strange quadtone rip problem
2013-07-03 by Rick Hawkins Java
Folks, i have developed a strange problem i'm using an epson r260 with quadtone rip driver version 2.7 on a macbook core 2 duo machine when i make a 4x6 color print using the epson driver, print is correctly positioned when i make a BO print using the quadtone rip, position is dropped about 5 inches, pitting only about 1/2 inch of the print on the 4x6 paper if i print the image with the same settings, but feed a sheet of 8.5 X11, image is correctly positioned left/right but is positioned at the TRAILING EDGE of the sheet .... i just measured and its exactly 5 inches low suggestions? same computer, same printer, worked fine, probably in the last month thanks, xx rick Rick Hawkins [Non-text portions of this message have been removed]
