Digital BW, The Print
Scanners?
Scanners?
2004-02-19 by randyrancier
Well, from what I have been able to gather from those of you that
work with MF film, is that there is a clear advantage to using a
4000 dpi scanner over others.  Sounds like most of you prefer the
Nikon (8000) scanners.  Are there any other contenders or is there a
clear advantage that the Nikon has over the others?  Does Nikon make
any other MF 4000 dpi scanners or is the 8000 & 9000 it?
Thanks again,
Randy
Re: [Digital BW] Scanners?
2004-02-19 by Victor Landweber
Randy --
I presume by "others" you mean a high-resolution flat-bed scanner. I
believe that a properly used film scanner -- one dedicated to scanning film
-- will provide scans superior to those made with a flat-bed scanner of
similar specifications. Part of this may be superior optics; part may be
the interface of hardware and software that's been designed for a specific
purpose.
This being said, there are several reasons why I consider the Polaroid
SprintScan120 (available used on eBay and elsewhere) or the similar
Microtek ArtixScan 120tf (currently available from retail sources such as
www.bhphoto.com for $1700) to provide superior 4000 dpi scanning for
black-and-white negatives. These are:
1. The Polaroid and Microtek scanners use a diffuse light source; the Nikon
uses a highly collimated source. A diffuse source reduces the appearance of
dust and scratches. Nikon includes "Digital Ice" with their scanner which
is highly effective with dye-based films such as chromogenic
black-and-white films, but DOES NOT WORK with silver-image black-and-white
negatives (or incidentally with Kodachrome) . This may be the best reason
to prefer a Polaroid or Microtek scanner to the Nikon.
2. The Nikon scanner uses a dimmer light source than the Polaroid or
Microtek so that its lens must work at a larger aperture. However excellent
the Nikon optics may be, the large aperture provides less depth of field so
that unless the film is held flat in a glass film holder, normally buckled
film is likely to show some loss of sharpness at its edges or corners. The
smaller aperture lens in the Polaroid or Microtek scanners provides a
satisfactorily sharp image all the way to the corners even with film held
in a glassless carrier. The advantage of a glassless carrier is that you
only have the two surfaces of the film to keep clean instead of the six
surfaces of film plus two pieces of glass. The dust that may appear on a
Nikon scan is additionally problematic since the Nikon's collimated light
source will project it more sharply than would the Polaroid or Microtek's
diffuse source.
3. There have been reports that scans made with the Nikon 8000 may show
banding in areas of even tonality if the scanner is used in its high-speed
mode which I believe scans three lines at a time. I don't know if Nikon has
remedied this in the 9000. The banding is eliminated if you turn off the
high-speed mode so that scans are made one line at a time, but then a scan
takes three times as long. There is no such problem with the Polaroid or
Microtek scanners.
4. A few more mundane considerations: the Polaroid or Microtek scanner is
smaller, quieter, and cheaper. My Polaroid SprintScan 120 came with the
full version of SilverFast AI software which I've updated to the latest
version. The current version of SilverFast is stable and powerful and
includes remarkably satisfactory dedicated profiles of dozens of
black-and-white films.
I went through a similar decision process prior to buying my Polaroid 120.
Even though Polaroid has discontinued their line of scanners, my SprintScan
120 continues to provide superior scans; it has never required warranty
service; and I remain satisfied with my purchase.
Hope this has been useful.
-- Victor Landweber
>Thanks again,
>Randy
2004-02-19 by Anthony G. Atkielski
randyrancier writes:
There's a clear advantage to using a scanner intended for MF, no doubt
about that.  The higher the dpi, the better, all else being equal, but
you do need to look at the quality of the pixels scanned, as well as
their number.
> Sounds like most of you prefer the Nikon (8000) scanners.
I like mine but I haven't tried others (although I've seen results from
others).  The Imacon scanners work very well, but they are much more
expensive than the Nikon; other results I've seen from other desktop
scanners don't impress me that much.  Overall, I'm very pleased with the
Nikon.  Not only is it 4000 dpi, which is pretty good, but the pixels
are of high quality.
2004-02-19 by Colin & Linda McKie
Hi Randy,
We looked at the same things a few months ago and bought the Minolta
Scan Multi Pro. This does MF up to 6x9 at 3200ppi and 35mm at 4800ppi.
In a lot of searching on the Web we found less moaning about the Minolta
than the Nikon apart from the software, which has now been improved, and
I never intended to use anything but Vuescan anyway. The main advantages
of the Minolta are better depth of field and better film carriers as
standard. The claimed Dmax figures are as daft as everyone else's and
hardly relevant for B&W anyway. We have found that the Scanhancer
diffuser gives an improvement in apparent grain with fine grain film (eg
Pan F) but not quite so much on Delta 3200 (which we use for pinholes).
Whichever scanner you choose, you should use 16 bit files as far as
possible for B&W, which means you need lots of computing power, memory
and storage space. A 120 film scanned at 3200ppi comes to about 1.5GB!
HTH,
Colin
http://www.travelling-light.net/
> Thanks again,
> Randy
Randy, Colin, et. al. --
I also looked at the Minolta when deciding about a scanner purchase. I read
that the Scan Multi Pro always sharpens a scan, even when it seems you've
disabled sharpening in software. It may be that  a sharpening routine is
built into its hardware or into its driver, but it this is the case it is
so serious a limitation as to eliminate the Minolta from further
consideration. Sharpening should always be applied as the last step after
image sizing and before printing. Otherwise you will find yourself
manipulating, and likely exaggerating, the inevitable artifacts produced by
sharpening -- doubtlessly detrimental to your images.
-- Victor Landweber
At 11:18 PM 2/18/2004, you wrote:
>Hi Randy,
>We looked at the same things a few months ago and bought the Minolta Scan
>than the Nikon apart from the software, which has now been improved, and I
>never intended to use anything but Vuescan anyway. The main advantages of
>hardly relevant for B&W anyway. We have found that the Scanhancer diffuser
>gives an improvement in apparent grain with fine grain film (eg Pan F) but
>possible for B&W, which means you need lots of computing power, memory and
>HTH,
>Colin
>randyrancier wrote:
>Well, from what I have been able to gather from those of you that work
>with MF film, is that there is a clear advantage to using a 4000 dpi
>scanner over others.  Sounds like most of you prefer the Nikon (8000)
>scanners.  Are there any other contenders or is there a clear advantage
>that the Nikon has over the others?  Does Nikon make any other MF 4000 dpi
>Thanks again,
>Randy
Hi Victor,
Where did this come from? I have certainly never heard of this, and
there is no hardware sharpening going on. What the Minolta driver does I
neither know nor care. Having said that, I would take issue with the
flat claim that "Sharpening should always be applied as the last step
after image sizing and before printing.". We use Photokit Sharpener,
which is a 3 step sharpening workflow. These steps are capture, creative
and output, and when used with Photoshop CS allow sharpening via layers
on 16 bit files. The output sharpening is certainly applied after final
sizing, but the capture is applied after spotting and any noise
reduction, and the creative is optional and can be used at any time.
Cheers,
Colin
http://www.travelling-light.com/
> -- Victor Landweber
Re[2]: [Digital BW] Scanners?
Colin & Linda McKie writes:
Sharpening should always be the last step, for two reasons: (1) it
degrades image quality; and (2) the degree of sharpening required
depends on the exact use of the final image (printing or display, type
of printer or press, reproduction size, dot gain, screen frequency,
etc.).
> We use Photokit Sharpener, which is a 3 step sharpening workflow.
You can use whatever you want, but sharpening should still be the very
last step.  Archived images should never be sharpened, for the reasons
already stated above.  Scans should never be sharpened, either.  You
only sharpen just before you print or display (that is, only when
preparing a specific copy of an image for printing or display).
Victor, thank you so much for the information, so many others get
off on tangents.
No I am only considering film scanners.  From what your saying
sounds like the old debate of difussion vs. condensor enlargers.  I
will probably be shooting primarily chromogenic BW film, but I will
also be doing a lot of color; I would also like to scan some of my
old BW negs and would like to be able to have the option to shoot
and develope convientional BW film; would the Poloroid and Microtek
scanner work well for all of these applications?  Also, if Poloroid
isn't supporting these scanners, is there any problem getting them
serviced if I was to pick up a used one or should I stick with
Microtek at this point, in your opinion?
Randy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Victor
Landweber <victor@l...> wrote:
> Randy --
I
scanning film
scanner of
may be
specific
> purpose.
Polaroid
similar
such as
for
the Nikon
appearance of
scanner which
and-white
reason
or
excellent
field so
buckled
corners. The
provides a
film held
that you
the six
appear on a
collimated light
Microtek's
> diffuse source.
show
high-speed
Nikon has
off the
then a scan
Polaroid or
> Microtek scanners.
scanner is
with the
latest
and
Polaroid 120.
SprintScan
warranty
> -- Victor Landweber
there a
make
> >Thanks again,
> >Randy
Wow,  How much RAM do you need for this??  Does my 2.4Mh processor
have evough umph to handle it, or will I need to upgrade?
Randy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Colin & Linda
McKie <colinmckie@x> wrote:
> Hi Randy,
Minolta
4800ppi.
Minolta
improved, and
advantages
as
and
film (eg
pinholes).
as
memory
1.5GB!
> HTH,
> Colin
that
there a
make
> > Thanks again,
> > Randy
2004-02-19 by jnhugo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Victor Landweber
> Randy --
I
scanning film
scanner of
may be
specific
> purpose.
Polaroid
> SprintScan120
I love Victor Landwebers work-I've watched your stuff for at least 30
years-right?
Anyway, for all the reasons listed by victor I also purchased the
Polaroid for my work at home--not as good as drumscans but not bad
either. I bought the Nikon for the lab at work at it gives by far and
away much better scans-almost no comparison- than the polaroid- the
nikon scanware is much more flexible and I think the Scan software
that came with the polaroid ( i paid extra for it)is horrible -the
polascan isn't too bad but no real flexibility-good automatic scans
(based on histogram)- iprobably shouldn't post this as I am
considering selling the SS120
jack (no charge)
Randy et. al. --
It's exactly the same old diffusion vs. condenser enlarger discussion. My
early darkroom prints were made with condenser enlargers, but after ten
years or so of photographic printing I discovered the benefits of using an
enlarger with a diffuse light source -- improved highlight separation was
the major improvement, but softer, more easily spotted dust was also a plus.
The reasons to prefer one scanner over the other becomes less certain since
your present work is largely with color and B&W chromogenic films. However,
I believe you'd find the Polaroid/Microtek scanner to be the preferred
device for scanning your old negatives, old Kodachromes, as well as any new
work you might do with silver-image film. I felt certain about purchasing
the Polaroid since I have an accumulation of many years of conventional B&W
negatives, quite a few Kodachrome slides, and I continue to expose a fair
amount of 400-speed Tri-X. The Polaroid/Microtek scanner is also capable of
producing fine scans from chromogenic films though this wouldn't be a
reason to prefer the SprintScan over the Nikon scanner which should be
equally excellent at this particular task.
If you can find a dealer with a new Polaroid SprintScan 120, I believe that
Polaroid continues their warranty support. I understand that paid,
out-of-warranty support is also still available. Even so, if I were
replacing mine with a NEW unit, I would seriously consider buying a
Microtek 120tf. I understand that the Polaroid units were actually
manufactured by Microtek under contract to Polaroid, and the 120tf should
be the same scanner.
On the other hand, saving money is also a virtue, and a purchase decision
might also hinge on the prices found on eBay where I see that recent sales
of the Polaroid 120 have been for $1750 NEW and $1250 MINT. As I wrote
previously, the Microtek is available for $1700 NEW from www.bhphoto.com.
The software package that comes with the scanner might also influence your
choice. SilverFast software is bundled with the Microtek 120tf. The
Polaroid 120 comes with either of two packages: Polacolor Insight alone or
SilverFast AI in addition to Insight. I've tried Insight, SilverFast, and
VueScan and much prefer the control and flexibility of SilverFast. The
version provided with the SprintScan 120, however, is v.5 or v5.2 or v.5.5
all of which include a few non-working features. I found it very much worth
spending $77 to upgrade to their current v.6.2 in which everything works.
Should you decide to buy a full, after-market copy of SilverFast, it will
cost you $424, so it's worth making sure it's included with whatever
scanner you buy.
Hope this helps.
-- Victor Landweber
>off on tangents.
>Thanks
>Randy
On a Windows machine, at least 1.5 GB total RAM for 6x6 color images
scanned at 4000 dpi and 16-bit color.  The images themselves are about
470 MB.
> Does my 2.4Mh processor have evough umph to handle it,
Processor speed isn't nearly as important as RAM.  And 2.4 GHz is fine.
2004-02-20 by Victor Landweber
Jack --
Thanks for the boost. Yup, 30 years at least.
Have you tried the latest SilverFast upgrade? V6 looks pretty much the same
as V5, but everything works and it doesn't crash. SF includes flexible
exposure and tonal response adjustments, convenient 16-bit scans, and the
best curves adjustment dialog I've seen anywhere.
-- Victor Landweber
>years-right?
>jack (no charge)
