On 04/05/2013 05:24 PM, Paul wrote:
> For those (like me) who would appreciate a wide format 1.5 pl printer,
> this article indicates we may have one available soon. See
> http://manilastandardtoday.com/2013/02/13/epson-unveils-new-line-of-commercial-industrial-printers/
> On the curious side, Epson has also come out with a new minilab printer
> that uses new "UltraChrome D6" *dyes*! Whether these dyes are the same
> as its Claria & Noritsu dyes is, of course, an interesting question. Why
> Epson would use its pigment trade name on this is also of interest.
> There are no fade test results relating to the UC dyes, but Epson is
> throwing out the term "archival" in some of its literature. However,
> Claria in dark storage has a Wilhelm rating of about 200 years, which by
> older standard would be considered "archival" (whatever that means).
> Paul
> www.PaulRoark.com
Paul, that article is confusing.
The dry minilab model most likely has similar technology to the Noritsu
and Fuji dry minilabs with Epson parts. A page wide inkjet print head
that can squirt 5 droplet sizes and the smallest droplet being 1.5
picoliter. Only the media moves. The Epson model is CcMmYK, Noritsu/Fuji
have 4 and 5 channel models if I recall it correctly.
The wider sign models use a head similar to the existing wide formats
and will print a minimum 3.5 picoliter droplet using (eco)solvent ink. I
do not expect a wide format with 1.5 picoliter droplets if they can not
solve the speed issue. Page wide heads for wide formats exist in the
industrial web/sheet printing machines that are in competition with
offset etc printing technology. Not likely to be of any interest to us
but for photo books that will one day be produced on machines like that
instead of Indigos. Right now the droplet size will be larger than 1.5
picoliter too. Epson, HP, Canon (Oc\ufffd), Ricoh and some other inkjet head
manufacturers are involved.
Kia Silverbrook's Memjet technology has 22cm wide inkjet thermal heads
that can squirt as small as 1 or 1.5 picoliter droplets. Dye ink only so
far. Lenovo and some other companies have made office printers based on
those heads. They are used in the label printing industry too and
possibly with two heads next to one another in wider models. There is a
co\ufffdperation between Oc\ufffd (Canon now) and Silverfast Memjet that delivered
a wide format, the Velocity, first seen on the Drupa 2012.
http://www7.oce.com/velocity/en/
The new HP Officejet Pro + series have page wide heads too but can
squirt pigment inks. 6 picoliter droplets though. Similar $600+ prices
like the Memjet models. HP uses wider assemblies of similar heads on
their web inkjet printing machines and the abandoned dry minilab HP model.
Your quoted article suggests that Epson could become the world leader in
printing technology. They are actually way behind in the total printing
market compared to HP, Canon, Fuji. It is different in some market
segments like photo printing.
Met vriendelijke groet, Ernst Dinkla
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
December 2012: 500+ inkjet media paper white spectral plots.
