Digital BW, The Print
understanding product codes on box of PremierArt paper
2016-01-25 by paulmwhiting@...
I've been using PremierArt Fine Art Smoth paper in the 205gsm weight for years. A little warmer than what I was used to from darkroom days but it grew on me. Spent some time at my local art supply store to find a mat board that was a good match. A plus is that it was printable on both sides, which appealed to my frugal nature.
But lately, upon opening a new box, the paper was noticeably brighter. The paper I was used to was warmer because it had no OBA's, which I've grown to appreciate. Here's the code on the box:
Smooth 205gsm C2S 2220-85115 E50#6649
What I interpret is that C2S means coated both sides, 2220 is the paper style... no OBA's, Hot Press (ie Smooth), etc. 8511 means 8.5" x 11" and 5 means 50 sheets to the box. For a 25 sheet box that last number is 3, which is 25 rounded up.
So far so good. But the E50# varies from box to box, for example E50#6649, E50#7079, etc. so I think that must be the lot number. Aha... so the paper is made and packaged in lots, that makes sense. But my new box, with a different lot number, is much whiter than other lot numbers. Not a good thing! Error in packaging maybe?
Anyone experienced this? Perhaps I should call the company but I wanted to run this by the group first.
Thanks for any thoughts,
Paul
Re: understanding product codes on box of PremierArt paper
2016-02-09 by paulmwhiting@...
I did phone PremierArt today, and spoke directly with a very helpful staff person. He said that E number is indeed the lot number, which they use for internal purposes. And he did say it's possible for there to be some slight variations in the lots. I appreciated his candor and honesty. I can see where this paper business is not an exact science, although I'm sure they take every precaution. I'll certainly continue to use it, in fact it's about time for me to send in another order. I usually go to Atlex.
Also found out they are indeed continuing the manufacture of the Fine Art Smooth 205gsm. For a while there was a rumor that this paper was being discontinued - no, he said, this is a very popular paper. So that was good to find out.
Paul W.
