Digital BW, The Print
1280 / CFS nightmare
2004-01-22 by Harry Saddler
I just switched my 1280 from MIS VM to MIS UT-2/Eboni, using a new,
prefilled set of MIS CFS carts & tubes. I cannot get clean nozzle
checks. I did windex-on-pad, windex-under-head,
windex-nozzle-injection, MIS's de-foaming procedure, several cycles of
3 cleaning passes followed by three purge prints. For my labors, one
color is now not printing at all, and the black cart just squirts ink
on the edge of the page. I must be doing SOMETHING wrong!?
Harry
Re: 1280 / CFS nightmare
2004-01-23 by Bob Michaels
Any problems in a system with a CFS requires you first substitue
original Epson carts to determine if you have a nozzle problem or cart
problem. Otherwise you'll be chasing a nozzle problem when you really
have a cart problem. Your's sounds like it could be a cart problem but
you can tell for sure if it prints fine with Epson carts. Call MIS and
you'll eventually ending up talking to Bob, the owner. He'll probably
tell you to disconnect the cart from the tube, suck out all the ink
from the bottom and bottom refill with exactly 9cc's of ink (for a
1280 cart), let sit for a few hours then try it. CFS carts need the
right amount of air in them. I love my MIS CFS but they can be a bit
quirky to set up.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Harry Saddler
> Harry
Re: [Digital BW] Re: 1280 / CFS nightmare
2004-01-23 by Harry Saddler
Since my original post, I went to MIS' site and followed the
instructions for introducing an "air break" into the carts. Suddenly,
two problematic colors started printing fine. But two still have lines
(indicating a clog, probably) and one doesn't appear at all. I'm
letting it rest, and if it's still NFG, I'm going to try to flush out
the offending nozzles by injecting Windex, then doing the de-foaming &
air-break routine again. Then I'm going to take an icepick to the
nozzles. Ok, maybe not that last step...
I did put Epson carts in to try to get things back to an unclogged
state, but they wouldn't unclog, so I took 'em out and did the
Windex-inject trick. But then I didn't put the Epson carts back in,
cause I figured they're unsealed and I don't know what effect that has.
Harry
> quirky to set up.
> Bob Michaels
>> Harry
> Please visit the Group Homepage to check the Files, and other
> resources as they are often being updated.
> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> If you wish to receive no emails or just a daily digest, or you wish
> to unsubscribe, please edit your Membership preferences by visiting
> this same page.
> Please follow these basic guidelines:
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> - Good manners are required at all time. No personal attacks or
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> - By posting on this forum you agree to abide by the group rules and
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
> Files section:
> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER”
> AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> Buy Ink Cartridges or Refill Kits for your HP, Epson, Canon or Lexmark
> Printer at MyInks.com. Free s/h on orders $50 or more to the US &
> Canada.
> http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/ucIolB/TM
> To visit your group on the web, go to:
>  DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
>  http://docs.yahoo.com/info/terms/
Harry, use only the Epson carts till you've got the nozzle clog
problems solved. That way you know you have good carts. I find the
Epson ink to be best at unclogging nozzles. Don't hesitate to reuse
them as they have poppet valves which make them reusable.
BTW, Bob at MIS says their $5 Chinese "el cheapo" color carts work
like the Epson ones in this regard. I have some but have not tried to
use them for this yet.
Bob Michaels
> Harry
> > quirky to set up.
> > Bob Michaels
cycles of
> >> Harry
> > this same page.
to
> > keep them short.
from
> > Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
> > Files section:
"OWNER"
> > AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> > LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE
PRINT
> > Canada.
> > Yahoo! Groups Links
2004-01-23 by Scott Graham
I've found that I can keep Epson cartridges (for the 1200) a fairly long time and using
them to test the printer.  I put the MIS steel plugs in them after I am done using them
on the MIS carts.
Good Luck
Scott
2004-01-29 by marc hornung
When changing ink types it is always good to run some cleaning cartridges first, that is before introducing the new ink to the print heads. This helps prevent any reactions between the inks. MIS carries a new cleaning solution that seems to work much better then the windex, the product is listed at the bottom of the accessory web page its called MIS-fluid. Soaking the park pad and letting the heads sit in it allows the fluid to wick up into the print heads.
M
quirky to set up.
Bob Michaels
> Harry
Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
- As threads develop, trim off excess portions of earlier messages to keep them short.
- Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
- Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
2004-02-16 by Harry Saddler
A status report, just in case this was keeping anyone up nights:
I finally contacted MIS, and they immediately sent me a new prefilled
cart & tube set, which solved the problem. Finally! They're examining
the old one to find out what the problem was, presumably to keep it
from happening again.
Thanks, everyone at MIS -- excellent customer service!
Harry
