From: "Paul Roark roark.paul@gmail.com [DigitalBlackandWhiteThePrint]" <DigitalBlackandWhiteThePrint@yahoogroups.com>
To: DigitalB&WPrint <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Thursday, May 21, 2015 9:30 AM
Subject: Re: [Digital BW] 3880 cartridges
I did use that method. His previous method of removing the cap on the end of the cart seemed like a safer way to go in terms of avoiding damage to the valve and seal. Good, new empty carts seems like the safest way to go at the moment.
His recommended resetter worked well for a while, then stopped working.
Paulwww.PaulRoark.com
On Thu, May 21, 2015 at 7:09 AM, CB curtisbliss@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
I have an unused 3880 which I have also been wanting to try, once i can figure out how to refill or get decent carts. I had been looking on youtube to see this Jose poke out the back flow valve and refill the carts. He claimed that only one seller in FL had the reset tool which worked. Did you try that one? Are you talking about the same method? Depressing to hear about the pool of ink!
Curt
From: "roark.paul@... [DigitalBlackandWhiteThePrint]" <DigitalBlackandout tWhiteThePrint@yahoogroups.com>
Sent: Wednesday, May 20, 2015 10:45 PM
Subject: [Digital BW] 3880 cartridges
The carts and chips seem to be the weak point on the 3880. For my first effort, I tried (and am using) OEM Epson carts where I poked out the back-flow valve (a la Jtoolman YouTube video) and reset the chips. Initially, although it took several redundant carts to get chips that would reset, it appeared to be working fine. Then I noticed the the pool of ink under the printer, and the chips stopped resetting.
I no longer recommend this approach.
If the third party approaches like Jon Cone's work well, they are well worth the cost. So, I'd like feedback on any third party 3880 carts that might be up to serious work. If you don't want to embarrass anyone, contact me off list. This 3880, however, is too good to give up on, but I need a cartridge system that is good for the long haul, including bi-weekly agitation of the carts. That means the seals need to be good enough to take regular removal for agitation. I might add that the STS carts I'm using on the 7800 can do it, as can OEM 7800 carts (when their seals and valves have not been damaged). Some feedback I've already received is that a lot of the 3880 cart systems are not up to serious, high volume use.
Thanks in advance for the feedback.
PaulPaulRoark.com -- Paul Roark's Photographic Home
| | | | PaulRoark.com -- Paul Roark's Photographic Home Paul Roark Black and White Photography | |
| View on www.PaulRoark.com | Preview by Yahoo |
