Digital BW, The Print
Any New Film Scanners Coming?
2003-05-30 by murph278
Does anybody know if there are any new medium format film scanners in the works.
The current line-up is getting long in the tooth and want to know before I plunk
down the dough.  I've been renting a Nikon 8000 ED which has been working great
for my B+W work.  However, CCD's (& CMOS) technology seems to be moving so fast
that I'm suprised no new film scanners have been announced with greater resolution,
faster, etc.  Any info would be appreciated...thanks...
-Murph
RE: [Digital BW] Any New Film Scanners Coming?
2003-05-30 by Austin Franklin
Murph,
> The current line-up is getting long in the tooth...
I'd be interested in knowing what about the current line-up is long in the
tooth in your opinion?
> moving so fast
> greater resolution,
They probably won't get any higher resolution than a 10k sensor which, over
a 2.25" span is why the current crop are 4k scanners), and they probably
won't get much faster.  CCD properties haven't gotten such that they require
less light to register the density of the film...that's a noise issue...
You are scanning, and have an exposure time of X, and scan, say, 10,000
lines...so it's quite deterministic to see that 10,000 times X is your
minimum scan time.
Do you really need more than 4k SPI?
Austin
Re: [Digital BW] Any New Film Scanners Coming?
2003-05-30 by Carolyn Frayn
On Thursday, May 29, 2003, at 08:48  PM, Austin Franklin wrote:
snip
Dunno, do we? ;)  I'd like an 11k spi drum scanner but isn't going to
happen ...With the new Minolta 35mm film scanner announced at 5400
spi... I'd assume 120 is next. and so on and so on...
Carolyn
Hi Carolyn,
The sensor size is limited in width to what is available from the sensor
manufacturers.  Minolta doesn't make it's own linear CCD.  I don't know what
they use for a sensor in that unit...yet...but it's only 5300 sensing
elements wide, and it is tri-linear (RGB).  To scan 120, they would need a
sensor 2.25 times wider...
We also don't know how good the 5400 SPI is...as with their previous
scanners, it seemed to me that tests showed that they didn't live up to
their purported specs.
What is the "and so on and so on"?  You are physically limited in the number
of sensing elements you can get over a particular span, where you don't get
a substantial increase in noise.  Second, the larger (wider) the sensor, you
run into physical limitations of the scanning mechanism, as in optics and
scanning it self.  That all ain't gonna be cheap.
These are no small tasks, and I just don't see a market that makes this type
of development worthwhile (for a bit company that is), and I don't see
people willing to pay for it either.  Let's see how the Minolta scanner
does...  I'm sure someone will get one, and some tests will pop up...soon...
Austin
2003-05-30 by Bob Michaels
Austin: I'm certainly a technical type person. But I remember some guy
named Moore back 30 years ago who came up with this idea about
computers getting twice as fast and half the size every 18 months or
something like that. I said "sure, for a few years maybe". (I didn't
invest in Intel back then either) When someone told me that someday
computers would be so small they could be battery powered and we could
 carry them around in our hands, I didn't believe him either. Now, I'm
believing just about anything. Like I opened, I don't understand this
stuff but I wonder if your constraints are realistic. Maybe in 2003,
but 2004?
Bob Michaels
know what
need a
the number
don't get
sensor, you
optics and
this type
up...soon...
> Regards,
> Austin
Hi Austin...
Once again I've been debating the microtek/minolta/polaroid specs...
the polaroid was out as I couldn't find one, the microtek is the same
as the polaroid so I may go that route, but have to bring it up from
the States... and the new minolta was just a curiousity, same light
source, higher res...
an old expression...
> don't get
> sensor, you
> and
No, but as time marches on many things become doable, smaller, and
cheaper.. and so on. Since they came out with a 5400 spi scanner for
35, I assumed that the 120 wouldn't be far along.
> this type
Those that can, buy an Imacon.
> up...soon...
I'm sure... I'm very curious about that manual focus knob though ;)
Best,
Carolyn
2003-05-30 by Anthony Atkielski
Murph writes:
> and want to know before I plunk down the dough.
It doesn't matter how long in the tooth they are as long as they do a good
job.
Bob writes:
> But I remember some guy named Moore back 30 years
> ago who came up with this idea about computers
> 18 months or something like that.
Moore's law does not apply to analog devices, and both scanners and
electronic ("digital") cameras are analog devices.  A digital device such as
a microprocessor or memory chip doesn't have to understand anything except
on and off, and so tolerances are generous.  In an analog device, every
electron affects the results, and so the worse the tolerances, the worse the
results.  For this reason, analog devices cannot be improved at any speed
coming even remotely close to obeying Moore's law.  And digital photography
is currently dependent on improvements in analog devices; that has been what
kept digital photography so long in coming, and that is what prevents it
from matching film even after years of development.
> When someone told me that someday computers would
> either.
I did, but I also predicted that most people would still be using computers
with real keyboards and large displays, and I was right.
> Maybe in 2003, but 2004?
2004 will be practically identical to 2003, for digital photography and
scanners, just as these fields have been in previous years.  When you look
past the hype (not an easy task, since the hype completely obscures the view
most of the time), you see that progress really isn't as fast as it is
claimed to be.
Carolyn writes:
Since they never quite managed 4000 dpi for 120, I wouldn't hold my breath.
Additionally, each increase in resolution is a smaller improvement than its
predecessor in scanners.  A resolution of 4000 dpi is only a small
improvement over 2700 or 2900 dpi, despite the apparent jump.  A resolution
of 5400 dpi represents an even tinier jump.  Furthermore, unless you shoot
everything on a tripod on fine-grained film, you may not see any difference
at all between 4000 and 5400 dpi, and you may not even see a difference
between 2700 and 4000.
2003-05-30 by Martin Wesley
To: <digitalblackandwhitetheprint@yahoogroups.com>
Sent: Thursday, May 29, 2003 8:34 PM
Subject: Re: [Digital BW] Any New Film Scanners Coming?
> snip
Carolyn,
Supposedly B&W films resolve to a dpi equivalence of 3000 to 7000 dpi. I
imagine that in real world situations you have much less than that by the
time you take into account optical issues when you shoot. Some people
suggest that about 2500 dpi true optical resolution would be plenty for B&W
film scanning. So a true 4000 dpi scanner should really do the job.
The problem is that the resolution calculated from sensors or samples per
inch don't correspond to actual optical resolution. The Nikon 8000 scanning
at 4000 dpi tested out at ~2,900 dpi. optical resolution but that should be
very good for our purposes. I would guess that the Polaroid and Minolta MF
scanners are similar. Comparing Polaroid 120 scans to scans of the same
negatives on a Howtek 4000 which has an optical resolution of ~3500 dpi
there is a difference. While I like having that extra bit of data, I am not
sure the final print is better. If anything it may just be making it easier
to get a print I like.
If the next generation of 5400 dpi CCD scanners can deliver 75% as optical
resolution then they would be at 4000 dpi and that would be very nice!
The Aztek Premier drum scanner gives an optical resolution of over 7000 dpi
from an 8000 dpi scan so you wouldn't lose a bit of information on the film.
Not quite sure how you would handle files that big though. Not to mention
that you could get a nice new car for the price. <G>
Martin
Anthony,
> Moore's law...
Not to nitpick, OK, well, I will...Moore's purported "law" is not a law what
so ever.  It was an assertion.  An assertion that most everyone in the field
was well aware of long before Moore heralded it in some, otherwise not
notable public statement, and for some silly reason, he is credited with
coming up with it in the first place.  Kind of like Gates invented software.
Sorry, but that's one of those silly things that bugs me...
Austin
2003-05-30 by Daniel Staver
The new Minolta also has a grain-dissolver, which is a built-in diffuser
that's supposed to reduce the grain without sacrificing detail. It can
be switched on and off in software. I suppose it's the same thing they
sell at http://www.scanhancer.com and that they just took the idea and
incorporated it in their hardware. Nevertheless, it's nice to see that
they're actually doing more than just increasing the dpi all the time.
Daniel Staver
http://daniel.staver.no
> difference
I do not shoot on a tripod, use a variety of films and speeds.  I
certainly see a difference in the print when making larger prints by
upsampling compared to higher original samplings.. As for the
difference between any res specs, results also depend highly on the
different scanners used, the software and the operator...
Carolyn
Hi Martin..
> I
> the
> for B&W
When you shoot color, or color for B&W and B&W, and require very good
scans for all, how does that change the specs for sampling resolutions?
> per
> scanning
> should be
> Minolta MF
Thank you for that information.
> am not
> easier
I know how precise you are and what you achieved with your Polaroid is
the reason I went looking for one once it was required. Thanks for that
info as well...
> optical
Yes it would. ;)
> 7000 dpi
> film.
I play with 1.5 gig PS files, though layers and layers of course, not a
flattened image file size. PS has a size limit of 2.51 GIG's. So even a
Scanmate 11k  would fit in nicely... I've been reading about people
seeing a big difference in those huge scans of 35mm, so how can it be
said with completely certainty that what we have now is near the limit
for desktop CCD's and the quality of the scans won't improve with
higher res etc. I'm just curious... and I don't have your engineering
degrees so forgive me for being naive in this respect.
> Not to mention
Well, that's just it, can't justify it just yet ;)
Carolyn
2003-05-30 by Truman Prevatt
The first real 2D CCD that was any pratical use in imaging dates back to
the 70's and that was a 1 k by 1 k (1 megapixel) monochromic CCD. That
sucker was expensive - so expensive that no one but the US DOD could
afford it. At that time the 1 k one dimensional CCD was still
expensive.  The amount of progress we have made in this area has not
been anywhere near the progress technoloy has made in other areas. They
can be produced today for a heck of a lot less money but they haven't
improved that much in capability - except maybe much better dynamic
range. Compare this to semiconductor memory. At the same time this CCD
was being developed the PC was someone's wet dream. In the early 80, 64
k of memory was a big deal. Now most have at least a half a gig in them
and you can buy a 250 meg simm for about 100 bucks.  One of the problems
is the physics behind the CCD.  It was thought CMOS sensors would solve
this but they come with their own set of problems.
Of course if you really want to see a jump in scanner technology all
that has to happen is for me to go out and buy a new one to upgrade the
one I have. Then within a week the next generation will be released :-).
Truman
>Carolyn writes:
2003-05-30 by Clayton Jones
Hello Austin,
At least you know that you are nitpicking, that's a step in the right
direction.
Clayton
Sent: Friday, May 30, 2003 6:51 AM
> Hi Martin..
> > I
> > the
> > for B&W
Theoretically color neg films are lower resolution and therefore less
demanding. Color neg and chromogenic B&W films are reported to have
resolutions of 1300 to 3000 and color slide film is 2000 to 6000. So the
requirement for color slide are about the same as B&W.
(snip)
> > 7000 dpi
> > film.
Ouch! I have a tough time working with anything over 0.5 or 0.6 GB.
It is hard to judge the differences people see and how they evaluate it. A
lot may have to do with what they are going from and to. Maybe they don't
scan particularly well themselve but when they send it out for that big drum
scan the operator does a better job. Or perhaps the drum operator or
software did a bit of sharpening making a side by side comparison seem much
more different than it really is. No good answer to that.
No degrees in scanning or electronics here. It certainly makes sense to
pursue scanner resolution up to and probably a bit past the highest
resolution of the film, say 7000 dpi, just so you have the option to capture
everything off the best piece of film. Beyond that you are not gaining
anymore info just making larger files. Hopefully the tech will advance and
prices fall, making this possible.
Martin
> So the
Thank you.. ;)
> it. A
> don't
> big drum
> much
Agreed... Same holds for output of course.
> capture
Good and Yes...
> and
Thanks Martin, for all your good info. I hope it will too. I'm not
planning a move to digital capture, I doubt I will anyway, I'd spend
far too much time adding grain to those files... ;)
Carolyn
Hi Martin,
> demanding.
Perhaps you might want to check here:
http://medfmt.8k.com/mf/lenslpm.html
in general, I'd say that isn't really true.  Tri-X is listed at 100lp/mm,
and Fuji Superia 400 is listed at 100 as well...  Plus-X is listed at 125,
and a comparable Fuji Superia 100 is listed at 125 as well...so they seem to
be about the same. Of course, there are going to be exceptions, but I
believe in general, you can't make that generalization...yes, I see you said
"theoretically" ;-)
> So the
Hum.  As I'm sure you well know, not as far as density goes.  Perhaps for
resolution...
Austin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Anthony
Atkielski" <anthony@a...> wrote:
> Murph writes:
a good
> job.
True - the Nikon 8000ed I've rented has been working great, but it is
nice to know what may be coming out soon as potential options before
you spend this much cash...
-Murph
2003-05-30 by Peter Nelson
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Martin Wesley"
<mwesley250@e...> wrote:
See:
http://www.users.qwest.net/~rnclark/scandetail.htm
He demonstrates that there is a significan improvement going from
2800 to 4000 DPI and still a little more improvement from 4000 to
6000 DPI.
Thanks for your response - I've learned alot, just reading everyone's posts.  By long in
the tooth, I meant that they've been around awhile relatively without new models.
From someone who doesn't own a film scanner it seems like the current line-up has
been there a while - buy maybe that's just my impatient nature working too.  Didn't
mean to degrade the current line-up as a few posts convey'd.
I'm thinking about buying the Nikon 8000 ED, but don't want to spend the cash if
another scanner was coming out immenintly with higher resolution - just part of my
due diligence.  The other problem is that I want to have flexibility to make large
prints with my medium format scans.
Anywall all the info is appreciated...thanks...
-Murph
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Austin Franklin"
<darkroom@i...> wrote:
> Murph,
> > moving so fast
> > greater resolution,
> minimum scan time.
> Austin
Carolyn writes:
> ... I've been reading about people seeing a big
> can it be said with completely certainty that
> what we have now is near the limit for desktop CCD's
We are far from the limit for desktop scanners.  However, pixels need to be
improved in quality, not just quantity.
Re: Any New Film Scanners Coming?
2003-05-30 by sceptre12345
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "murph278"
spend the cash if
just part of my
> due diligence.
As Jerry used to say, there will surely be a new model coming out
within 24hrs of your purchase...
Cheers,
Andre
What prevents creation of a desktop scanner that uses PMT technology
(without a drum)?  Are there any other scanning technologies besides
CCD/CMOS and PMT?
To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Friday, May 30, 2003 15:52
> Truman
Murph writes:
> great, but it is nice to know what may be coming out
> soon as potential options before you spend this much cash...
You can just sell the scanner if a better one comes out.
I've had three Nikon scanners: the LS-30, the LS-2000, and the LS-8000ED.
The LS-30 is on semi-permanent loan to a photographer friend (who had never
scanned anything in her life prior to using the LS-30; needless to say, she
was pleasantly shocked to see just how good her favorite images looked when
they were scanned directly, as opposed to being entrusted to lab for
prints).  I still use the LS-2000, mainly for high-speed films where 2700
dpi is enough to get everything useful off the film.  I use the LS-8000ED
for slide films, B&W, and all MF scans.  While each scanner has been better
than its predecessor, they are all still useful.  I wouldn't mind replacing
the LS-2000 with a LS-4000ED, but I don't have the budget for that now (and
even if I replaced it, I'd keep the LS-2000).
2003-05-31 by Carolyn Frayn
> to be
well sure, and improvement usually always comes in time... I just get
my back up with all the "certainty" floating around... with respect,
who can be 100% certain about what's to come, except maybe my dog. His
future is fairly predictable... eat, drink out of the toilet, sleep...
Carolyn
