--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Peter Nelson
<peter@s...>" <peter@s...> wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "disch7634
> <disch7634@y...>" <disch7634@y...> wrote:
> > I use my
> > 2200 for anything of importance, however I use the 785 for
printing
> > family snaps and stuff like that. I like the Gray Balancer and
have
> > had good luck getting good B&W from the 2200, so I would like
both
> to
> > be able to coexist.
> How did you decide that the Gray Balancer and the 785 were
> conflicting? What resource were they conflicting over?
> I have the Gray Balancer, a 2200, and an 870, and both
> printers use my parallel port (via a switch) and I've
> never had any problems. I run Win2K.
I stripped all of my peripherals and their software off and restored
XP to before they were added, everything worked fine. I then started
adding the peripherals back on until I found the combination of
computer, software and peripherals that caused the error. It was the
785 and the Gray Balancer software. My theory is that the gray
balancer is trying to control the 785 in the same way it controls the
2200. What I don't know is if it is a combination of the 785, Gray
Balancer and XP. I would have to try a different operating system to
find that out. The fact that you say that you run Win2k without
problems would make me think that XP has some hand in the problem as
well.
