Dye Prints
2013-07-23 by pdesmidt tds.net
How are the dye prints holding up on the Red River Metallic paper? I have a 4880 sitting idle.... [Non-text portions of this message have been removed]
2013-07-23 by Edward Wiseman
I'm using an Epson 1400 with Claria "clones" from LYSON (their XG series)..Fantastic results.ABSOLUTELY STUNNING!!.I haven't noticed ANY fading using this ink and RR ULTRA POLAR Gloss over the last 5 years, and NONE as well with the RR Metallic since it was first available..I have not done any "SOUTH" window testing, however..Of course THAT could "TOAST" the color off of virtually ANY media.. These inks may be available for your printer as well.. Contact http://www.ink2image.com Their phone # is on this site.. Best of luck with your 4880! Eddie
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of pdesmidt tds.net Sent: Tuesday, July 23, 2013 11:47 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Dye Prints How are the dye prints holding up on the Red River Metallic paper? I have a 4880 sitting idle.... [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
2013-07-23 by Paul Roark
pdesmidt tds.net <pdesmidt@...> wrote: > ** > > > How are the dye prints holding up on the Red River Metallic paper? > I have a 4880 sitting idle.... > > There are no sophisticated tests of that combination as far as I know. At their best, the dyes on Canson Baryta that has been sprayed have done amazingly well, almost at the Color UltraChrome level. However, the tests with another company's metallic show considerable changes at 50 MLux-hours. See http://www.aardenburg-imaging.com/ My own experience with the Noritsu dyes on Red River Metallic indicate that un-sprayed, un-framed cards on the mantle in a light room with south facing windows look very good after one year. I don't see any obvious change in non-critical observation. So, while I don't expect much longevity from any dye, I think the sprayed ones will probably still be fine after several years. I expect they won't look the same after 25 years. This is eye candy. They look great, are cheap, sell, and are fun to make and look at. I just spray with Lascaux (non-UV), dry-mount on pre-coated foam-core, frame-nail into black frames cut from stock, and it's done. With a roll of Red River Polar Pearl Metallic in the 4000, printing impressive looking display prints is easy. No other print media has come close to the apparent sharpness and "snap" these display. That said, we hang carbon prints under acrylic on most of our walls at home. Paul www.PaulRoark.com [Non-text portions of this message have been removed]
Thanks, Paul. I really like the Eboni-6 on EHPN, but for some of my images increased dynamic range and sharpness would be welcome. I've been shooting quite a bit with an 8x10 camera this year. On Tue, Jul 23, 2013 at 2:20 PM, Paul Roark <roark.paul@...> wrote: > ** > > > pdesmidt tds.net <pdesmidt@...> wrote: > > > ** > > > > > > > How are the dye prints holding up on the Red River Metallic paper? > > I have a 4880 sitting idle.... > > > > There are no sophisticated tests of that combination as far as I know. At > their best, the dyes on Canson Baryta that has been sprayed have done > amazingly well, almost at the Color UltraChrome level. However, the tests > with another company's metallic show considerable changes at 50 MLux-hours. > See http://www.aardenburg-imaging.com/ > > My own experience with the Noritsu dyes on Red River Metallic indicate that > un-sprayed, un-framed cards on the mantle in a light room with south facing > windows look very good after one year. I don't see any obvious change in > non-critical observation. So, while I don't expect much longevity from any > dye, I think the sprayed ones will probably still be fine after several > years. I expect they won't look the same after 25 years. > > This is eye candy. They look great, are cheap, sell, and are fun to make > and look at. I just spray with Lascaux (non-UV), dry-mount on pre-coated > foam-core, frame-nail into black frames cut from stock, and it's done. > With a roll of Red River Polar Pearl Metallic in the 4000, printing > impressive looking display prints is easy. No other print media has come > close to the apparent sharpness and "snap" these display. That said, we > hang carbon prints under acrylic on most of our walls at home. > > Paul > www.PaulRoark.com > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
