Epson 7600 -- advice needed from 7600/9600 users
2016-03-15 by rdeloe1@...
I’m looking for some advice from people who have experience with the Epson 7600 or 9600.
I have an opportunity to buy an Epson 7600 (Ultrachrome version) with stand. It’s described as being in good working order. Obviously I won’t touch it unless I see it printing a clean nozzle check right in front of me, and if the status report is good. For purposes of this post, let’s assume everything checks out fine and the cost is low.
The printer would have to live in my basement. It’s a dry basement, and humidity is not a problem in my house. This is probably not ideal, but there’s no other place to keep the thing.
I’d load the printer up with Eboni in Paul Roark’s “Variable
Tone” formulation. It would only print on matte paper with this ink. I realize
that this will require cleaning and flushing the Ultrachrome inks it’s
currently using.It would never go back to color.
Here’s the thing: I’d rarely print 24” wide. Frankly, it would make a lot more sense to get a 3880. However, I’m thinking that a 7600 could work on the assumption that I’d print larger than 17” sometimes (OK, rarely), and that I’d print between 13” wide and 17” wide more often (but still not a lot). For printing less than 13” wide my Artisan 1430 is performing very well.
The only way this would make the slightest bit of sense is if the printer could go without printing for long stretches. For purposes of this post, let’s assume it makes one print a month – and sometimes less frequently. The day before I plan to use it, I’d agitate the carts to deal with sedimentation in the carts. In between prints, if I remember, I could turn it on once a week and run a nozzle check (but let’s assume that doesn’t always happen).
And finally, I’ve already found lots of good repair tips and sites, and I’m reasonably handy. So basic maintenance and repairs are do-able.
OK, with all those caveats… what do you think? Can this work for me? Keith Cooper has a great web page dedicated to answering this question (and that page says No way man, not a good idea!) However, I live in hope that maybe it could work anyway… Rob
