Digital BW, The Print
New refillable cartridges and Epson 3800
2013-08-09 by davidkachel
I get my ink delivery this afternoon and am going to set up my 3800, again.
I have the newer refillable cartridges, the short that don't keep the ink cover from closing.
Does anyone know if I can mix those with OEM cartridges? Or do I have to replace the entire OEM set with the aftermarket set in order for them to work?
TIA
Re: New refillable cartridges and Epson 3800
2013-08-10 by minoltaatje
Depends on the brand.
I assume the set comes with instructions which will clarify things.
Generally speaking when (if) you need 9 working chips from the OEM cartridges, they can be mixed. In other words they can be replaced when a Epson cartridge is almost (usually not completely) empty.
- Jan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "davidkachel" <david@...> wrote:
> TIA
