Jon Cone's new B/W system FYI
2003-03-01 by flyfishingusa2002 <tflyfish@citlink.net>
Take a look at this link. It's to Jon Cone's media kit for PMA http://www.piezography.com/media/PMA-2003-Media-Kit.pdf You will see that their new system is based on the Cannon printers and not Epson. The reason for this change seems to stem around the fact that the Cannon has a user replacable head. In other words, Jon Cone is expecting his inks to clog the head to the point were it will need rep[lacing. I can't imagine that its a cheap replacement. What do you think? Barry
2003-03-01 by Austin Franklin
> Take a look at this link. It's to Jon Cone's media kit for PMA > http://www.piezography.com/media/PMA-2003-Media-Kit.pdf > You will see that their new system is based on the Cannon printers > and not Epson. The reason for this change seems to stem around the > fact that the Cannon has a user replacable head. In other words, Jon > Cone is expecting his inks to clog the head to the point were it > will need rep[lacing. I can't imagine that its a cheap replacement. > What do you think? I am certainly not selling my TWO Epson 3000s that work fine just to use his replacement software! I believe I'm not a customer of theirs for, at least, the near future. Austin
2003-03-01 by Ton Guiking
> -----Oorspronkelijk bericht----- > Van: flyfishingusa2002 <tflyfish@...> > [mailto:tflyfish@...] > Verzonden: zaterdag 1 maart 2003 15:09 > Aan: DigitalBlackandWhiteThePrint@yahoogroups.com > Onderwerp: [Digital BW] Jon Cone's new B/W system FYI > > > Take a look at this link. It's to Jon Cone's media kit for > PMA http://www.piezography.com/media/PMA-2003-Media-Kit.pdf > You will see that their new system is based on the Cannon printers > and not Epson. The reason for this change seems to stem around the > fact that the Cannon has a user replacable head. In other words, Jon > Cone is expecting his inks to clog the head to the point were it > will need rep[lacing. I can't imagine that its a cheap replacement. > What do you think? What I think? I think you didn't read the article well... (or you can't stand the fact that Epson is no longer the self-evident #1 choice). The reason for the change is (according to John Cone): - Canon printers are *way* faster - The replacable head is is a *great* feature for changing between B/W and colour - The repacable head is *way* easier to clean, just in plain ordianary water BTW, he announces the same system for Epson! (maybe it will take some more time, Epson printers are notorious for clogging..) Ton - bought recently a Canon S900 and am a happy camper- Guiking
2003-03-01 by Kip Babington
I think it would be more fair to accept Mr. Cone's explanation in the materials that, (1) if you do get a clog, it's a lot simpler to just remove a Canon head and flush it under warm water than to clear a clog from an Epson head, and (2) the availability of separate heads for Canon printers means users can have one loaded with color inks and another with Piezo inks, and do both color and B&W on the same printer with just a head swap (which takes about 5 seconds once the head carriage has moved into the center of the printer.) As to (1), having cleared several nozzle clogs in a Canon 9000 printhead by rinsing the head under running water (and this is with dye only inks) I can confirm that it's a trivial exercise compared to the ammonia-soaked paper towel procedures that are mentioned regularly in these pages for dealing with Epson clogs. As to (2), this is the reason I bought a Canon 9000 last year, although Canon has just recently released the printheads for separate sale (my photo shop says they can get them for $125 each.) I do confess I don't know how well the heads will do loaded with ink but not sitting on the printer - I understand Epson printers have a cap of some sort that seals up the print nozzles when the head is parked, in order to keep them from drying out. It remains to be seen if something similar will be needed for an unmounted but inked Canon head in order to keep it ready to print immediately upon installation. I'm prepared to keep one sealed in a plastic bag with a wet sponge inside if necessary. I took up digital photography (after 40+ years of B&W in a darkroom) only after determining that it might be possible to do quality B&W work digitally. I started with the original Piezo inks in an Epson 860. But I didn't do my homework well enough, and was disappointed to discover that those inks only worked on matte papers whereas I wanted to do glossies. And the speed of the 860 was way too slow to do what I needed - which is about 800 8x10s at Christmas time. I didn't have the discipline to start early in the fall in order to get it all done by Christmas Eve. The speed of the Canon 9000 and its ability to do adequate (barely) B&W 8x10s in around 2 minutes is what got me through this last Christmas season. Now the availability of Piezo and the recent release of Lyson Quad Black inks for the Canon make serious B&W on glossy stock possible. So I for one am delighted to see this new direction for Mr. Cone's efforts. Cheers, Kip At 3/1/2003 02:08 PM +0000, you wrote:
>Take a look at this link. It's to Jon Cone's media kit for PMA >http://www.piezography.com/media/PMA-2003-Media-Kit.pdf >You will see that their new system is based on the Cannon printers >and not Epson. The reason for this change seems to stem around the >fact that the Cannon has a user replacable head. In other words, Jon >Cone is expecting his inks to clog the head to the point were it >will need rep[lacing. I can't imagine that its a cheap replacement. >What do you think? > >Barry
2003-03-01 by Dan Honemann <dan_honemann@yahoo.com>
> You will see that their new system is based on the Cannon printers > and not Epson. From the pdf: "The new profiling system will allow the Company to also produce an inexpensive black & white inkjet system that will take advantage of the 7 ink positions of the EPSON 2200, 7600 and 9600 printers to produce more than one tone and to produce split-toning." Dan
> -----Oorspronkelijk bericht----- > Van: Kip Babington [mailto:cbabing3@...] > Verzonden: zaterdag 1 maart 2003 15:45 > Aan: DigitalBlackandWhiteThePrint@yahoogroups.com > Onderwerp: Re: [Digital BW] Jon Cone's new B/W system FYI > > > I think it would be more fair to accept Mr. Cone's explanation in the > materials that, (....) > > So I for one am delighted to see this new direction for Mr. > Cone's efforts. > > Cheers, > Kip > Amen, brother! Ton Guiking
2003-03-01 by Peter Nelson <peter@studio-nelson.com>
Are print head clogs really so common? I've owned several Epson printers over the years and a couple of HP's. I only use the manufacturer-supplied ink. I currently have two Epsons, a 2200 and an 870. I often go for weeks without printing. I have NEVER had a significant clog. The worst clog I ever had was with my 870 and it took 3 head-cleaning cycles to clear and it was MY fault, because I left the printer powered up for a week without using it once. (turning off the printer parks the heads properly so they're less likely to dry out). So what's the deal with clogs - have I just been lucky or is it something to do with third-party inks? Why would third-party inks be any more likely to clog than manufacturers' inks? I keep seeing people here talking about print head clogging but I don't understand why that seems so common. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Kip Babington <cbabing3@s...> wrote:
> I think it would be more fair to accept Mr. Cone's explanation > in the materials that, (1) if you do get a clog, it's a lot > simpler to just remove a Canon head and flush it under warm > water than to clear a clog from an Epson head
Peter, > Are print head clogs really so common? With the original Cone quadtone inks, yes, very. Austin
2003-03-01 by mh <mh@toomanyartists.com>
Is their anyone on this list that leaves their epson printer on all the time? I believe the "turn your printer off or they will dry up" is an old wives tale now probably based on drivers from days of old. I think epsons nowadays always have their pads parked when not printing. But I would be happy to know for sure if anyone can tell me. -mh --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Peter Nelson < peter@s...>" <peter@s...> wrote:
> Are print head clogs really so common? I've owned > several Epson printers over the years and a couple of HP's. > I only use the manufacturer-supplied ink. I currently have > two Epsons, a 2200 and an 870. I often go for weeks > without printing. > > I have NEVER had a significant clog. The worst clog > I ever had was with my 870 and it took 3 head-cleaning > cycles to clear and it was MY fault, because I left the > printer powered up for a week without using it once. > (turning off the printer parks the heads properly so > they're less likely to dry out). > > So what's the deal with clogs - have I just been lucky > or is it something to do with third-party inks? Why > would third-party inks be any more likely to clog than > manufacturers' inks? I keep seeing people here talking > about print head clogging but I don't understand why > that seems so common. > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Kip Babington > <cbabing3@s...> wrote: > > I think it would be more fair to accept Mr. Cone's explanation > > in the materials that, (1) if you do get a clog, it's a lot > > simpler to just remove a Canon head and flush it under warm > > water than to clear a clog from an Epson head
MH, > Is their anyone on this list that leaves their epson printer on all the > time? I do. > I believe the "turn your printer off or they will dry up" is an > old wives tale now probably based on drivers from days of old. Not on drivers, but on printer design. The new printers "cap" the heads when not in use, even though the power is still on. > I think > epsons nowadays always have their pads parked when not printing. But I > would be happy to know for sure if anyone can tell me. You can take a look inside. I know the 3000 and 1160 do, and I certainly would believe anything later than those two would as well. Regards, Austin
2003-03-01 by Bob_Michaels <bob@bobmichaels.org>
I never turn off my 1280 and never had clog problems using MIS FSN ink. I guess leaving it on is just habit from laser days and dot matrix before that. Bob Michaels --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mh <mh@t...>" <mh@t...> wrote:
> Is their anyone on this list that leaves their epson printer on all the > time? I believe the "turn your printer off or they will dry up" is an > old wives tale now probably based on drivers from days of old. I think > epsons nowadays always have their pads parked when not printing. But I > would be happy to know for sure if anyone can tell me. > > -mh > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Peter Nelson < > peter@s...>" <peter@s...> wrote: > > Are print head clogs really so common? I've owned > > several Epson printers over the years and a couple of HP's. > > I only use the manufacturer-supplied ink. I currently have > > two Epsons, a 2200 and an 870. I often go for weeks > > without printing. > > > > I have NEVER had a significant clog. The worst clog > > I ever had was with my 870 and it took 3 head-cleaning > > cycles to clear and it was MY fault, because I left the > > printer powered up for a week without using it once. > > (turning off the printer parks the heads properly so > > they're less likely to dry out). > > > > So what's the deal with clogs - have I just been lucky > > or is it something to do with third-party inks? Why > > would third-party inks be any more likely to clog than > > manufacturers' inks? I keep seeing people here talking > > about print head clogging but I don't understand why > > that seems so common. > > > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Kip Babington > > <cbabing3@s...> wrote: > > > I think it would be more fair to accept Mr. Cone's explanation > > > in the materials that, (1) if you do get a clog, it's a lot > > > simpler to just remove a Canon head and flush it under warm > > > water than to clear a clog from an Epson head
2003-03-01 by Thomas Fors
It sounds to me like Cone's new system is doing exactly what Paul Roark has been doing for years, but instead of using Photoshop curves, his adjustments are made in ICC profiles and, of course, only available for his inks. I find his comments on his new PiezoGloss paper interesting too: "It is a high gloss surface after printing and this is going to be very popular with those looking for gloss. But the paper only glosses with the PiezoTone formulation for Canon." --Tom
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mh <mh@t...>" <mh@t...> wrote: > Is their anyone on this list that leaves their epson printer on all the > time? I believe the "turn your printer off or they will dry up" is an > old wives tale now probably based on drivers from days of old. I think > epsons nowadays always have their pads parked when not printing. But I > would be happy to know for sure if anyone can tell me. All I can say is that ever since that time, I always turn off my 870 except when actually printing - and I print even less frequently that ever on it because I mostly use my 2200) and I've had only one small clog, that cleared with a single cleaning cycle, since then.
2003-03-01 by danielstaver <daniel@petraflux.com>
> Is their anyone on this list that leaves their epson printer on all the time? My 2100 has been on since I bought it last october. Never had any problems.
2003-03-01 by Richard Sintchak
Saturday, March 1, 2003, 6:39:31 AM, Ton Guiking wrote: TG> What I think? I think you didn't read the article well... (or you can't TG> stand the fact that Epson is no longer the self-evident #1 choice). TG> The reason for the change is (according to John Cone): I think you may not be familiar with Jon's penchant for hype and spin. Best regards, Richard mailto:richard@... L i n k s t o m y g a l l e r i e s: http://fujirangefinder.com/document.php?id=246
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Thomas Fors" < tom@f...> wrote: > It sounds to me like Cone's new system is doing exactly what Paul Roark has > been doing for years, but instead of using Photoshop curves, his adjustments > are made in ICC profiles and, of course, only available for his inks. Yes, but I thought everyone here agreed a long time ago that that sort of thing was not possible to do using ICC profiles. Does anyone here want to guess as to how it was done and why nobody came up with it earlier? > I find his comments on his new PiezoGloss paper interesting too: "It is a > high gloss surface after printing and this is going to be very popular with > those looking for gloss. But the paper only glosses with the PiezoTone > formulation for Canon." > > --Tom Yes, I think we are all interested in this. I am hesitant to believe that there are not downsides to this though. My guess is there is either a high dye percentage of some sort, or the paper itself is doing something funky. We will have to test that combo extra carefully. -mh
Tom, > I find his comments on his new PiezoGloss paper interesting too: "It is a > high gloss surface after printing and this is going to be very > popular with > those looking for gloss. But the paper only glosses with the PiezoTone > formulation for Canon." Er, huh? Either the paper is glossy or not. The paper doesn't get every square nano-micron hit with ink...so I'm not clear how that would be possible. Is this saying that it's the ink that glosses, and the white areas of the paper don't gloss? That would look weird! Austin
It is "PiezoGloss" paper that only remains glossy with Canon Piezotone ink. Epson piezotone ink will exhibit the buffing/powder coat that it does on all the other glossy papers. Which I guess indicates that there is something funky going on with the Canon version. I hope they have fully tested whatever that funkiness is for proper archival properties. -mh --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Austin Franklin" <darkroom@i...> wrote:
> Tom, > > > I find his comments on his new PiezoGloss paper interesting too: "It is a > > high gloss surface after printing and this is going to be very > > popular with > > those looking for gloss. But the paper only glosses with the PiezoTone > > formulation for Canon." > > Er, huh? Either the paper is glossy or not. The paper doesn't get every > square nano-micron hit with ink...so I'm not clear how that would be > possible. Is this saying that it's the ink that glosses, and the white > areas of the paper don't gloss? That would look weird! > > Austin
So, the paper IS glossy to start with, right? If it IS glossy to start with, then it should remain glossy after being printed... I'm not clear on how this supposedly works. If you, or someone else can 'splain it, I'd appreciate it. Austin
> It is "PiezoGloss" paper that only remains glossy with Canon Piezotone > ink. Epson piezotone ink will exhibit the buffing/powder coat that it > does on all the other glossy papers. Which I guess indicates that there > is something funky going on with the Canon version. I hope they have > fully tested whatever that funkiness is for proper archival properties. > > -mh > > > Tom, > > > > > I find his comments on his new PiezoGloss paper interesting > too: "It is a > > > high gloss surface after printing and this is going to be very > > > popular with > > > those looking for gloss. But the paper only glosses with the > PiezoTone > > > formulation for Canon." > > > > Er, huh? Either the paper is glossy or not. The paper doesn't > get every > > square nano-micron hit with ink...so I'm not clear how that would be > > possible. Is this saying that it's the ink that glosses, and the white > > areas of the paper don't gloss? That would look weird! > > > > Austin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Austin Franklin" <darkroom@i...> wrote: > > So, the paper IS glossy to start with, right? If it IS glossy to start > with, then it should remain glossy after being printed... I'm not clear on > how this supposedly works. If you, or someone else can 'splain it, I'd > appreciate it. > > Austin I think what he's trying to say is that it's glossy to start with, but a normal ink would UNgloss it, however the new ink allows it to remain glossy where it is applied.<P> Personally, I don't care - I prefer matte papers but I think that's what they're trying to say.
2003-03-01 by Tim Atherton
> I think you may not be familiar with Jon's penchant for hype and spin. > > Best regards, > Richard You mean he's a salesman... :-) Artists beware - it's known how gullible you (we?) are....!
2003-03-01 by Eddy <eddy@fotoartes.com>
> I am certainly not selling my TWO Epson 3000s that work fine just to use his > replacement software! > > I believe I'm not a customer of theirs for, at least, the near future. > > Austin Austin, it works with any printer driver. To quote Jon: "The new PiezographyBW does not use any proprietary printer drivers, software, or file formats. The new PiezographyBW is ICC compliant and works with any software which can open and print a grayscale image. We have invented a new type of (industry standard) ICC printer profiling application that allows us to produce ICC printer profiles which are specifically oriented to monochromatic inks and the standard OEM printer driver." Nowhere does he say that Epson printers are not supported. They are. They have ADDED Canon, not deleted Epson. --Eddy McDonald
2003-03-01 by Tony Terlecki
On Sat, Mar 01, 2003 at 10:41:50PM -0000, Eddy <eddy@...> wrote: > > I am certainly not selling my TWO Epson 3000s that work fine just > to use his > > replacement software! > > > > I believe I'm not a customer of theirs for, at least, the near > future. > > > > Austin > > Austin, it works with any printer driver. To quote Jon: > > "The new PiezographyBW does not use any proprietary printer drivers, > software, or file formats. > > The new PiezographyBW is ICC compliant and works with any software > which can open and print a grayscale image. > > We have invented a new type of (industry standard) ICC printer > profiling application that allows us to produce ICC printer profiles > which are specifically oriented to monochromatic inks and the > standard OEM printer driver." > > Nowhere does he say that Epson printers are not supported. They > are. They have ADDED Canon, not deleted Epson. > The thing is that the 3000 droplet size is huge if you use the Epson driver. The old piezo software had it's own dither pattern which overrode the Epson driver and improved matters considerably. If the new product is reverting to and relying on Epson drivers then the 3000 is probably not going to produce good results. But I think we're all running ahead of ourselves here are we not? Let's at least see the product before passing judgement! -- Tony Terlecki ajt@...
That, and the fact that one will have to buy the "system" (ie the profiles) for $175 which Austin probably won't do since the plugin works fine (and, as said below, much better than the epson driver) Is there going to be an upgrade for registered users of the plugin I would like to know? Does Jon read this list at all? -mh --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tony Terlecki < ajt@m...> wrote:
> On Sat, Mar 01, 2003 at 10:41:50PM -0000, Eddy <eddy@f...> wrote: > > > I am certainly not selling my TWO Epson 3000s that work fine just > > to use his > > > replacement software! > > > > > > I believe I'm not a customer of theirs for, at least, the near > > future. > > > > > > Austin > > > > Austin, it works with any printer driver. To quote Jon: > > > > "The new PiezographyBW does not use any proprietary printer drivers, > > software, or file formats. > > > > The new PiezographyBW is ICC compliant and works with any software > > which can open and print a grayscale image. > > > > We have invented a new type of (industry standard) ICC printer > > profiling application that allows us to produce ICC printer profiles > > which are specifically oriented to monochromatic inks and the > > standard OEM printer driver." > > > > Nowhere does he say that Epson printers are not supported. They > > are. They have ADDED Canon, not deleted Epson. > > > > The thing is that the 3000 droplet size is huge if you use the Epson driver. > The old piezo software had it's own dither pattern which overrode the Epson > driver and improved matters considerably. If the new product is reverting to > and relying on Epson drivers then the 3000 is probably not going to produce > good results. > > But I think we're all running ahead of ourselves here are we not? Let's at > least see the product before passing judgement! > > > -- > Tony Terlecki > ajt@m...
2003-03-02 by Ton Guiking
> -----Oorspronkelijk bericht----- > Van: mh <mh@...> [mailto:mh@...] > Verzonden: zondag 2 maart 2003 0:59 > Aan: DigitalBlackandWhiteThePrint@yahoogroups.com > Onderwerp: Re: [Digital BW] Jon Cone's new B/W system FYI > >(...) > Is there going to be an upgrade for registered users of the plugin I > would like to know? Then read the article, and you'll see: "The Company now plans to completely reincarnate their PieographyBW for EPSON products. An upgrade for more than 4,000 users of that system is planned for April." So the answer seems to be YES. Best, Ton Guiking
2003-03-02 by Bruce
on 3/1/2003 8:45 PM, DigitalBlackandWhiteThePrint@yahoogroups.com at DigitalBlackandWhiteThePrint@yahoogroups.com wrote: > The thing is that the 3000 droplet size is huge if you use the Epson driver. > The old piezo software had it's own dither pattern which overrode the Epson > driver and improved matters considerably. If the new product is reverting to > and relying on Epson drivers then the 3000 is probably not going to produce > good results. > > But I think we're all running ahead of ourselves here are we not? Let's at > least see the product before passing judgement! I think the press release made it pretty clear. This product consists of Paul's curves (or similar) converted to ICC profiles for easy application. If paul's curves work for the Epson 3000, I would think that these ICC profiles should work about the same. And I've seen some of Paul's prints from his 3000 with the VM inks and they are stunning, Epson driver and all. -Bruce
2003-03-02 by Ernst Dinkla
A lot has been written on the Canon shift/addition. One of the things that has not been mentioned is that Canon is top in the digital camera world too. That will affect the sale of Canon printers especially with some of the fast direct camera>print solutions that are already marketed by Canon. Epson has similar solutions but no digital camera reputation that can be compared to Canon's. The Epson third party ink/cart market has a lot of competition meanwhile, the much smaller B&W market for Epson is full of competition. Cone, MIS, Lyson not to mention the software manufacturers. Cone has the new profiling software, that is the real key in his concept till someone figures out that something like that already exists (maybe the "Rich Grey" profile ?) or is not that difficult to make. There are some Canon printer specs that are better, practice will show whether there are also flaws in using Canon printers in B&W printing. In general Canon adapts its marketing concept faster to the changed circumstances. Less obsessed with ink selling than HP. Epson etc, they introduced the first printers with an ink cart per colour. However the price of an extra head quoted at 150 $ makes me wonder if an extra printer isn't the better choice. An Epson 9000 head is cheaper but takes a lot more time to replace :-) Ernst
2003-03-02 by Tyler Boley <tyler@tylerboley.com>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Bruce < smthopr@e...> wrote: snip... ...This product consists of > Paul's curves (or similar) converted to ICC profiles for easy application. Ridiculous. Nothing against Paul and his hard work, but people have been making curves for the Epson driver and various other drivers for years. They could be Culbertson's, or Randall's, or even mine, or someone else's who doesn't bother to spend time on lists. Some have even been utilizing profiles to make them, and even incorporating them into profiles. I'd send you one I made before there was ever a Piezography product, but who has ther time for this kind of dialogue? In fact they are not likely to be anyone's, but based on whatever they come up with there. Pretty well priced too. I'd say it just might work. As with all things, most of us will wait for somebody else to take the plunge and let us know. Then complain some more. Tyler
2003-03-02 by TF
on 3/2/03 1:03 PM, Tyler Boley <tyler@...> wrote: > In fact they are not likely to be anyone's, but based on whatever they > come up with there. > Pretty well priced too. I'd say it just might work. As with all things, > most of us will wait for somebody else to take the plunge and let us > know. Then complain some more. But let us rejoice in the blessing that this media blurb was released before any output could be seen! Thus we can dismiss it out of hand before ANYONE has to try it. It's unbelievable, isn't it? We mope around bitching about clogs, the cost of RIPs, the slow output, the fades, the need to create paper specific monitor previews, yadda yadda yadda, then when Cone answers the call with something that sounds good, cheap, and easy, he's dissed? Sheesh... Todd
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, TF <tflash@e...> wrote: ... > It's unbelievable, isn't it? We mope around bitching about clogs, the cost > of RIPs, the slow output, the fades, the need to create paper specific > monitor previews, yadda yadda yadda, then when Cone answers the call with > something that sounds good, cheap, and easy, he's dissed? > > Sheesh... > > Todd Right, he seems to sort of like it though, don't you think? Wait untill someone buys in, then has some problems, yikes! Tyler
2003-03-02 by Carolyn Frayn
On Sunday, March 2, 2003, at 12:04 PM, TF wrote: > then when Cone answers the call with > something that sounds good, cheap, and easy, he's dissed? well of course T, always a conspiracy, remember? C
2003-03-02 by Ed Mathews
> -----Original Message----- > From: TF [mailto:tflash@...] <SNIP> > But let us rejoice in the blessing that this media blurb was > released before > any output could be seen! <SNIP> This is a good point, which reminds me of another point: Did he show any examples of this at the show? Did anybody see anything? Usually, whenever I go to a tradeshow there's always some samples there to wow and impress people. Anything here? Thanks, Ed http://lightandsilver.com
2003-03-02 by Editor P.O.V. Image Service
flyfishingusa2002 wrote: >Take a look at this link. It's to Jon Cone's media kit for PMA >http://www.piezography.com/media/PMA-2003-Media-Kit.pdf >You will see that their new system is based on the Cannon printers >and not Epson. The reason for this change seems to stem around the >fact that the Cannon has a user replacable head. > Of course there is a SMALL problem with this... Currently Canon does not SELL replacement printheads for a particular printer model UNTIL the first units of that printer have moved past the one year warranty point. As an example, they only recently began offering replacement printheads for the S900 and S9000 (released about a year ago)... Unless Canon changes that policy,. there won't be available replacement heads for the i950 and i9100 until February and April of next year.. Keith "Just some guy," and caretaker of the Multiverse's largest EPSON printer User Community (highly recommended by Vogon Poets and MegaDodo Publications), at: http://groups.yahoo.com/group/EPSONx7x_Printers/ "For the rest of you out there, the secret is to bang the rocks together guys" [Non-text portions of this message have been removed]
