to be 16-bit. That's about all I can think
of.
2005-01-11 by Richard Wolfson
Maybe on a clear day in the desert (blue sky, sand dunes) there's just
not much red light coming from the sky?
Richard Wolfson
> From: Paul D. DeRocco [mailto:pderocco@...]
> Sent: Monday, January 10, 2005 7:41 PM
> it's with low-noise images that posterization is more likely
> to be a problem. I wonder if there was some operation in your
> workflow that's really performed on 8-bit data, even though
> it claims to be 16-bit. That's about all I can think of.
2005-01-11 by artistico7
have come across
the left of the red
then used the split
> be.
> Steve
Most scanner and digital camera technology today has problems
rendering certain shades of red correctly, meaning that several
shades as you see them will turn into a single hue when digitally
captured, which may not be obvious at first until you start playing
around with the curves and levels. I have had many problems with
this myself while scanning or photographing some of my artwork,
where the reds can turn out to be way off, particularly for a shade
very close to pure red and a bit towards yellow, which all becomes a
pure red in the scan or photo.
Hakon
www.hakonsoreide.com
mail@...
2005-01-11 by Steve Kale
Yes and hence my choice of the red channel to get a very dark sky.  I am
just surprised that I get a shadow warning when the black point is nowhere
near the edge of the red (or blue or green histograms).  Maybe I am missing
something basic here....I will keep experimenting.
> Date: Mon, 10 Jan 2005 19:49:27 -0500
> Richard Wolfson
2005-01-11 by Nick H. Nugent
Hi Steve,
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
> I am just surprised that I get a shadow warning when the black
> point is nowhere near the edge of the red (or blue or green
> histograms).  Maybe I am missing something basic here....I will
> keep experimenting.
There may be pixels that are clipped though you don't see them in the
histogram. Picture Window Pro has a High Histogram Expansion mode so
even a very small pixel count will become visible. Capture One may be
very much like PS in that the count for a particular pixel value is
shown as a percentage of a maximum value.  So though the slider is no
where near the histogram edge, there are pixels there.
I think Capture One may be performing an 8 bit operation there
because I have no other explanation for the posterization.
To verify this you may want to bring the red channel into PS as is in
16 bit and perform your histogram adjustment there to see if
posterization occurs.
--nick
