Epson 1430, 2880dpi leads to less neutral prints?
2016-03-08 by andrey@...
Hi everyone,
I just spent about a week and a half getting my Epson 1430 up and running with Paul's Eboni-6 inks, v1.1, from MIS, and it's finally coming together. Lots of great information here and the QTR list helped me get things sorted, so thank you all!
I've noticed on Epson Ultra Premium Presentation Paper Matte that using 2880 dpi (and unidirectional printing) that not only is the ink density higher, but the color cast is stronger. Is this normal? Black-only is more neutral with b* values in mid 3s, compared to mid 5s or 6s, and just excluding the lightest yellow position ink for a 6MK setup (turning it into a 5MK) gets me a more subjectively neutral print, though it's still warm compared to BO. The yellow position black ink by itself measures with b* in the 9s or higher in the midtones, BTW.
Microbanding at the 1-inch margins seems to be worse with 2880dpi, too.
Everyone here seems to recommend 2880/unidirectional, but how are the other modes? I've profiled the plain 1440 and 2880, but not any of the super modes or the 1440x1440. I've fed the printer some 720 dpi photos too (ie. photo resized to produce 720dpi at a given physical print size, like 4320x6480 to produce a 6x9 inch print), but if I'm seeing a difference to a 360dpi photo, it seems kind of subtle. I still need to do more tests here, though.
And another question: is there a black-only QTR calibration chart, where only the first strip is printed? To find the initial black ink limit, where you only look at the black channel, it seems a waste of time and ink to print out the entire test chart. With a narrow strip, you could also test out more modes on a single sheet of paper. I guess I could alter it in Photoshop, but I'm not sure if I'd screw up the special color distribution of the file.
I've only done my tests on EUPPPM, but am starting to profile nicer (ie. more expensive) papers now that I know what I'm doing. Canson Edition Etching and Epson Hot Press Natural are up next. The Epson looks very promising, and perhaps also produced by Canson based on its interior packaging.
Also a tip which most of you probably know already, but just in case: the microbanding in the first and last inch of the paper can really screw up your calibration. Because I'm using a ColorMunki, I'd been using Keith Cooper's calibration strip that's made for scanning with a ColorMunki, and it spans the length of the page. The microbanding lightens a tone since more white paper shows through, and it turns out that the 45% tone was in the bad area, so for linearization, that tone appears lighter than it should be, leading to a bump in the curve, and then to posterization in the midtones for my test picture. Scaling the calibration strip to 85% and centered in a US letter sized page so it's out of the danger zone solved that problem, and the ColorMunki scanning mode still works with the reduced size strip.
--Andre
