I see it under fluorescent lighting, but really, the paper itself has
a bit of a yellow cast and is really what I think is giving the
prints the color cast and not a typical inkjet metamerism. If you
walk around with a hp print and a traditional b&w print for reference
you will see it though.
Yeah, that's the rub. With hp paper and Wilhelm results you can
argue 100+ years, with anything else you are stuck making some flimsy
personal replacement guarentee or something.
Mounting is a problem though. For archival purposes most people
don't like photos mounted even though they hang much better when they
are, especially these hp prints. Maybe hang mounted prints and give
the buyer the option to get it unmouted if they prefer. Isn't this
an issue for anyone else? In general, are people still dry mounting
or just hinge or corner mounting photos?
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Radimus"
<radimus@p...> wrote:
> Mark, under what kind of lighting are you seeing a green tint? And
> are you seeing it with all of your prints or just some. I have not
> had much chance to crank out a lot of B&W on my 7660 yet, but what I
> have done has shown no color cast that I can see under fluorescent,
> incandecent, or natrual light.
> Nick, Wilhelm tests show the Ilford Classic Galerie to be good for
> 20-30 years, and HP Premium Plus for about 70 years. Although I am
> very interested to hear what Paul finds in his fade tests.
> Rad
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Nicholas
Hartmann
> <POLYGLOT@E...> wrote:
> > >Ok, made a bunch of 7660 prints on the hp Premium Plus glossy
that
> > >look really good. The driver is very accurate and the tonality
of
> > >the prints is great. Everyone I've showed them to thinks they
look
> > >better than my 1160 MIS VM mw prints (hard to accept given all
> > >effort that went into making them)... and this is after I go out
of
> > >my way to point out the slight greenish tint under certain
lighting.
> > >The depth of shadow detail is significantly greater than I've
seen
> > >out of pigment prints.
> > >The thing that concerns me is that the paper seems to like to
buckle
> > >and curl so just hanging the prints behind a matt is not going to
> > >work. How has anyone mounted this stuff? Is that funky weird
stuff
> > >on the back a problem?
> > Mark -
> > I haven't mounted any, but I did find that they can be flattened
> slightly
> > by using a dry-mounting press on the lowest possible temperature.
More
> > experiment would probably determine the correct time/temperature
> > combination, but the ink/paper combination appears to be robust.
> > One way to get around the problem entirely, and to make even
> better-looking
> > prints, is to use Ilford Galerie Classic paper. I tried some over
> > weekend: it's another swellable-polymer surface so it absorbs and
> > encapsulates the dye inks and _should_ therefore be fairly
durable.
> It also
> > swells MUCH less than the HP and has better shadow detail and
really
> > imperceptible gloss differential. If somebody (Paul, are you
listening?)
> > will please tell me that this stuff will last at least as long as
a
> toned
> > black-and-white RC print, I'm off to buy a couple 100-sheet boxes
> and try
> > to unload all the HP Premium Plus I stockpiled...
> > -- Nick
> > NICHOLAS HARTMANN
> > Technical and scientific translator
> > (414) 271-4890
> > nh@n...
> > http://www.nhartmann.com
