Arches 26 x 40 inch Hot Press
2016-09-03 by roark.paul@...
Just for the record, I have now printed some of these larger Arches watercolor sheets with the Espon 9800 and Eboni Variable Tone inkset (http://www.paulroark.com/BW-Info/9800-Eboni-Variable-Tone.pdf). The paper is thicker (remember to increase your platen gap) and requires re-linearization. Aside from that, the results are about the same as with the "full sheet" (22x30) sheets. (Aside from the 1.5 pl 1430 family, the dmax may be weak if you're not driving 2 MK positions.)
Paul
