Digital BW, The Print
Is the X-Rite 810 really the best solution?
2003-09-26 by Dimitri Katsaros
Hi all,
I took another look at the specs on the 810 and found that it also
measures transmissive densities. Now, since I assume everyone is
using paper, why would it be a good idea to pay for this extra
functionality? Also, I recently learned that photographic
densitometers are calibrated for photo dyes (CYM) instead of process
dyes (CMY) so doesn't this also present a problem?
Dimitri Katsaros
Re: Is the X-Rite 810 really the best solution?
2003-09-27 by Antonis Ricos
Dimitri,
the 810 happens to be a commonly found unit in the used market, that's why
it's popular. Otherwise, as you note, the extra transparency features are not
particularly useful - unless you also process your own film and have an
interest in calibrating that aspect of your photography.
As for the dyes, you are right again: these are densitometers, not spectros and
they are meant for photo dyes. But in the case of digital bw printing the 810 is
mostly used in  so-called "visual" mode, ie. it doesn't report color values but
overall density.
It is currently cheaper to buy a used 810 than a bw reflective-only
densitometer with similar specs; i.e. one that is as consistent in its readings
over time, as solidly built and as capable of reading into the deep shadows as
the 810.
The Eye One is the next step up, perhaps, but at  3 or 4 times the expense. It
makes sense if one is also calibrating digital color  processes.
Antonis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Dimitri Katsaros"
<dcka@y...> wrote:
> Hi all,
> Thanks
> Dimitri Katsaros
