Digital BW, The Print
pixelation in B&W prints from 6 megapixel DSLR - unavoidable?
2004-04-07 by Howard Slavitt
I recently bought a Nikon D70 and am having lots of fun taking photos of my son and
printing them on an Epson 1200 with MIS VM inks.  (My 1200 is especially well calibrated
to the VM curves because it was the "model" that Paul Roark used to generate the curves
for this printer.)  One thing I've noticed from prints from this 6 megapixel DSLR is that,
unlike MIS VM prints I've done from scans of 6 cm x 9 cm color slides converted to black
and white in Photoshoip, certain shadow detail areas (especially my son's hair) end up
having large pixelation blocks (areas where there are large blotchy blocks of black ink).  I
notice these types of areas on prints larger than 8 x 10" (i.e. printed a 180 dpi) and to a
much lesser extent on some 8 x 10" prints (i.e. printed at 240 dpi).  I've noticed this from
other digital cameras, in particular my Canon G2.  My hypotheses as to what's causing this
is that: a. It is caused by the Bayer pattern, and/or b. It's caused by my overaggressive use
of the levels and/or curves commands in Photoshop to get a full range of shadow values.
It's not just in the prints but also noticeable at 100% view in Photoshop, although much
less visible in Photoshop than in the actual prints.  Has anyone else noticed this
phenomenon?  Any decent solutions for getting rid of it?  BTW, my work flow is to shoot in
raw, and use the Photoshop Camera Raw plug in.  I work entirely in 16 bit.  I am very
skilled in Photoshop.  I do not oversharpen.  Thanks for your help.  BTW, I love the D70.
I'm falling in love with photography all over again.
Re: pixelation in B&W prints from 6 megapixel DSLR - unavoidable?
2004-04-07 by Dave
Hi Howard,
The Epson printer drivers really should have 300-360dpi files to print properly.
Upsample your image to 360dpi to be safe--One resize with Photoshop bicubic is
fine, or do it in 2-3 incremental steps with bicubic if you want.
More likely, investigate the blotchy areas in Photoshop with the eyedropper tool--is
perhaps posterization occurring because of the levels/curves commands? If, for
example you find the entire blotch slammed to 0,0,0 or 100% K, it may be levels/
curves that are to blame.
Enjoy your D70! I'm definitely enjoying my D60 as well.
Dave
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Howard Slavitt"
ink).  I notice these types of areas on prints larger than 8 x 10" (i.e. printed a 180 dpi)
> and to a much lesser extent on some 8 x 10" prints (i.e. printed at 240 dpi).
2004-04-07 by John Vitollo
"Howard Slavitt" <howard.slavitt@s...> wrote:
> I recently bought a Nikon D70  BTW, my work flow is to shoot in
Photoshop Camera Raw does not suppport the D70 at this time...it will open the raw file
but as you can see the quality is not there yet.
2004-04-07 by Val Brunell
John...Thanks for the help with upsizing files.
I just got a D70.  As this is my first DSLR, I'm a little hazy on
dealing with the files.  I have done some test shots on RAW,
transfered the file from the camera to the PC using the Picture
Project software I got in the kit.  I then open the file with P/S CS
and save it as a TIF file for processing.  Is this right?...Val
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo"
in 16 bit.
2004-04-07 by Andre
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Val Brunell"
CS
If somewhere in your workflow you can convert your file to 16 bits
while still in raw mode that will help later on when you start making
adjustment in Photoshop.
I'm on a Mac so I don't know much about Picture Package. I'd use the Nikon software to
convert the raw files to tiffs in 16 bit of course.
John:
Actually, I'm working with a beta version of RAW that does support
the D70.  The quality of conversion is very good.  The problem I've
noted does not appear when printing to color.  I do the conversion
into 16 bit.  I'm pretty sure it's a Bayer pattern phenomenon, and/or
a result of overaggressive use of levels and curves.
Also, my terminology in my original post was mistaken.  I should have
said posterization/mottling of deep shadow/black areas.  The problem
is probably best described as mottling.
Howard
in 16 bit.
Re: [Digital BW] pixelation in B&W prints from 6 megapixel DSLR - unavoidable?
2004-04-08 by Max Clark
This question is very relevent to me as well, since I
experience the same problem on occasion.  I might
describe it as "solarization" in some darker/shaded
areas that have a continuous tone.
I am using scanned film files in PS CS.
I too have suspected that it may be the result of
being a bit too zeolous in my curve adjustments.
However, these curves are not usually very extreme at
all.
I need to take the time to print these images again
without the curves being applied to see what, if any,
difference it makes.
Congrats on the D70!  I am a happy F100 owner myself,
but the D70 looks very promising, especially at less
than $1k!
--- Howard Slavitt <howard.slavitt@...>
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway
http://promotions.yahoo.com/design_giveaway/
BTW, I didn't know that the Photoshop Camera Raw
plugin was supporting the D70 yet.  Is it?
Do you Yahoo!?
2004-04-08 by Steven Karafyllakis
Howard; IMO the likely culprit is overaggressive use of he
curves/level functions, as you supect. If that is the case, it
should show up in your histogram as moderate to severe 'combing' in
the lower end of the scale. Check for combing after flatening any
layers (including adjustments) and converting to 8-bit. That's what
your printer driver sees and prints, even if you are seeing a
respectable histo before flatening.
Steve Karafyllakis
http://www.stevekphoto.com
> John:
I've
and/or
have
problem
> Howard
Vitollo"
in
entirely
> in 16 bit.
