Digital BW, The Print
2K 2LK Inkset
2K 2LK Inkset
2013-06-13 by Keith
Based in the UK, I made up this inkset using Opus Pro Dye Ink,and MIS Clear Base.
Have got some super results on both Ilford Smooth Pearl and Photo Paper Directs own Pearl Paper.
However the LK is fading very fast, in a bright room within 10 days.
I am assuming that the MIS base is incompatible with the ink.
If I could source Dye Glop from the same ink manufacture, does anyone know if this would work as a clear base.
An explanation for doing this is that I already had the Opus Pro ink on the shelf, and have used this ink in my colour Epson 1400, my own fade tests have shown no detectable fading after 24 hours in direct sunlight, also it is a very close colour match to Claria dyes.
Any ideas would be very helpful.
Keith Dugdale.
Re: [Digital BW] 2K 2LK Inkset
2013-06-13 by Paul Roark
The clear base I made is specifically matched to the Noritsu K.  I have no
idea what might happen if the ink and base have different dye couplers, for
example.  Frankly, I'd be skeptical of any other dye inkset in terms of
longevity.  Traditional dyes do not dilute well.
Paul
www.PaulRoark.com
> Clear Base.
> Keith Dugdale.
2013-06-14 by Keith
Thanks Paul.
I have found a UK supplier of Noritsu Black at 120GBP for 500ml.
This is said to be suitable for Noritsu Models D701,D703 and D1005.
Is this the stuff that I require.
Keith Dugdale.
2013-06-14 by Paul Roark
That's it.  If there is someone else in your area who is doing this,
sharing the large carts makes sense to lower the initial outlay costs.
Paul
www.PaulRoark.com
On Fri, Jun 14, 2013 at 1:43 PM, Keith <keithdale@...> wrote:
> Thanks Paul.
> Keith Dugdale.
