Digital BW, The Print
scanning&printing
scanning&printing
2003-08-12 by njhilite
Can anyone help me on this issue.
I have an Epson2200 inkjet printer and would like to scan my images
to be able to print them.
What scanner should I get?
I let the Film develop. So, do I scan from the negatives and therefor
need a 35mm scanner?
And how does it work from here? How do I get a picture printed out
from my scanned negatives? How do they get converted into an actual
image that can be edited with Photoshop for instance?
And finally, which scanner should I get?
Thanks.
Re: scanning&printing
2003-08-12 by kiwikale
Huge topic but here is a start that perhaps others can build on.  Yes you scan the
negs (or positive slides for that matter).  File/Import from within Photoshop will kick
off your installed scanner driver (eg the TWAIN driver  or Vuescan or Silverfast should
you decide to use these scanner driver software packages).  Your scanner will come
with instructions on how to set up the scans (eg placement and software settings).  It
is relatively straightforward to get a simple scan, much more complex as you begin to
use the more powerful features.  The images will appear as positives in PS for you to
work on and then print.  Scanning negs is technically more complex for a scanner
than slides and often scanner software packages (eg Silverfast) have built in profiles
for the type of film you are using.
A good starting point for deciding which scanner is your budget.  I use an Epson
2450 (now replaced by the 3200) which is a flatbed scanner with film holder units for
mounted or strip film.  It does a very ok job considering its price (and has the
advantage of also being able to scan docs for other purposes).  But if you really want
the best scan quality you ought to think about a dedicated film scanner.  Check your
price point first.
This forum is focused on issues concerning B&W Prints.  There are probably other
forums which are more relevant to scanners and scanning techniques, but the
following website has a useful tutorial on scanning...
http://www.scantips.com/
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "njhilite" <njhilite@y...>
> Thanks.
Re: [Digital BW] scanning&printing
2003-08-12 by Stan McQueen
Probably, although you might get sufficient resolution from one of the
newer flatbed scanners, such as the Epson 3200, to be able to make small
prints from 35mm. Basically, you need a scanner that will scan negatives
and transparencies. Scanners that do this are either dedicated film
scanners or flatbed (desktop) scanners with a transparency adapter.
The scanner software will produce a file in TIFF or JPEG format that you
will input into Photoshop for editing and printing.
It depends on what your needs are. Everybody has their own favorite
scanner. I use a Polaroid Sprintscan 4000 film scanner for 35mm and a
Polaroid 45i for 4x5 and medium format.
>Thanks.
Hope it helped.
Stan
Photography by Stan McQueen
http://www.smcqueen.com
2003-08-12 by johngeyles
Vuescan works as a Photoshop plug-in (and not just as a stand-alone)
now ?
John
2003-08-13 by wrightdda2001
totally agree on the 3200 or the Polaroid Sprintscan. I use a 120 but
had a 4000 and you can get 4000's pretty cheap (350) on ebay which is
a bargain for a 16bit 4000 cpi scanner - its an awesome scanner for
35mm film or transparencies, especially when combined with
silverfast. One last point, you dont need Silverfast, the polaroid
scanning software, while simple, gives an excellent result.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Stan McQueen
therefor
small
negatives
that you
a
> >Thanks.
> Hope it helped.
> Stan
RE: [Digital BW] scanning&printing
2003-08-13 by John Swain
I too have a Sprintscan 4000 and highly recommend it over the Nikon
Coolscans I had previously.
My understanding is that resolution is not the issue when choosing a film
scanner; it is Dynamic Range.  The Polaroid is much better in this respect.
Flatbeds don't even come close - or didn't when I bought mine 2 years ago.
My theory may be a little shakey but I have found my results back this up in
practice as well.
Only problem you might have is Polaroid going bust - not sure if you can
still get them.
See these articles http://scantips.com/basics14.html
http://scantips.com/chap3.html  for some more information.
js
Sent: 12 August 2003 20:25
>Thanks.
Hope it helped.
Stan
Please visit the Group Homepage to check the Files, Bookmarks, Polls and
other resources as they are often being updated. The page is at:
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
Please follow these basic guidelines:
- Include your full name with your message.
- Include the address of your website, if you have one.
- As threads develop, trim off excess portions of earlier messages to keep
them short.
- As the topic of a thread changes remember to change the subject header.
- Good manners are required at all time. No personal attacks or flames
- Complete your Yahoo profile.
- Before posting a question, search the message archives and the various
resources on the homepage.
Re: [Digital BW] Re: scanning&printing
2003-08-13 by Stan McQueen
Quoting johngeyles <jge@...>:
> now ?
Not as far as I'm aware. Vuescan has an option that will launch Photoshop
or other editing program when the scan is finished, but I don't think the
reverse is true (Photoshop launching Vuescan).
Stan
Quoting John Swain <john.swain@...>:
> scanner; it is Dynamic Range.\ufffd The Polaroid is much better in this
> respect.
> ago.
> in
> practice as well.
> still get them.
> http://scantips.com/chap3.html\ufffd for some more information.
> js
> -----Original Message-----
> From: Stan McQueen [mailto:stan@...]
> >Thanks.
> Hope it helped.
> Stan
> same
> page.
> keep
> them short.
> Yahoo! Groups Sponsor
>   ADVERTISEMENT
> same page.
> keep them short.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Sorry about the previous message. I clicked on "Send" accidentally.
I've never had a Nikon scanner, but I am very happy with my two Polaroids.
> respect.
> ago.
> in practice as well.
It's probably a combination of the two factors: resolution and dynamic
range. Flatbeds rarely have the actual resolution they claim. And dynamic
range is rarely what is claimed, in any scanner.
> still get them.
Polaroid is in Chapter 11 reorganization. They are still operating and
producing and selling products.
Stan
Re: RE: [Digital BW] scanning&printing
2003-08-13 by mfaphoto@optonline.net
I have an Epson Perfection 3200 scanner. On the message board for the 3200, some people have been knocking it saying that it is not sharp enough for 35mm. Well, personally I think it is and I'm pretty critical. I have been doing photography for about 38 years and work with all formats from 35mm to 4X5. Now, I don't have a film scanner and have no experience with them. I bought the 3200 to mainly scan my 120 and 4X5 film as I mostly work in those formats. For those it does a great job.
When I work with 35mm, I usually print 8X10 or 11X14. At those sizes, I feel that I get everything that is in the film with the 3200. If you are going larger, then maybe you will need another scanner, I don't know. However,  you might give the 3200 a try. If you don't like it, you can always return it. I don't believe that there is another flatbed scanner out there of it's quality for the price.
See the following review for more information.
http://www.photo-i.co.uk/Reviews/interactive/Scanners
/Epson_3200/page_10.htm
By the way. I use SilverFast Ai 6.0 to scan and always use Unsharp Masking to optimize sharpness. It really makes a big difference. If you use the Epson software, I recommend checking the unsharp mask box  with each scan.
Russ Martin
I just tried the link to the review of the Epson 3200 scanner that I posted in the previous message. It didn't work. Evidently, Yahoo's computers did not turn the whole URL into an active link. So, Just highlight and paste thw whole URL into your browser window and it will take you there.
http://www.photo-i.co.uk/Reviews/interactive/Scanners/Epson_3200/page_10.htm
Russ
2003-08-13 by Sam A. McCandless
At 11:12 PM +0100 7/10/02, ListServer@... wrote:
>ADDRESS FOR POSTING CONTRIBUTIONS
>  filmscanners@...
>ADDRESS FOR COMMANDS eg 'subscribe','unsubscribe' etc
>  listserver@...
>HUMAN ASSISTANCE (last resort please!)
> filmscanners-owner@...
>HOST WEBSITE
>http://www.halftone.co.uk Tony Sleep Photography
Not that I object to seeing njhilite's questions or responses to
her/him here, but Tony Sleep's filmscanner list (addresses above are
from his web site) is a good place to ask questions about film
scanners. He shoots B&W and so do many of the active subscribers to
his list.
Sam
Sam McCandless
>Thanks.
>[njhilite@...]
